[Geoserver-users] Deploy Geoserver 1.7.5 To Jboss 4.2.1
Hello,
when i try to deploy geoserver.war into JBoss i always got the following exceptions:
Can u help me?
2009-07-01 12:28:20,552 INFO [geoserver.catalog] - Loaded namespace ‘sf’ (http://www.openplans.org/spearfish)
2009-07-01 12:28:20,552 INFO [geoserver.catalog] - Loaded namespace ‘topp’ (http://www.openplans.org/topp)
2009-07-01 12:28:20,552 INFO [geoserver.catalog] - Loaded namespace ‘it.geosolutions’ (http://www.geo-solutions.it)
2009-07-01 12:28:20,552 INFO [geoserver.catalog] - Loaded namespace ‘sde’ (http://geoserver.sf.net)
2009-07-01 12:28:20,552 INFO [geoserver.catalog] - Loaded namespace ‘nurc’ (http://www.nurc.nato.int)
2009-07-01 12:28:20,552 INFO [geoserver.catalog] - Loaded namespace ‘tiger’ (http://www.census.gov)
2009-07-01 12:28:20,567 INFO [geoserver.catalog] - Loaded namespace ‘cite’ (http://www.opengeospatial.net/cite)
2009-07-01 12:28:20,567 INFO [geoserver.catalog] - Default namespace: ‘topp’
2009-07-01 12:28:20,567 INFO [geoserver.catalog] - Loaded style ‘burg’
2009-07-01 12:28:20,567 INFO [geoserver.catalog] - Loaded style ‘giant_polygon’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘capitals’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘simple_streams’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘pophatch’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘restricted’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘tiger_roads’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘poly_landmarks’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘green’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘rain’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘simple_roads’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘dem’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘population’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘line’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘raster’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘grass’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘polygon’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘point’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘poi’
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style ‘cite_lakes’
2009-07-01 12:28:21,673 INFO [geoserver.catalog] - Processed data store ‘taz_shapes’, enabled
2009-07-01 12:28:21,892 INFO [geoserver.catalog] - Processed data store ‘sf’, enabled
2009-07-01 12:28:21,969 INFO [geoserver.catalog] - Processed data store ‘nyc’, enabled
2009-07-01 12:28:22,001 INFO [geoserver.catalog] - Processed data store ‘states_shapefile’, enabled
2009-07-01 12:28:22,016 INFO [geoserver.catalog] - Processed coverage store ‘sfdem’, enabled
2009-07-01 12:28:22,016 INFO [geoserver.catalog] - Processed coverage store ‘arcGridSample’, enabled
2009-07-01 12:28:22,016 INFO [geoserver.catalog] - Processed coverage store ‘mosaic’, enabled
2009-07-01 12:28:22,016 INFO [geoserver.catalog] - Processed coverage store ‘img_sample2’, enabled
2009-07-01 12:28:22,016 INFO [geoserver.catalog] - Processed coverage store ‘worldImageSample’, enabled
2009-07-01 12:28:22,873 INFO [geoserver.catalog] - Loaded feature type ‘tiger:giant_polygon’
2009-07-01 12:28:23,309 INFO [geoserver.catalog] - Loaded feature type ‘tiger:poi’
2009-07-01 12:28:23,325 INFO [geoserver.catalog] - Loaded feature type ‘tiger:poly_landmarks’
2009-07-01 12:28:23,340 INFO [geoserver.catalog] - Loaded feature type ‘tiger:tiger_roads’
2009-07-01 12:28:23,886 INFO [geoserver.catalog] - Loaded feature type ‘sf:archsites’
2009-07-01 12:28:23,917 INFO [geoserver.catalog] - Loaded feature type ‘sf:bugsites’
2009-07-01 12:28:23,932 INFO [geoserver.catalog] - Loaded feature type ‘sf:restricted’
2009-07-01 12:28:23,948 INFO [geoserver.catalog] - Loaded feature type ‘sf:roads’
2009-07-01 12:28:23,979 INFO [geoserver.catalog] - Loaded feature type ‘sf:streams’
2009-07-01 12:28:23,995 INFO [geoserver.catalog] - Loaded feature type ‘topp:states’
2009-07-01 12:28:24,026 INFO [geoserver.catalog] - Loaded feature type ‘topp:tasmania_cities’
2009-07-01 12:28:24,042 INFO [geoserver.catalog] - Loaded feature type ‘topp:tasmania_roads’
2009-07-01 12:28:24,057 INFO [geoserver.catalog] - Loaded feature type ‘topp:tasmania_state_boundaries’
2009-07-01 12:28:24,073 INFO [geoserver.catalog] - Loaded feature type ‘topp:tasmania_water_bodies’
2009-07-01 12:28:25,475 WARN [referencing.factory] - Unavailable authority factory: European Petroleum Survey Group
2009-07-01 12:28:25,522 WARN [referencing.factory] - Unavailable authority factory: European Petroleum Survey Group
2009-07-01 12:28:25,537 WARN [referencing.factory] - Unavailable authority factory: European Petroleum Survey Group
2009-07-01 12:28:25,553 WARN [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS[“WGS84 / Simple Mercator”, GEOGCS[“WGS 84”, DATUM[“WGS_1984”, SPHEROID[“WGS_1984”, 6378137.0, 298.257223563]], PRIMEM[“Greenwich”, 0.0], UNIT[“degree”, 0.017453292519943295]], PROJECTION[“Mercator_1SP_Google”], PARAMETER[“latitude_of_origin”, 0.0], PARAMETER[“central_meridian”, 0.0], PARAMETER[“scale_factor”, 1.0], PARAMETER[“false_easting”, 0.0], PARAMETER[“false_northing”, 0.0], UNIT[“m”, 1.0], AXIS[“x”, EAST], AXIS[“y”, NORTH], AUTHORITY[“EPSG”,“54004”]]
2009-07-01 12:28:25,646 WARN [referencing.factory] - Unavailable authority factory: European Petroleum Survey Group
2009-07-01 12:28:25,677 WARN [referencing.factory] - Unavailable authority factory: European Petroleum Survey Group
2009-07-01 12:28:25,693 WARN [referencing.factory] - Unavailable authority factory: European Petroleum Survey Group
2009-07-01 12:28:25,740 WARN [geoserver.catalog] - Error loading ‘arcGridSample_Arc_Sample/info.xml’, ignoring
2009-07-01 12:28:25,740 INFO [geoserver.catalog] -
org.opengis.referencing.NoSuchAuthorityCodeException: No code “EPSG:4326” from authority “European Petroleum Survey Group” found for object of type “IdentifiedObject”.
at org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:949)
at org.geotools.referencing.factory.PropertyAuthorityFactory.getWKT(PropertyAuthorityFactory.java:314)
at org.geotools.referencing.factory.PropertyAuthorityFactory.createCoordinateReferenceSystem(PropertyAuthorityFactory.java:388)
at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:781)
at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:798)
at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:638)
at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:729)
at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
at org.geotools.referencing.CRS.decode(CRS.java:420)
at org.geoserver.catalog.util.LegacyCatalogImporter.readCoverage(LegacyCatalogImporter.java:662)
at org.geoserver.catalog.util.LegacyCatalogImporter.imprt(LegacyCatalogImporter.java:248)
at org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:119)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:81)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3854)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4359)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:761)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:741)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:553)
at org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:297)
at org.jboss.mx.server.RawDynamicInvoker.invoke(RawDynamicInvoker.java:164)
at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659)
at org.apache.catalina.core.StandardContext.init(StandardContext.java:5310)
at org.jboss.web.tomcat.service.TomcatDeployer.performDeployInternal(TomcatDeployer.java:301)
at org.jboss.web.tomcat.service.TomcatDeployer.performDeploy(TomcatDeployer.java:104)
at org.jboss.web.AbstractWebDeployer.start(AbstractWebDeployer.java:375)
at org.jboss.web.WebModule.startModule(WebModule.java:83)
at org.jboss.web.WebModule.startService(WebModule.java:61)
at org.jboss.system.ServiceMBeanSupport.jbossInternalStart(ServiceMBeanSupport.java:289)
at org.jboss.system.ServiceMBeanSupport.jbossInternalLifecycle(ServiceMBeanSupport.java:245)
at sun.reflect.GeneratedMethodAccessor3.invoke(Unknown Source)
at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:155)
at org.jboss.mx.server.Invocation.dispatch(Invocation.java:94)
at org.jboss.mx.server.Invocation.invoke(Invocation.java:86)
at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264)
at org.jboss.system.ServiceController$ServiceProxy.invoke(ServiceController.java:978)
at $Proxy0.start(Unknown Source)
at org.jboss.system.ServiceController.start(ServiceController.java:417)
at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:210)
at $Proxy45.start(Unknown Source)
at org.jboss.web.AbstractWebContainer.start(AbstractWebContainer.java:466)
at org.jboss.mx.interceptor.AbstractInterceptor.invoke(AbstractInterceptor.java:133)
at org.jboss.mx.server.Invocation.invoke(Invocation.java:88)
at org.jboss.mx.interceptor.ModelMBeanOperationInterceptor.invoke(ModelMBeanOperationInterceptor.java:142)
at org.jboss.mx.interceptor.DynamicInterceptor.invoke(DynamicInterceptor.java:97)
at org.jboss.system.InterceptorServiceMBeanSupport.invokeNext(InterceptorServiceMBeanSupport.java:238)
at org.jboss.ws.integration.jboss42.DeployerInterceptor.start(DeployerInterceptor.java:93)
at org.jboss.deployment.SubDeployerInterceptorSupport$XMBeanInterceptor.start(SubDeployerInterceptorSupport.java:188)
at org.jboss.deployment.SubDeployerInterceptor.invoke(SubDeployerInterceptor.java:95)
at $Proxy46.start(Unknown Source)
at org.jboss.deployment.MainDeployer.start(MainDeployer.java:1025)
at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:819)
at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:782)
at sun.reflect.GeneratedMethodAccessor18.invoke(Unknown Source)
at $Proxy9.deploy(Unknown Source)
at org.jboss.deployment.scanner.URLDeploymentScanner.deploy(URLDeploymentScanner.java:421)
at org.jboss.deployment.scanner.URLDeploymentScanner.scan(URLDeploymentScanner.java:634)
at org.jboss.deployment.scanner.AbstractDeploymentScanner$ScannerThread.doScan(AbstractDeploymentScanner.java:263)
at org.jboss.deployment.scanner.AbstractDeploymentScanner.startService(AbstractDeploymentScanner.java:336)
at $Proxy4.start(Unknown Source)
at org.jboss.deployment.SARDeployer.start(SARDeployer.java:302)
at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:766)
at $Proxy5.deploy(Unknown Source)
at org.jboss.system.server.ServerImpl.doStart(ServerImpl.java:482)
at org.jboss.system.server.ServerImpl.start(ServerImpl.java:362)
at org.jboss.Main.boot(Main.java:200)
at org.jboss.Main$1.run(Main.java:508)
at java.lang.Thread.run(Thread.java:595)
2009-07-01 12:28:25,755 WARN [geoserver.catalog] - Error loading ‘arc_sample/info.xml’, ignoring
2009-07-01 12:28:25,755 INFO [geoserver.catalog] -
2009-07-01 12:28:25,864 WARN [geoserver.catalog] - Error loading ‘img_sample/info.xml’, ignoring
2009-07-01 12:28:25,864 INFO [geoserver.catalog] -
org.opengis.referencing.NoSuchAuthorityCodeException: No code “EPSG:32633” from authority “European Petroleum Survey Group” found for object of type “IdentifiedObject”.
2009-07-01 12:28:25,958 WARN [geoserver.catalog] - Error loading ‘img_sample2_Pk50095/info.xml’, ignoring
2009-07-01 12:28:25,958 INFO [geoserver.catalog] -
2009-07-01 12:28:25,973 WARN [geoserver.catalog] - Error loading ‘mosaic_sample/info.xml’, ignoring
2009-07-01 12:28:25,973 INFO [geoserver.catalog] -
2009-07-01 12:28:26,223 WARN [geoserver.catalog] - Ignoring coverage: ‘sfDem_dem’, coverage store ‘sfDem’ not found
2009-07-01 12:28:26,223 WARN [geoserver.catalog] - Error loading ‘sfdem_sfdem/info.xml’, ignoring
2009-07-01 12:28:26,223 INFO [geoserver.catalog] -
org.opengis.referencing.NoSuchAuthorityCodeException: No code “EPSG:26713” from authority “European Petroleum Survey Group” found for object of type “IdentifiedObject”.
2009-07-01 12:28:26,254 WARN [geoserver.catalog] - Error loading ‘worldImageSample_Img_Sample/info.xml’, ignoring
2009-07-01 12:28:26,254 INFO [geoserver.catalog] -
2009-07-01 12:28:26,316 INFO [geoserver.confg] - Loading service ‘wcs’
2009-07-01 12:28:26,332 INFO [geoserver.confg] - Loading service ‘wfs’
2009-07-01 12:28:26,363 WARN [referencing.factory] - Unavailable authority factory: European Petroleum Survey Group
2009-07-01 12:28:26,379 WARN [referencing.factory] - Unavailable authority factory: European Petroleum Survey Group
2009-07-01 12:28:26,410 WARN [referencing.factory] - Unavailable authority factory: European Petroleum Survey Group
2009-07-01 12:28:26,425 WARN [referencing.factory] - Unavailable authority factory: European Petroleum Survey Group
2009-07-01 12:28:26,441 WARN [referencing.factory] - Unavailable authority factory: European Petroleum Survey Group
2009-07-01 12:28:26,472 WARN [referencing.factory] - Unavailable authority factory: European Petroleum Survey Group
2009-07-01 12:28:26,472 WARN [geoserver.confg] - Error occured loading service: wms
2009-07-01 12:28:26,472 INFO [geoserver.confg] -
at org.geotools.referencing.CRS.decode(CRS.java:348)
at org.geoserver.config.util.LegacyServicesReader.wms(LegacyServicesReader.java:227)
at org.geoserver.wms.WMSLoader.load(WMSLoader.java:40)
at org.geoserver.config.util.LegacyServiceLoader.load(LegacyServiceLoader.java:45)
at org.geoserver.config.util.LegacyConfigurationImporter.imprt(LegacyConfigurationImporter.java:160)
at org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:131)
2009-07-01 12:28:27,344 INFO [util.ApplicationContextProvider] - No context parameter, system or Java environment variables found for GEOSERVER_WMS_URL
2009-07-01 12:28:27,344 INFO [util.ApplicationContextProvider] - Reverting to http://localhost:8080/geoserver/wms?request=GetCapabilities
2009-07-01 12:28:27,344 INFO [util.GetCapabilitiesConfiguration] - Constructing from url http://localhost:8080/geoserver/wms?request=GetCapabilities
2009-07-01 12:28:27,376 INFO [storage.DefaultStorageFinder] - *********************************************************************************************************************************
2009-07-01 12:28:27,376 INFO [storage.DefaultStorageFinder] - *** Reverting to java.io.tmpdir C:\DOKUME~1\re22548\LOKALE~1\Temp\geowebcache for storage. Please set GEOWEBCACHE_CACHE_DIR. ***
2009-07-01 12:28:28,684 INFO [geowebcache.GeoWebCacheDispatcher] - set TileLayerDispatcher
2009-07-01 12:28:28,684 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
2009-07-01 12:28:28,715 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
2009-07-01 12:28:28,762 INFO [util.ApplicationContextProvider] - No context parameter, system or Java environment variables found for GEOSERVER_WFS_URL
2009-07-01 12:28:28,778 INFO [util.ApplicationContextProvider] - Reverting to null
2009-07-01 12:28:28,778 INFO [util.ApplicationContextProvider] - No context parameter, system or Java environment variables found for GEOWEBCACHE_WFS_FILTER
2009-07-01 12:28:28,778 INFO [wfs.WFSService] - Configured to forward to http://localhost:8080/geoserver/wfs , timeout is 600000ms, regex filter null
2009-07-01 12:28:28,980 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 4 paths
2009-07-01 12:28:29,152 ERROR [geoserver.global] - Could not load feature type sf:roads
java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code “EPSG:26713” from authority “European Petroleum Survey Group” found for object of type “IdentifiedObject”.
at org.vfny.geoserver.global.FeatureTypeInfo.getSRS(FeatureTypeInfo.java:1012)
at org.vfny.geoserver.global.FeatureTypeInfo.toDTO(FeatureTypeInfo.java:522)
at org.vfny.geoserver.global.Data.toDTO(Data.java:1604)
at org.vfny.geoserver.config.DataConfig.(DataConfig.java:220)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:494)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:100)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:248)
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No code “EPSG:26713” from authority “European Petroleum Survey Group” found for object of type “IdentifiedObject”.
at org.vfny.geoserver.global.FeatureTypeInfo.getSRS(FeatureTypeInfo.java:1008)
… 162 more
2009-07-01 12:28:29,183 ERROR [geoserver.global] - Could not load feature type topp:tasmania_state_boundaries
java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code “EPSG:4326” from authority “European Petroleum Survey Group” found for object of type “IdentifiedObject”.
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No code “EPSG:4326” from authority “European Petroleum Survey Group” found for object of type “IdentifiedObject”.
… 162 more
2009-07-01 12:28:29,230 ERROR [geoserver.global] - Could not load feature type tiger:tiger_roads
… 162 more
2009-07-01 12:28:29,292 ERROR [geoserver.global] - Could not load feature type tiger:poly_landmarks
… 162 more
2009-07-01 12:28:29,323 ERROR [geoserver.global] - Could not load feature type topp:states
… 162 more
2009-07-01 12:28:29,417 ERROR [geoserver.global] - Could not load feature type sf:bugsites
… 162 more
2009-07-01 12:28:29,432 ERROR [geoserver.global] - Could not load feature type topp:tasmania_roads
… 162 more
2009-07-01 12:28:29,448 ERROR [geoserver.global] - Could not load feature type sf:archsites
… 162 more
2009-07-01 12:28:29,448 ERROR [geoserver.global] - Could not load feature type sf:restricted
… 162 more
2009-07-01 12:28:29,494 ERROR [geoserver.global] - Could not load feature type sf:streams
… 162 more
2009-07-01 12:28:29,526 ERROR [geoserver.global] - Could not load feature type topp:tasmania_water_bodies
… 162 more
2009-07-01 12:28:29,541 ERROR [geoserver.global] - Could not load feature type tiger:giant_polygon
… 162 more
2009-07-01 12:28:29,557 ERROR [geoserver.global] - Could not load feature type tiger:poi
… 162 more
2009-07-01 12:28:29,588 ERROR [geoserver.global] - Could not load feature type topp:tasmania_cities
… 162 more
2009-07-01 12:28:31,317 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown…
2009-07-01 12:28:31,317 INFO [geoserver.global] - Done disposing datastores.
2009-07-01 12:28:31,317 INFO [geowebcache.GeoWebCacheDispatcher] - GeoWebCacheDispatcher.destroy() was invoked, shutting down.
2009-07-01 12:28:31,348 WARN [geoserver.securit] - Rule ..r=* is overriding another rule targetting the same resource
2009-07-01 12:28:31,348 WARN [geoserver.securit] - Rule ..w=* is overriding another rule targetting the same resource
2009-07-01 12:28:31,364 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown…
2009-07-01 12:28:31,364 INFO [geoserver.global] - Done disposing datastores.
2009-07-01 12:28:31,364 INFO [geoserver.catalog] - Disposing datastore ‘nyc’
2009-07-01 12:28:31,364 INFO [geoserver.catalog] - Disposing datastore ‘taz_shapes’
2009-07-01 12:28:31,364 INFO [geoserver.catalog] - Disposing datastore ‘states_shapefile’
2009-07-01 12:28:31,364 INFO [geoserver.catalog] - Disposing datastore ‘sf’
2009-07-01 12:28:31,364 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘wmsConfig’ defined in URL [jar:file:/C:/nwp/jboss-4.2.1/server/default/deploy/geoserver.war/WEB-INF/lib/wms-1.7.5.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.vfny.geoserver.config.WMSConfig]: Constructor threw exception; nested exception is java.lang.NullPointerException
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:254)
Caused by: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.vfny.geoserver.config.WMSConfig]: Constructor threw exception; nested exception is java.lang.NullPointerException
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:115)
… 152 more
Caused by: java.lang.NullPointerException
at org.vfny.geoserver.global.Service.toDTO(Service.java:177)
at org.vfny.geoserver.global.WMS.toDTO(WMS.java:289)
at org.vfny.geoserver.config.WMSConfig.(WMSConfig.java:173)
… 154 more
2009-07-01 12:28:31,380 ERROR [[localhost].[/geoserver]] - Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
… 152 more
… 154 more
Is this the first time you are deploying geoserver (any version) into this container. I have seen this error pop up during upgrades. I suggest you undeploy geoserver, then remove any temporary files that your container is holding onto releated to the geoserver webapp (if you see a GeoTools directory that is the one), and then redeploy.
-Justin
Tomasz Kaszubowski wrote:
Hello,
Can u help me?
2009-07-01 12:28:20,552 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://www.openplans.org/spearfish)
2009-07-01 12:28:20,552 INFO [geoserver.catalog] - Loaded namespace 'topp' (http://www.openplans.org/topp)
2009-07-01 12:28:20,552 INFO [geoserver.catalog] - Loaded namespace 'it.geosolutions' (http://www.geo-solutions.it)
2009-07-01 12:28:20,552 INFO [geoserver.catalog] - Loaded namespace 'sde' (http://geoserver.sf.net)
2009-07-01 12:28:20,552 INFO [geoserver.catalog] - Loaded namespace 'nurc' (http://www.nurc.nato.int)
2009-07-01 12:28:20,552 INFO [geoserver.catalog] - Loaded namespace 'tiger' (http://www.census.gov)
2009-07-01 12:28:20,567 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengeospatial.net/cite)
2009-07-01 12:28:20,567 INFO [geoserver.catalog] - Default namespace: 'topp'
2009-07-01 12:28:20,567 INFO [geoserver.catalog] - Loaded style 'burg'
2009-07-01 12:28:20,567 INFO [geoserver.catalog] - Loaded style 'giant_polygon'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'capitals'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'simple_streams'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'pophatch'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'restricted'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'tiger_roads'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'poly_landmarks'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'green'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'rain'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'simple_roads'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'dem'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'population'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'line'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'raster'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'grass'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'polygon'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'point'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'poi'
2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded style 'cite_lakes'
2009-07-01 12:28:21,673 INFO [geoserver.catalog] - Processed data store 'taz_shapes', enabled
2009-07-01 12:28:21,892 INFO [geoserver.catalog] - Processed data store 'sf', enabled
2009-07-01 12:28:21,969 INFO [geoserver.catalog] - Processed data store 'nyc', enabled
2009-07-01 12:28:22,001 INFO [geoserver.catalog] - Processed data store 'states_shapefile', enabled
2009-07-01 12:28:22,016 INFO [geoserver.catalog] - Processed coverage store 'sfdem', enabled
2009-07-01 12:28:22,016 INFO [geoserver.catalog] - Processed coverage store 'arcGridSample', enabled
2009-07-01 12:28:22,016 INFO [geoserver.catalog] - Processed coverage store 'mosaic', enabled
2009-07-01 12:28:22,016 INFO [geoserver.catalog] - Processed coverage store 'img_sample2', enabled
2009-07-01 12:28:22,016 INFO [geoserver.catalog] - Processed coverage store 'worldImageSample', enabled
2009-07-01 12:28:22,873 INFO [geoserver.catalog] - Loaded feature type 'tiger:giant_polygon'
2009-07-01 12:28:23,309 INFO [geoserver.catalog] - Loaded feature type 'tiger:poi'
2009-07-01 12:28:23,325 INFO [geoserver.catalog] - Loaded feature type 'tiger:poly_landmarks'
2009-07-01 12:28:23,340 INFO [geoserver.catalog] - Loaded feature type 'tiger:tiger_roads'
2009-07-01 12:28:23,886 INFO [geoserver.catalog] - Loaded feature type 'sf:archsites'
2009-07-01 12:28:23,917 INFO [geoserver.catalog] - Loaded feature type 'sf:bugsites'
2009-07-01 12:28:23,932 INFO [geoserver.catalog] - Loaded feature type 'sf:restricted'
2009-07-01 12:28:23,948 INFO [geoserver.catalog] - Loaded feature type 'sf:roads'
2009-07-01 12:28:23,979 INFO [geoserver.catalog] - Loaded feature type 'sf:streams'
2009-07-01 12:28:23,995 INFO [geoserver.catalog] - Loaded feature type 'topp:states'
2009-07-01 12:28:24,026 INFO [geoserver.catalog] - Loaded feature type 'topp:tasmania_cities'
2009-07-01 12:28:24,042 INFO [geoserver.catalog] - Loaded feature type 'topp:tasmania_roads'
2009-07-01 12:28:24,057 INFO [geoserver.catalog] - Loaded feature type 'topp:tasmania_state_boundaries'
2009-07-01 12:28:24,073 INFO [geoserver.catalog] - Loaded feature type 'topp:tasmania_water_bodies'
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984", SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295]], PROJECTION["Mercator_1SP_Google"], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","54004"]]
2009-07-01 12:28:25,740 WARN [geoserver.catalog] - Error loading 'arcGridSample_Arc_Sample/info.xml', ignoring
org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
2009-07-01 12:28:25,755 WARN [geoserver.catalog] - Error loading 'arc_sample/info.xml', ignoring
2009-07-01 12:28:25,864 WARN [geoserver.catalog] - Error loading 'img_sample/info.xml', ignoring
org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:32633" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
2009-07-01 12:28:25,958 WARN [geoserver.catalog] - Error loading 'img_sample2_Pk50095/info.xml', ignoring
2009-07-01 12:28:25,973 WARN [geoserver.catalog] - Error loading 'mosaic_sample/info.xml', ignoring
2009-07-01 12:28:26,223 WARN [geoserver.catalog] - Ignoring coverage: 'sfDem_dem', coverage store 'sfDem' not found
2009-07-01 12:28:26,223 WARN [geoserver.catalog] - Error loading 'sfdem_sfdem/info.xml', ignoring
org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:26713" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
2009-07-01 12:28:26,254 WARN [geoserver.catalog] - Error loading 'worldImageSample_Img_Sample/info.xml', ignoring
2009-07-01 12:28:26,316 INFO [geoserver.confg] - Loading service 'wcs'
2009-07-01 12:28:26,332 INFO [geoserver.confg] - Loading service 'wfs'
2009-07-01 12:28:27,376 INFO [storage.DefaultStorageFinder] - *** Reverting to java.io.tmpdir C:\DOKUME~1\re22548\LOKALE~1\Temp\\geowebcache for storage. Please set GEOWEBCACHE_CACHE_DIR. ***
java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:26713" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
    at org.vfny.geoserver.config.DataConfig.<init>(DataConfig.java:220)
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:26713" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
    ... 162 more
java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
    ... 162 more
    ... 162 more
    ... 162 more
    ... 162 more
    ... 162 more
    ... 162 more
    ... 162 more
    ... 162 more
    ... 162 more
    ... 162 more
    ... 162 more
    ... 162 more
    ... 162 more
2009-07-01 12:28:31,317 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
2009-07-01 12:28:31,348 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
2009-07-01 12:28:31,348 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
2009-07-01 12:28:31,364 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
2009-07-01 12:28:31,364 INFO [geoserver.catalog] - Disposing datastore 'nyc'
2009-07-01 12:28:31,364 INFO [geoserver.catalog] - Disposing datastore 'taz_shapes'
2009-07-01 12:28:31,364 INFO [geoserver.catalog] - Disposing datastore 'states_shapefile'
2009-07-01 12:28:31,364 INFO [geoserver.catalog] - Disposing datastore 'sf'
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'wmsConfig' defined in URL [jar:file:/C:/nwp/jboss-4.2.1/server/default/deploy/geoserver.war/WEB-INF/lib/wms-1.7.5.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.vfny.geoserver.config.WMSConfig]: Constructor threw exception; nested exception is java.lang.NullPointerException
    ... 152 more
    at org.vfny.geoserver.config.WMSConfig.<init>(WMSConfig.java:173)
    ... 154 more
    ... 152 more
    ... 154 more
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
It is appreciated if you can keep all conversation on the public email list. Thanks :slight_smile:
Not sure what the problem might be then... i will try to grab a jboss download and try it out when i get a minute, see if it works for me.
-Justin
Yes it was the first time i´ve tried to deploy geoserver.
Now i have removed every geoserver files from jboss directory, but i still got the same error.
2009/7/3 Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>>
    redeploy. -Justin Tomasz Kaszubowski wrote: > Hello, > when i try to
    deploy geoserver.war into JBoss i always got the following >
    exceptions: > > Can u help me? > > > 2009-07-01 12:28:20,552 INFO
    [geoserver.catalog] - Loaded namespace 'sf' >
    (http://www.openplans.org/spearfish) > 2009-07-01 12:28:20,552 INFO
    [geoserver.catalog] - Loaded namespace > 'topp'
    (http://www.openplans.org/topp) > 2009-07-01 12:28:20,552 INFO
    [geoserver.catalog] - Loaded namespace > 'it.geosolutions'
    (http://www.geo-solutions.it) > 2009-07-01 12:28:20,552 INFO
    [geoserver.catalog] - Loaded namespace > 'sde'
    (http://geoserver.sf.net) > 2009-07-01 12:28:20,552 INFO
    [geoserver.catalog] - Loaded namespace > 'nurc'
    (http://www.nurc.nato.int) > 2009-07-01 12:28:20,552 INFO
    [geoserver.catalog] - Loaded namespace > 'tiger'
    (http://www.census.gov) > 2009-07-01 12:28:20,567 INFO
    [geoserver.catalog] - Loaded namespace > 'cite'
    (http://www.opengeospatial.net/cite) > 2009-07-01 12:28:20,567 INFO
    [geoserver.catalog] - Default namespace: 'topp' > 2009-07-01
    12:28:20,567 INFO [geoserver.catalog] - Loaded style 'burg' >
    2009-07-01 12:28:20,567 INFO [geoserver.catalog] - Loaded style >
    'giant_polygon' > 2009-07-01 12:28:20,583 INFO [geoserver.catalog] -
    Loaded style 'capitals' > 2009-07-01 12:28:20,583 INFO
    [geoserver.catalog] - Loaded style > 'simple_streams' > 2009-07-01
    12:28:20,583 INFO [geoserver.catalog] - Loaded style 'pophatch' >
    'restricted' > 2009-07-01 12:28:20,583 INFO [geoserver.catalog] -
    Loaded style > 'tiger_roads' > 2009-07-01 12:28:20,583 INFO
    [geoserver.catalog] - Loaded style > 'poly_landmarks' > 2009-07-01
    12:28:20,583 INFO [geoserver.catalog] - Loaded style 'green' >
    'rain' > 2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded
    style > 'simple_roads' > 2009-07-01 12:28:20,583 INFO
    [geoserver.catalog] - Loaded style 'dem' > 2009-07-01 12:28:20,583
    INFO [geoserver.catalog] - Loaded style 'population' > 2009-07-01
    12:28:20,583 INFO [geoserver.catalog] - Loaded style 'line' >
    'raster' > 2009-07-01 12:28:20,583 INFO [geoserver.catalog] - Loaded
    style 'grass' > 2009-07-01 12:28:20,583 INFO [geoserver.catalog] -
    Loaded style 'polygon' > 2009-07-01 12:28:20,583 INFO
    [geoserver.catalog] - Loaded style 'point' > 2009-07-01 12:28:20,583
    INFO [geoserver.catalog] - Loaded style 'poi' > 2009-07-01
    12:28:20,583 INFO [geoserver.catalog] - Loaded style 'cite_lakes' >
    store > 'taz_shapes', enabled > 2009-07-01 12:28:21,892 INFO
    [geoserver.catalog] - Processed data store > 'sf', enabled >
    store > 'nyc', enabled > 2009-07-01 12:28:22,001 INFO
    [geoserver.catalog] - Processed data store > 'states_shapefile',
    enabled > 2009-07-01 12:28:22,016 INFO [geoserver.catalog] -
    Processed coverage > store 'sfdem', enabled > 2009-07-01
    12:28:22,016 INFO [geoserver.catalog] - Processed coverage > store
    'arcGridSample', enabled > 2009-07-01 12:28:22,016 INFO
    [geoserver.catalog] - Processed coverage > store 'mosaic', enabled >
    coverage > store 'img_sample2', enabled > 2009-07-01 12:28:22,016
    'worldImageSample', enabled > 2009-07-01 12:28:22,873 INFO
    [geoserver.catalog] - Loaded feature type > 'tiger:giant_polygon' >
    type > 'tiger:poi' > 2009-07-01 12:28:23,325 INFO
    [geoserver.catalog] - Loaded feature type > 'tiger:poly_landmarks' >
    type > 'tiger:tiger_roads' > 2009-07-01 12:28:23,886 INFO
    [geoserver.catalog] - Loaded feature type > 'sf:archsites' >
    type > 'sf:bugsites' > 2009-07-01 12:28:23,932 INFO
    [geoserver.catalog] - Loaded feature type > 'sf:restricted' >
    type > 'sf:roads' > 2009-07-01 12:28:23,979 INFO [geoserver.catalog]
    - Loaded feature type > 'sf:streams' > 2009-07-01 12:28:23,995 INFO
    [geoserver.catalog] - Loaded feature type > 'topp:states' >
    type > 'topp:tasmania_cities' > 2009-07-01 12:28:24,042 INFO
    [geoserver.catalog] - Loaded feature type > 'topp:tasmania_roads' >
    type > 'topp:tasmania_state_boundaries' > 2009-07-01 12:28:24,073
    INFO [geoserver.catalog] - Loaded feature type >
    'topp:tasmania_water_bodies' > 2009-07-01 12:28:25,475 WARN
    [referencing.factory] - Unavailable > authority factory: European
    Petroleum Survey Group > 2009-07-01 12:28:25,522 WARN
    Petroleum Survey Group > 2009-07-01 12:28:25,537 WARN
    Petroleum Survey Group > 2009-07-01 12:28:25,553 WARN
    [referencing.factory] - Axis elements found > in a wkt definition,
    the force longitude first axis order hint might not > be respected:
     > PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84",
    DATUM["WGS_1984", > SPHEROID["WGS_1984", 6378137.0, 298.257223563]],
    PRIMEM["Greenwich", > 0.0], UNIT["degree", 0.017453292519943295]], >
    0.0], > PARAMETER["central_meridian", 0.0],
    PARAMETER["scale_factor", 1.0], > PARAMETER["false_easting", 0.0],
    PARAMETER["false_northing", 0.0], > UNIT["m", 1.0], AXIS["x", EAST],
    AXIS["y", NORTH], > AUTHORITY["EPSG","54004"]] > 2009-07-01
    12:28:25,646 WARN [referencing.factory] - Unavailable > authority
    factory: European Petroleum Survey Group > 2009-07-01 12:28:25,677
    WARN [referencing.factory] - Unavailable > authority factory:
    European Petroleum Survey Group > 2009-07-01 12:28:25,693 WARN
    Petroleum Survey Group > 2009-07-01 12:28:25,740 WARN
    [geoserver.catalog] - Error loading >
    'arcGridSample_Arc_Sample/info.xml', ignoring > 2009-07-01
    12:28:25,740 INFO [geoserver.catalog] - >
    org.opengis.referencing.NoSuchAuthorityCodeException: No code >
    for > object of type "IdentifiedObject". > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at org.geotools.referencing.CRS.decode(CRS.java:420) > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at java.security.AccessController.doPrivileged(Native Method) >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
     > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) >
    at >
     > at >
     > at java.lang.reflect.Method.invoke(Method.java:585) > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at org.jboss.web.WebModule.startModule(WebModule.java:83) > at
    org.jboss.web.WebModule.startService(WebModule.java:61) > at >
     > at >
     > at sun.reflect.GeneratedMethodAccessor3.invoke(Unknown Source) >
    at >
     > at org.jboss.mx.server.Invocation.dispatch(Invocation.java:94) >
    at org.jboss.mx.server.Invocation.invoke(Invocation.java:86) > at >
     > at
     > at >
     > at $Proxy0.start(Unknown Source) > at
     > at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source) >
    at >
     > at
     > at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:210)
     > at $Proxy45.start(Unknown Source) > at >
    at >
     > at >
    at >
     > at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
     > at $Proxy46.start(Unknown Source) > at
    org.jboss.deployment.MainDeployer.start(MainDeployer.java:1025) > at
    org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:819) > at
    org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:782) > at
    sun.reflect.GeneratedMethodAccessor18.invoke(Unknown Source) > at >
    at >
     > at
     > at $Proxy9.deploy(Unknown Source) > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at $Proxy4.start(Unknown Source) > at
    org.jboss.deployment.SARDeployer.start(SARDeployer.java:302) > at
    org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:766) > at
    sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) > at >
     > at >
    at >
     > at
     > at $Proxy5.deploy(Unknown Source) > at
    org.jboss.system.server.ServerImpl.doStart(ServerImpl.java:482) > at
    org.jboss.system.server.ServerImpl.start(ServerImpl.java:362) > at
    org.jboss.Main.boot(Main.java:200) > at
    org.jboss.Main$1.run(Main.java:508) > at
    java.lang.Thread.run(Thread.java:595) > 2009-07-01 12:28:25,755 WARN
    [geoserver.catalog] - Error loading > 'arc_sample/info.xml',
    ignoring > 2009-07-01 12:28:25,755 INFO [geoserver.catalog] - >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    java.lang.Thread.run(Thread.java:595) > 2009-07-01 12:28:25,864 WARN
    [geoserver.catalog] - Error loading > 'img_sample/info.xml',
    ignoring > 2009-07-01 12:28:25,864 INFO [geoserver.catalog] - >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    java.lang.Thread.run(Thread.java:595) > 2009-07-01 12:28:25,958 WARN
    'img_sample2_Pk50095/info.xml', ignoring > 2009-07-01 12:28:25,958
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    java.lang.Thread.run(Thread.java:595) > 2009-07-01 12:28:25,973 WARN
    [geoserver.catalog] - Error loading > 'mosaic_sample/info.xml',
    ignoring > 2009-07-01 12:28:25,973 INFO [geoserver.catalog] - >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    java.lang.Thread.run(Thread.java:595) > 2009-07-01 12:28:26,223 WARN
    [geoserver.catalog] - Ignoring coverage: > 'sfDem_dem', coverage
    store 'sfDem' not found > 2009-07-01 12:28:26,223 WARN
    [geoserver.catalog] - Error loading > 'sfdem_sfdem/info.xml',
    ignoring > 2009-07-01 12:28:26,223 INFO [geoserver.catalog] - >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    java.lang.Thread.run(Thread.java:595) > 2009-07-01 12:28:26,254 WARN
    'worldImageSample_Img_Sample/info.xml', ignoring > 2009-07-01
    12:28:26,254 INFO [geoserver.catalog] - >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    java.lang.Thread.run(Thread.java:595) > 2009-07-01 12:28:26,316 INFO
    [geoserver.confg] - Loading service 'wcs' > 2009-07-01 12:28:26,332
    INFO [geoserver.confg] - Loading service 'wfs' > 2009-07-01
    12:28:26,363 WARN [referencing.factory] - Unavailable > authority
    factory: European Petroleum Survey Group > 2009-07-01 12:28:26,379
    European Petroleum Survey Group > 2009-07-01 12:28:26,410 WARN
    Petroleum Survey Group > 2009-07-01 12:28:26,425 WARN
    Petroleum Survey Group > 2009-07-01 12:28:26,441 WARN
    Petroleum Survey Group > 2009-07-01 12:28:26,472 WARN
    [geoserver.confg] - Error occured loading > service: wms >
    2009-07-01 12:28:26,472 INFO [geoserver.confg] - >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    org.geotools.referencing.CRS.decode(CRS.java:348) > at >
     > at org.geoserver.wms.WMSLoader.load(WMSLoader.java:40) > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    java.lang.Thread.run(Thread.java:595) > 2009-07-01 12:28:27,344 INFO
    [util.ApplicationContextProvider] - No > context parameter, system
    or Java environment variables found for > GEOSERVER_WMS_URL >
    2009-07-01 12:28:27,344 INFO [util.ApplicationContextProvider] - >
    Reverting to
    http://localhost:8080/geoserver/wms?request=GetCapabilities >
    2009-07-01 12:28:27,344 INFO [util.GetCapabilitiesConfiguration] - >
    Constructing from url >
    2009-07-01 12:28:27,376 INFO [storage.DefaultStorageFinder] - >
     > 2009-07-01 12:28:27,376 INFO [storage.DefaultStorageFinder] - ***
     > Reverting to java.io.tmpdir >
    set > GEOWEBCACHE_CACHE_DIR. *** > 2009-07-01 12:28:27,376 INFO
     > 2009-07-01 12:28:28,684 INFO [geowebcache.GeoWebCacheDispatcher]
    - set > TileLayerDispatcher > 2009-07-01 12:28:28,684 INFO
    [geowebcache.GeoWebCacheDispatcher] - > Invoked
    setServletPrefix(gwc) > 2009-07-01 12:28:28,715 INFO
    [wms.WMSService] - Will proxy requests to > backend that are not
    getmap or getcapabilities. > 2009-07-01 12:28:28,762 INFO
    or Java environment variables found for > GEOSERVER_WFS_URL >
    2009-07-01 12:28:28,778 INFO [util.ApplicationContextProvider] - >
    Reverting to null > 2009-07-01 12:28:28,778 INFO
    or Java environment variables found for > GEOWEBCACHE_WFS_FILTER >
    Reverting to null > 2009-07-01 12:28:28,778 INFO [wfs.WFSService] -
    Configured to forward to > http://localhost:8080/geoserver/wfs ,
    timeout is 600000ms, regex filter null > 2009-07-01 12:28:28,980
    INFO [rest.RESTDispatcher] - Created > RESTDispatcher with 4 paths >
    2009-07-01 12:28:29,152 ERROR [geoserver.global] - Could not load >
    feature type sf:roads > java.lang.RuntimeException: >
     > at >
     > at org.vfny.geoserver.global.Data.toDTO(Data.java:1604) > at
    org.vfny.geoserver.config.DataConfig.(DataConfig.java:220) > at
    Method) > at >
     > at >
     > at
    java.lang.reflect.Constructor.newInstance(Constructor.java:494) > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    java.lang.Thread.run(Thread.java:595) > Caused by:
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > ... 162 more > 2009-07-01 12:28:29,183 ERROR [geoserver.global] -
    Could not load > feature type topp:tasmania_state_boundaries >
     > at >
    Method) > at >
     > at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > ... 162 more > 2009-07-01 12:28:29,230 ERROR [geoserver.global] -
    Could not load > feature type tiger:tiger_roads >
     > at >
    Method) > at >
     > at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > ... 162 more > 2009-07-01 12:28:29,292 ERROR [geoserver.global] -
    Could not load > feature type tiger:poly_landmarks >
     > at >
    Method) > at >
     > at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > ... 162 more > 2009-07-01 12:28:29,323 ERROR [geoserver.global] -
    Could not load > feature type topp:states >
     > at >
    Method) > at >
     > at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > ... 162 more > 2009-07-01 12:28:29,417 ERROR [geoserver.global] -
    Could not load > feature type sf:bugsites >
     > at >
    Method) > at >
     > at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > ... 162 more > 2009-07-01 12:28:29,432 ERROR [geoserver.global] -
    Could not load > feature type topp:tasmania_roads >
     > at >
    Method) > at >
     > at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > ... 162 more > 2009-07-01 12:28:29,448 ERROR [geoserver.global] -
    Could not load > feature type sf:archsites >
     > at >
    Method) > at >
     > at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    Could not load > feature type sf:restricted >
     > at >
    Method) > at >
     > at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > ... 162 more > 2009-07-01 12:28:29,494 ERROR [geoserver.global] -
    Could not load > feature type sf:streams >
     > at >
    Method) > at >
     > at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > ... 162 more > 2009-07-01 12:28:29,526 ERROR [geoserver.global] -
    Could not load > feature type topp:tasmania_water_bodies >
     > at >
    Method) > at >
     > at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > ... 162 more > 2009-07-01 12:28:29,541 ERROR [geoserver.global] -
    Could not load > feature type tiger:giant_polygon >
     > at >
    Method) > at >
     > at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > ... 162 more > 2009-07-01 12:28:29,557 ERROR [geoserver.global] -
    Could not load > feature type tiger:poi >
     > at >
    Method) > at >
     > at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > ... 162 more > 2009-07-01 12:28:29,588 ERROR [geoserver.global] -
    Could not load > feature type topp:tasmania_cities >
     > at >
    Method) > at >
     > at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > ... 162 more > 2009-07-01 12:28:31,317 INFO [geoserver.global] -
    Disposing DataStores > at GeoServer shutdown... > 2009-07-01
    12:28:31,317 INFO [geoserver.global] - Done disposing datastores. >
    2009-07-01 12:28:31,317 INFO [geowebcache.GeoWebCacheDispatcher] - >
    GeoWebCacheDispatcher.destroy() was invoked, shutting down. >
    2009-07-01 12:28:31,348 WARN [geoserver.securit] - Rule *.*.r=* is >
    overriding another rule targetting the same resource > 2009-07-01
    12:28:31,348 WARN [geoserver.securit] - Rule *.*.w=* is > overriding
    another rule targetting the same resource > 2009-07-01 12:28:31,364
    INFO [geoserver.global] - Disposing DataStores > at GeoServer
    shutdown... > 2009-07-01 12:28:31,364 INFO [geoserver.global] - Done
    disposing datastores. > 2009-07-01 12:28:31,364 INFO
    [geoserver.catalog] - Disposing datastore 'nyc' > 2009-07-01
    12:28:31,364 INFO [geoserver.catalog] - Disposing datastore >
    'taz_shapes' > 2009-07-01 12:28:31,364 INFO [geoserver.catalog] -
    Disposing datastore > 'states_shapefile' > 2009-07-01 12:28:31,364
    INFO [geoserver.catalog] - Disposing datastore 'sf' > 2009-07-01
    12:28:31,364 ERROR [context.ContextLoader] - Context >
    initialization failed >
    creating > bean with name 'wmsConfig' defined in URL >
     > Instantiation of bean failed; nested exception is >
    org.springframework.beans.BeanInstantiationException: Could not >
    instantiate bean class [org.vfny.geoserver.config.WMSConfig]: >
    Constructor threw exception; nested exception is >
    java.lang.NullPointerException > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    org.springframework.beans.BeanInstantiationException: Could > not
     > at >
     > at >
     > ... 152 more > Caused by: java.lang.NullPointerException > at
    org.vfny.geoserver.global.Service.toDTO(Service.java:177) > at
    org.vfny.geoserver.global.WMS.toDTO(WMS.java:289) > at
    org.vfny.geoserver.config.WMSConfig.(WMSConfig.java:173) > at
    Method) > at >
     > at >
     > at
     > ... 154 more > 2009-07-01 12:28:31,380 ERROR
    [[localhost].[/geoserver]] - Exception > sending context initialized
    event to listener instance of class >
    org.springframework.web.context.ContextLoaderListener >
     > at >
     > at >
     > at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at >
     > at >
     > at
     > at >
    at >
     > at >
     > at >
     > at
     > at >
     > at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
    at >
     > at >
    at >
     > at >
     > at >
     > at >
     > at >
     > at >
     > at
    at >
     > at
     > at >
     > at >
     > at >
     > at >
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
    at >
     > at
     > at >
     > at >
    Method) > at >
     > at >
     > at
     > ... 154 more > > >
     > > _______________________________________________ >
    Geoserver-users mailing list > Geoserver-users@lists.sourceforge.net
    <mailto:Geoserver-users@lists.sourceforge.net> >
    https://lists.sourceforge.net/lists/listinfo/geoserver-users --
    Justin Deoliveira OpenGeo - http://opengeo.org Enterprise support
Justin Deoliveira
I would double check if you have explicitly defined any of the following system properties:
-DEPSG-HSQL.directory
-Djboss.server.temp.dir
-Djboss.server.data.dir
in your script that launches JBoss and verify that you have cleaned those directories out.
If you don't explicitly specify EPSG-HSQL.directory, I believe it gets stored in java.io.tmpdir (which is /tmp on my Linux system so ends up being /tmp/Geotools/Databases/HSQL/)
Ryan
