[Geoserver-users] Default roles not derived from JDBC groups to JDBC users
We have a JDBC UserGroup Service and a Default Role service. Roles are assigned to the groups. This works. But no role is derived from the group to the users - members of the group. Any suggestion?
Thanks a lot,
Michal
Hi
  1. Please check if your role service is the current active role service.2) Assure that the group names in the db are identical to the names in the xml file. (roles.xml)
Christian
On Thu, Jan 9, 2014 at 6:18 PM, <sredl@anonymised.com> wrote:
Thanks a lot,
Michal
CenturyLink Cloud: The Leader in Enterprise Cloud Services.
Learn Why More Businesses Are Choosing CenturyLink Cloud For
Critical Workloads, Development Environments & Everything In Between.
Get a Quote or Start a Free Trial Today.
http://pubads.g.doubleclick.net/gampad/clk?id=119420431&iu=/4140/ostg.clktrk
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Hi Christian,
Dne 2014-01-11 11:38, Christian Mueller napsal:
Hi
1) Please check if your role service is the current active role
service.
Yes.
Yes.
The role IS assigned to the group. (Please check the attateched file 'screenshot_aagroup.png', group name 'aagroup', role name 'ROLE_aagroup')
But the role is not derived to the group members. (Attached file 'screenshot_aagroup_member.png'. In the "Selected Groups" you see that 'aagroup' is selected. But the 'Derived roles' list is empty.)
Thanks a lot,
Michal
Christian
are
Thanks a lot,
Michal
Between.
[1]
https://lists.sourceforge.net/lists/listinfo/geoserver-users [2]
Links:
[1]
http://pubads.g.doubleclick.net/gampad/clk?id=119420431&amp;iu=/4140/ostg.clktrk
[2] https://lists.sourceforge.net/lists/listinfo/geoserver-users
Strange. Can you make a quick check using the default user group service (xml). Not sure if this is a GUI bug.
Christian
On Mon, Jan 13, 2014 at 4:50 PM, <sredl@anonymised.com> wrote:
Hi Christian,
Hi
    service.
Yes.
  1. Assure that the group names in the db are identical to the names in
Yes.
The role IS assigned to the group. (Please check the attateched file ‘screenshot_aagroup.png’, group name ‘aagroup’, role name ‘ROLE_aagroup’)
But the role is not derived to the group members. (Attached file ‘screenshot_aagroup_member.png’. In the “Selected Groups” you see that ‘aagroup’ is selected. But the ‘Derived roles’ list is empty.)
Thanks a lot,
Michal
Christian
are
Thanks a lot,
Michal
Between.
[1]
Geoserver-users@anonymised.comsourceforge.net
Links:
[1]
Hi Christian,
when I create group and user in the default usergroup service and assign a role from the default role service, it works fine. When user and group is defined in JDBC and the role is assigned in roles.xml, it fails.
I should note, that the JDBC usergroup service is based on views, not tables, so they are read-only. The roles are assigned by editting the roles.xml.
Thanks a lot,
Michal
Dne 2014-01-14 14:26, Christian Mueller napsal:
Christian
Hi Christian,
Hi
service.
Yes.
names in
Yes.
'ROLE_aagroup')
Thanks a lot,
Michal
Christian
are
Thanks a lot,
Michal
Between.
[1]
[2]
Links:
[1]
[1]
[2]
Links:
[1]
View or table makes no difference.
What is the SQL attribute type of your user/group names. Is it CHAR or VARCHAR ?
On Tue, Jan 14, 2014 at 5:56 PM, <sredl@anonymised.com> wrote:
Hi Christian,
Thanks a lot,
Michal
Christian
Hi Christian,
Hi
    service.
Yes.
    names in
Yes.
‘ROLE_aagroup’)
Thanks a lot,
Michal
Christian
are
Thanks a lot,
Michal
Between.
[1]
[1]
[2]
Links:
[1]
[1]
[2]
Links:
[1]
Hi Christian,
I am very sorry, my fault. The error was in the group view - the groups were not enabled... Now it works fine. Thanks a lot.
Michal
Dne 2014-01-15 12:47, Christian Mueller napsal:
VARCHAR ?
Hi Christian,
Thanks a lot,
Michal
Christian
Hi Christian,
Hi
service.
Yes.
names in
Yes.
'ROLE_aagroup')
Thanks a lot,
Michal
Christian
are
Thanks a lot,
Michal
Between.
[2]
[1]
https://lists.sourceforge.net/lists/listinfo/geoserver-users [1]
[2]
Links:
[1]
[2]
[1]
[1]
[2]
Links:
[1]
[2]
[2] https://lists.sourceforge.net/lists/listinfo/geoserver-users [1]
Links:
[1] https://lists.sourceforge.net/lists/listinfo/geoserver-users
[2]
Happy end :slight_smile:
Christian
On Wed, Jan 15, 2014 at 5:53 PM, <sredl@anonymised.com> wrote:
Hi Christian,
I am very sorry, my fault. The error was in the group view - the groups were not enabled… Now it works fine. Thanks a lot.
Michal
VARCHAR ?
Hi Christian,
Thanks a lot,
Michal
Christian
Hi Christian,
Hi
    service.
Yes.
    names in
Yes.
‘ROLE_aagroup’)
Thanks a lot,
Michal
Christian
are
Thanks a lot,
Michal
Between.
[2]
[1]
[1]
[2]
[2]
Links:
[1]
[2]
[1]
[1]
[2]
Links:
[1]
[2]
Links:
[2]
