[Geoserver-users] Deficient shp-files
Hi Mika,
Don't know if this helps, but..
There's many kinds of spatial index files. .qix -files are used by Quantum GIS, .fix -files by uDig and .sbn/.sbx -files by ESRI products. The format of .sbn files is proprietary and hence cannot be implemented by other vendors.
There is a command in Quantum GIS for (re)creating the spatial index file: open the layer and go to menu Layer->Properties.
Jani
Message: 4
Date: Thu, 19 Mar 2009 10:54:34 +0200
Subject: Re: [Geoserver-users] Deficient shp-files
To: Andrea Aime <aaime@anonymised.com>
Cc: geoserver-users <geoserver-users@lists.sourceforge.net>
Message-ID: <49C2084A.20006@anonymised.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Hi Anrea and thanks for your time,
but I am afraid that wiping out of those files doesn't make any
difference. Also, they are geoserver specific, right? What you do with a
uDig or OpenJUMP?
My main point is that in order to use and share shp-files, you shouldn't
have to possess a proprietary software. I can fix my shapes by
"floating" them through MapInfo and mif-format, but what if didn't have
that software?
- mika
Andrea Aime kirjoitti:
Lehtonen, Mika ha scritto:
Hi Andreas,
how can you rebuild the spatial index in Geoserver? Or in other of
those software? I have no idea. Creating the spatial index in
Geoserver won't make any difference anyway. BTW, I am testing with
1.7.1.
Wipe out the .qix and .fix files.
Interesting. I'm not familiar with the different indexing systems on ESRI shapes. I had those .sbn/.sbx files, so the material is coming from some ESRI software? But correct me, if I'm wrong saying that in case you don't have any indexfiles, the rendering should be full in any software which reads shp-format?
thanks,
- mika -
Kylmäaho Jani kirjoitti:
Hi Mika,
Jani
Message: 4
but I am afraid that wiping out of those files doesn't make any difference. Also, they are geoserver specific, right? What you do with a uDig or OpenJUMP?
My main point is that in order to use and share shp-files, you shouldn't have to possess a proprietary software. I can fix my shapes by "floating" them through MapInfo and mif-format, but what if didn't have that software?
- mika
Hi Andreas,
how can you rebuild the spatial index in Geoserver? Or in other of those software? I have no idea. Creating the spatial index in Geoserver won't make any difference anyway. BTW, I am testing with 1.7.1.
This is the case AFIK..
- Jani
Lehtonen, Mika (19.3.2009 11:51):
thanks,
- mika -
Hi Mika,
Jani
Message: 4
uDig or OpenJUMP?
that software?
- mika
Hi Andreas,
1.7.1.
We have had situations which has only been solved by recreating the spatial index with ArcCatalog and/or copying all records to a new shapefile.
This has happened when non-ESRI softwares has created/edited the shapefile or when editing/saving the shapefile during network failures / different OS.
My guess is that the .shx file in some way can get out-of-order, but not fatally. Wikipedia has some more information.
Without a readable spatial index, any zoomin / identify operation will be slow.
Andreas Oxenstierna
Telefon direkt 040-16 70 17
Mobil 0734-12 80 17
andreas.oxenstierna@anonymised.com
SWECO Position AB
Hans Michelsensgatan 2
Box 286
201 22 Malmö
Telefon 040-16 70 00
www.sweco.se
-----Ursprungligt meddelande-----
Från: Lehtonen, Mika [mailto:mika@anonymised.com]
Skickat: den 19 mars 2009 10:52
Till: Kylmäaho Jani
Kopia: geoserver-users@lists.sourceforge.net
Ämne: Re: [Geoserver-users] Deficient shp-files
Interesting. I’m not familiar with the different indexing systems on ESRI shapes. I had those .sbn/.sbx files, so the material is coming from some ESRI software? But correct me, if I’m wrong saying that in case you don’t have any indexfiles, the rendering should be full in any software which reads shp-format?
thanks,
  • mika -
Hi Mika,
Don’t know if this helps, but…
There’s many kinds of spatial index files. .qix -files are used by Quantum GIS, .fix -files by uDig and .sbn/.sbx -files by ESRI products. The format of .sbn files is proprietary and hence cannot be implemented by other vendors.
Jani
Message: 4
To: Andrea Aime aaime@anonymised.com
Cc: geoserver-users geoserver-users@lists.sourceforge.net
Message-ID: 49C2084A.20006@anonymised.com
but I am afraid that wiping out of those files doesn’t make any
shouldn’t have to possess a proprietary software. I can fix my shapes
by “floating” them through MapInfo and mif-format, but what if didn’t
have that software?
  • mika
Hi Andreas,
Geoserver won’t make any difference anyway. BTW, I am testing with
1.7.1.
Apps built with the Adobe(R) Flex(R) framework and Flex Builder™ are powering Web 2.0 with engaging, cross-platform capabilities. Quickly and easily build your RIAs with Flex Builder, the Eclipse™based development software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com _______________________________________________
Geoserver-users mailing list
