[Geoserver-users] Deploying geoserver 1.7 war in Tomcat (Mac OSX 10.5)
Hi-
I have been trying to deploy geoserver in Tomcat on Mac OSX Leopard server, and I keep running into the same error:
>Nov 18 2008 3:26:55 PM org.apache.catalina.core.StandardContext listenerStart
>SEVERE: Exception sending context initialized event to listener instance of class org.geoserver.GeoserverInitStartupListener
>java.lang.NoCassDefFoundError
I've tried everything I can think of to make sure that tomcat is looking in the right place and that geoserver has the correct permissions, but I'm basing that on the war-file install instructions in the User guide.
Any suggestions as to what I'm doing wrong?
Thanks-
Seth
Hi Seth,
The class that can not be found is the first thing loaded by GeoServer... so this would indicate to me that the installation is somehow corrupt.
Has the war been fully unpacked? IE. Does the directory <tomcat>/webapps/geoserver exist? Also verify that the directory webapps/geoserver/WEB-INF/lib contains a file web-1.7.0.jar.
Seth Stradling wrote:
Hi-
Thanks-
Seth
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Seth,
(keeping the reply on the public list)
So yeah, definitely an issue with the unpacking then. I don't know of any issues with the tomcat manager, but what i usually do myself is just copy the war into the webapps folder and let tomcat auto deploy it for me. But i guess this only works if you have access to the server file system.
If you do have access can you provide a listing of the files under webapps/geoserver. Might help us figure out what the issue is.
Another thing that might be prudent before trying to redeploy is removing the geoserver "work" directory. <tomcat>/work/Catalina/localhost/geoserver
-Justin
Geoserver did unpack into the correct directory, but I am missing web-1.7.0.jar (I re-downloaded the war file this morning, and have had the same result). I used the Tomcat application manager to upload the .war - could that be the reason why it is not unpacking properly?
Thanks-
Seth
On Nov 19, 2008, at 9:09 AM, Justin Deoliveira wrote:
Hi Seth,
Hi-
Thanks-
Seth
Justin Deoliveira
Justin Deoliveira
Hi Justin -
I went ahead and tried autodeploying the war file, but had the same result. I also unpacked the .war using StuffIt and could not find the web-1.7.0 jar doing that either.
The file directory under webapps/geoserver looks like:
  -Data
-editArea
-gmaps
-images
-index.jsp
-meta-inf
-openlayers
-popup_map
-rss
-schemas
-style.css
-WEB-INF
-Seth
On Nov 20, 2008, at 9:54 AM, Justin Deoliveira wrote:
Hi Seth,
-Justin
Thanks-
Seth
Hi Seth,
Hi-
Thanks-
Seth
Justin Deoliveira
Justin Deoliveira
Hi Seth,
Can you show me which files are under WEB-INF/lib? Alternatively you can just zip up the entire geoserver directory and post it somewhere i can get at it.
-Justin
Hi Justin -
-Data
-editArea
-gmaps
-images
-index.jsp
-meta-inf
-openlayers
-popup_map
-rss
-schemas
-style.css
-WEB-INF
-Seth
Hi Seth,
-Justin
Thanks-
Seth
Hi Seth,
Hi-
Thanks-
Seth
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
NIE-2-Attachment-Warning.txt (2.06 KB)
Hi Justin -
I can’t post the .zip file anywhere it’s accessible (I’m behind a firewall) and it looks like the last email I sent got the .zip attachment stripped (same deal), so I’ve attached a .rtf of the WEB-INF/lib directory and included the list below as well.
Thanks-
Seth
geoserver WEB-inf directory.rtf (91 Bytes)
geoserver WEB-inf directory.rtf (3.18 KB)
Hi again-
I just tried deploying the .war file on tomcat 5.5 (I was running 6 on the xserve) and it worked fine. Then I tried moving the webapp file back over into 6 and no luck. Is there anything specific to how tomcat 6 unpacks/loads that might be causing the problem?
Thanks again-
Seth
On Nov 21, 2008, at 8:59 AM, Seth Stradling wrote:
Hi Justin -
Thanks-
Seth
acegi-security-1.0.3.jar
activation-1.1.jar
ant-optional-1.5.1.jar
antlr-2.7.2.jar
aopalliance-1.0.jar
batik-awt-util-1.6.jar
batik-bridge-1.6.jar
batik-css-1.6.jar
batik-dom-1.6.jar
batik-ext-1.6.jar
batik-gvt-1.6.jar
batik-parser-1.6.jar
batik-script-1.6.jar
batik-svg-dom-1.6.jar
batik-svggen-1.6.jar
batik-transcoder-1.6.jar
batik-util-1.6.jar
batik-xml-1.6.jar
cglib-nodep-2.1_3.jar
com.noelios.restlet-1.0.8.jar
com.noelios.restlet.ext.servlet-1.0.8.jar
common-2.2.1.jar
commons-beanutils-1.7.0.jar
commons-codec-1.3.jar
commons-collections-3.1.jar
commons-dbcp-1.2.2.jar
commons-digester-1.7.jar
commons-fileupload-1.2.1.jar
commons-httpclient-2.0.jar
commons-io-1.3.2.jar
commons-jxpath-1.2.jar
commons-lang-2.1.jar
commons-logging-1.0.3.jar
commons-pool-1.3.jar
commons-validator-1.1.4.jar
data-1.7.0.jar
easymock-2.3.jar
easymockclassextension-2.3.jar
ecore-2.2.2.jar
ezmorph-1.0.3.jar
freemarker-2.3.13.jar
geoapi-2.2-20081020.191707-33.jar
gt-api-2.5.1.jar
gt-arcgrid-2.5.1.jar
gt-coverage-2.5.1.jar
gt-cql-2.5.1.jar
gt-data-2.5.1.jar
gt-epsg-hsql-2.5.1.jar
gt-geotiff-2.5.1.jar
gt-graph-2.5.1.jar
gt-gtopo30-2.5.1.jar
gt-image-2.5.1.jar
gt-imagemosaic-2.5.1.jar
gt-jdbc-2.5.1.jar
gt-main-2.5.1.jar
gt-metadata-2.5.1.jar
gt-postgis-2.5.1.jar
gt-property-2.5.1.jar
gt-referencing-2.5.1.jar
gt-render-2.5.1.jar
gt-shapefile-2.5.1.jar
gt-shapefile-renderer-2.5.1.jar
gt-validation-2.5.1.jar
gt-wfs-2.5.1.jar
gt-wms-2.5.1.jar
gt-xml-2.5.1.jar
gt-xsd-core-2.5.1.jar
gt-xsd-filter-2.5.1.jar
gt-xsd-gml2-2.5.1.jar
gt-xsd-gml3-2.5.1.jar
gt-xsd-ows-2.5.1.jar
gt-xsd-wfs-2.5.1.jar
h2-1.0-20070319.231009-1.jar
hsqldb-1.8.0.7.jar
imageio-ext-arcgrid-1.0-SNAPSHOT.jar
imageio-ext-customstreams-1.0-SNAPSHOT.jar
itext-2.0.6.jar
jai_codec-1.1.3.jar
jai_core-1.1.3.jar
jai_imageio-1.1.jar
jdom-1.0.jar
json-lib-2.1-jdk13.jar
jsr-275-1.0-beta-2.jar
jstl-1.0.6.jar
jts-1.9.jar
log4j-1.2.14.jar
lucene-1.4.3.jar
mail-1.4.jar
main-1.7.0.jar
net.opengis.ows-2.5.1.jar
net.opengis.wcs-2.5.1.jar
net.opengis.wfs-2.5.1.jar
org.restlet-1.0.8.jar
org.restlet.ext.freemarker-1.0.8.jar
org.w3.xlink-2.5.1.jar
oro-2.0.8.jar
ows-1.7.0-tests.jar
ows-1.7.0.jar
picocontainer-1.2.jar
platform-1.7.0.jar
postgis-driver-1.0.jar
postgresql-8.1-407.jdbc3.jar
spring-aop-2.5.5.jar
spring-beans-2.5.5.jar
spring-context-2.5.5.jar
spring-context-support-2.5.5.jar
spring-core-2.5.5.jar
spring-jdbc-2.5.5.jar
spring-tx-2.5.5.jar
spring-web-2.5.5.jar
spring-webmvc-2.5.5.jar
spring-webmvc-struts-2.5.5.jar
standard-1.0.6.jar
struts-1.2.9.jar
validation-1.7.0.jar
vecmath-1.3.1.jar
velocity-1.4.jar
velocity-dep-1.4.jar
wcs-1.7.0.jar
wcs1_1-1.7.0.jar
wfs-1.7.0.jar
wfs11-1.7.0.jar
wms-1.7.0.jar
xalan-2.7.0.jar
xercesImpl-2.4.0.jar
xml-apis-1.0.b2.jar
xml-apis-xerces-2.7.1.jar
xpp3-1.1.3.4.O.jar
xpp3_min-1.1.4c.jar
xsd-2.2.2.jar
xstream-1.3.jar
On Nov 21, 2008, at 8:19 AM, Justin Deoliveira wrote:
Hi Seth,
-Justin
Hi Justin -
-Data
-editArea
-gmaps
-images
-index.jsp
-meta-inf
-openlayers
-popup_map
-rss
-schemas
-style.css
-WEB-INF
-Seth
Hi Seth,
So yeah, definitely an issue with the unpacking then. I don’t know of any issues with the tomcat manager, but what i usually do myself is just copy the war into the webapps folder and let tomcat auto deploy it for me. But i guess this only works if you have access to the server file system.
Another thing that might be prudent before trying to redeploy is removing the geoserver “work” directory. /work/Catalina/localhost/geoserver
-Justin
Thanks-
Seth
Hi Seth,
The class that can not be found is the first thing loaded by GeoServer… so this would indicate to me that the installation is somehow corrupt.
Has the war been fully unpacked? IE. Does the directory /webapps/geoserver exist? Also verify that the directory webapps/geoserver/WEB-INF/lib contains a file web-1.7.0.jar.
Hi-
I’ve tried everything I can think of to make sure that tomcat is looking in the right place and that geoserver has the correct permissions, but I’m basing that on the war-file install instructions in the User guide.
Any suggestions as to what I’m doing wrong?
Thanks-
Seth
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
http://moblin-contest.org/redirect.php?banner_id=100&url=/_______________________________________________
Was there ever an answer to this? Is the answer to use Tomcat 5.5 instead of
6?
Hi again-
Thanks again-
Seth
Hi Justin -
I can't post the .zip file anywhere it's accessible (I'm behind a
attachment stripped (same deal), so I've attached a .rtf of the WEB-
Thanks-
Seth
<geoserver WEB-inf directory.rtf>
activation-1.1.jar
antlr-2.7.2.jar
aopalliance-1.0.jar
batik-css-1.6.jar
batik-dom-1.6.jar
batik-ext-1.6.jar
batik-gvt-1.6.jar
batik-util-1.6.jar
batik-xml-1.6.jar
common-2.2.1.jar
data-1.7.0.jar
easymock-2.3.jar
ecore-2.2.2.jar
ezmorph-1.0.3.jar
gt-api-2.5.1.jar
gt-cql-2.5.1.jar
gt-data-2.5.1.jar
gt-graph-2.5.1.jar
gt-image-2.5.1.jar
gt-jdbc-2.5.1.jar
gt-main-2.5.1.jar
gt-render-2.5.1.jar
gt-wfs-2.5.1.jar
gt-wms-2.5.1.jar
gt-xml-2.5.1.jar
hsqldb-1.8.0.7.jar
itext-2.0.6.jar
jai_codec-1.1.3.jar
jai_core-1.1.3.jar
jai_imageio-1.1.jar
jdom-1.0.jar
jstl-1.0.6.jar
jts-1.9.jar
log4j-1.2.14.jar
lucene-1.4.3.jar
mail-1.4.jar
main-1.7.0.jar
oro-2.0.8.jar
ows-1.7.0-tests.jar
ows-1.7.0.jar
platform-1.7.0.jar
spring-tx-2.5.5.jar
standard-1.0.6.jar
struts-1.2.9.jar
vecmath-1.3.1.jar
velocity-1.4.jar
wcs-1.7.0.jar
wcs1_1-1.7.0.jar
wfs-1.7.0.jar
wfs11-1.7.0.jar
wms-1.7.0.jar
xalan-2.7.0.jar
xml-apis-1.0.b2.jar
xpp3-1.1.3.4.O.jar
xpp3_min-1.1.4c.jar
xsd-2.2.2.jar
xstream-1.3.jar
Hi Seth,
-Justin
Hi Justin -
-Data
-editArea
-gmaps
-images
-index.jsp
-meta-inf
-openlayers
-popup_map
-rss
-schemas
-style.css
-WEB-INF
-Seth
Hi Seth,
is.
localhost/geoserver
-Justin
Thanks-
Seth
Hi Seth,
web-1.7.0.jar.
Hi-
Thanks-
Seth
win great prizes
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
challenge
great prizes
the world
challenge
prizes
world
View this message in context: http://www.nabble.com/Deploying-geoserver-1.7-war-in-Tomcat-(Mac-OSX-10.5)-tp20570282p21489493.html
I was never able to reproduce the problem. I have successfully deployed GeoServer in tomcat 6, and I know others have too. Are you seeing the same issue?
If so, the only other thing I can think of is if one of you made your unpacked web application available to me. Ie. zipping up webapps/geoserver and putting it somewhere i can get at it.
-Justin
6?
Hi again-
Thanks again-
Seth
Hi Justin -
I can't post the .zip file anywhere it's accessible (I'm behind a firewall) and it looks like the last email I sent got the .zip attachment stripped (same deal), so I've attached a .rtf of the WEB- INF/lib directory and included the list below as well.
Thanks-
Seth
activation-1.1.jar
antlr-2.7.2.jar
aopalliance-1.0.jar
batik-css-1.6.jar
batik-dom-1.6.jar
batik-ext-1.6.jar
batik-gvt-1.6.jar
batik-util-1.6.jar
batik-xml-1.6.jar
common-2.2.1.jar
data-1.7.0.jar
easymock-2.3.jar
ecore-2.2.2.jar
ezmorph-1.0.3.jar
gt-api-2.5.1.jar
gt-cql-2.5.1.jar
gt-data-2.5.1.jar
gt-graph-2.5.1.jar
gt-image-2.5.1.jar
gt-jdbc-2.5.1.jar
gt-main-2.5.1.jar
gt-render-2.5.1.jar
gt-wfs-2.5.1.jar
gt-wms-2.5.1.jar
gt-xml-2.5.1.jar
hsqldb-1.8.0.7.jar
itext-2.0.6.jar
jai_codec-1.1.3.jar
jai_core-1.1.3.jar
jai_imageio-1.1.jar
jdom-1.0.jar
jstl-1.0.6.jar
jts-1.9.jar
log4j-1.2.14.jar
lucene-1.4.3.jar
mail-1.4.jar
main-1.7.0.jar
oro-2.0.8.jar
ows-1.7.0-tests.jar
ows-1.7.0.jar
platform-1.7.0.jar
spring-tx-2.5.5.jar
standard-1.0.6.jar
struts-1.2.9.jar
vecmath-1.3.1.jar
velocity-1.4.jar
wcs-1.7.0.jar
wcs1_1-1.7.0.jar
wfs-1.7.0.jar
wfs11-1.7.0.jar
wms-1.7.0.jar
xalan-2.7.0.jar
xml-apis-1.0.b2.jar
xpp3-1.1.3.4.O.jar
xpp3_min-1.1.4c.jar
xsd-2.2.2.jar
xstream-1.3.jar
Hi Seth,
-Justin
Hi Justin -
-Data
-editArea
-gmaps
-images
-index.jsp
-meta-inf
-openlayers
-popup_map
-rss
-schemas
-style.css
-WEB-INF
-Seth
Hi Seth,
Another thing that might be prudent before trying to redeploy is removing the geoserver "work" directory. <tomcat>/work/Catalina/ localhost/geoserver
-Justin
Thanks-
Seth
Hi Seth,
Hi-
Thanks-
Seth
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
http://moblin-contest.org/redirect.php?banner_id=100&url=/ _______________________________________________
challenge
prizes
world
Justin Deoliveira
Thanks Justin, fyi I am using Windows Server 2008 (vista) with Apache 2.2 and
Tomcat 6, but I am having the same problem described in this thread (not
unpacking correctly).
Here is the unpacked geoserver
http://mapserver.drcog.org/website/geoserver_root.zip
Thanks!
Mike
same issue?
-Justin
of
6?
Hi again-
Thanks again-
Seth
Hi Justin -
Thanks-
Seth
activation-1.1.jar
antlr-2.7.2.jar
aopalliance-1.0.jar
batik-css-1.6.jar
batik-dom-1.6.jar
batik-ext-1.6.jar
batik-gvt-1.6.jar
batik-util-1.6.jar
batik-xml-1.6.jar
common-2.2.1.jar
data-1.7.0.jar
easymock-2.3.jar
ecore-2.2.2.jar
ezmorph-1.0.3.jar
gt-api-2.5.1.jar
gt-cql-2.5.1.jar
gt-data-2.5.1.jar
gt-graph-2.5.1.jar
gt-image-2.5.1.jar
gt-jdbc-2.5.1.jar
gt-main-2.5.1.jar
gt-render-2.5.1.jar
gt-wfs-2.5.1.jar
gt-wms-2.5.1.jar
gt-xml-2.5.1.jar
hsqldb-1.8.0.7.jar
itext-2.0.6.jar
jai_codec-1.1.3.jar
jai_core-1.1.3.jar
jai_imageio-1.1.jar
jdom-1.0.jar
jstl-1.0.6.jar
jts-1.9.jar
log4j-1.2.14.jar
lucene-1.4.3.jar
mail-1.4.jar
main-1.7.0.jar
oro-2.0.8.jar
ows-1.7.0-tests.jar
ows-1.7.0.jar
platform-1.7.0.jar
spring-tx-2.5.5.jar
standard-1.0.6.jar
struts-1.2.9.jar
vecmath-1.3.1.jar
velocity-1.4.jar
wcs-1.7.0.jar
wcs1_1-1.7.0.jar
wfs-1.7.0.jar
wfs11-1.7.0.jar
wms-1.7.0.jar
xalan-2.7.0.jar
xml-apis-1.0.b2.jar
xpp3-1.1.3.4.O.jar
xpp3_min-1.1.4c.jar
xsd-2.2.2.jar
xstream-1.3.jar
Hi Seth,
-Justin
Hi Justin -
-Data
-editArea
-gmaps
-images
-index.jsp
-meta-inf
-openlayers
-popup_map
-rss
-schemas
-style.css
-WEB-INF
-Seth
Hi Seth,
is.
localhost/geoserver
-Justin
Thanks-
Seth
Hi Seth,
web-1.7.0.jar.
Hi-
Thanks-
Seth
win great prizes
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
challenge
great prizes
the world
challenge
prizes
world
Justin Deoliveira
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
View this message in context: http://www.nabble.com/Deploying-geoserver-1.7-war-in-Tomcat-(Mac-OSX-10.5)-tp20570282p21502807.html
Hi Mike,
Thanks for posting this for me. However the archive seems to be flat... i was hoping to keep the file system structure in tact so I could simply drop it into my tomcat webapps directory.
I have never used Vista, i know on xp you can just send a folder to a compressed archive or whatever...
-Justin
Thanks!
Mike
-Justin
of
6?
Hi again-
Thanks again-
Seth
Hi Justin -
Thanks-
Seth
activation-1.1.jar
antlr-2.7.2.jar
aopalliance-1.0.jar
batik-css-1.6.jar
batik-dom-1.6.jar
batik-ext-1.6.jar
batik-gvt-1.6.jar
batik-util-1.6.jar
batik-xml-1.6.jar
common-2.2.1.jar
data-1.7.0.jar
easymock-2.3.jar
ecore-2.2.2.jar
ezmorph-1.0.3.jar
gt-api-2.5.1.jar
gt-cql-2.5.1.jar
gt-data-2.5.1.jar
gt-graph-2.5.1.jar
gt-image-2.5.1.jar
gt-jdbc-2.5.1.jar
gt-main-2.5.1.jar
gt-render-2.5.1.jar
gt-wfs-2.5.1.jar
gt-wms-2.5.1.jar
gt-xml-2.5.1.jar
hsqldb-1.8.0.7.jar
itext-2.0.6.jar
jai_codec-1.1.3.jar
jai_core-1.1.3.jar
jai_imageio-1.1.jar
jdom-1.0.jar
jstl-1.0.6.jar
jts-1.9.jar
log4j-1.2.14.jar
lucene-1.4.3.jar
mail-1.4.jar
main-1.7.0.jar
oro-2.0.8.jar
ows-1.7.0-tests.jar
ows-1.7.0.jar
platform-1.7.0.jar
spring-tx-2.5.5.jar
standard-1.0.6.jar
struts-1.2.9.jar
vecmath-1.3.1.jar
velocity-1.4.jar
wcs-1.7.0.jar
wcs1_1-1.7.0.jar
wfs-1.7.0.jar
wfs11-1.7.0.jar
wms-1.7.0.jar
xalan-2.7.0.jar
xml-apis-1.0.b2.jar
xpp3-1.1.3.4.O.jar
xpp3_min-1.1.4c.jar
xsd-2.2.2.jar
xstream-1.3.jar
Hi Seth,
-Justin
Hi Justin -
-Data
-editArea
-gmaps
-images
-index.jsp
-meta-inf
-openlayers
-popup_map
-rss
-schemas
-style.css
-WEB-INF
-Seth
Hi Seth,
-Justin
Thanks-
Seth
Hi Seth,
Hi-
Thanks-
Seth
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
challenge
prizes
world
Justin Deoliveira
Justin Deoliveira
Hi Michael,
So i tried the latest zip file you gave me with tomcat 6.0.18 on both mac os and windows, and no problems with either... so i am not sure where things are going wrong.
Could you include the tomcat start up log?
Michael Tafel wrote:
Sorry about that Justin, I extracted this one and it maintained the
folder structure. Thanks!
http://mapserver.drcog.org/website/geoserver.zip
Mike
Michael Tafel| GIS Specialist| Denver Regional Council of Governments|
303.480.6797|1290 Broadway Suite 700 Denver, CO 80203
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Friday, January 16, 2009 10:26 AM
To: Michael Tafel
Subject: Re: [Geoserver-users] Deploying geoserver 1.7 war in Tomcat
(Mac OSX 10.5)
Hi Mike,
-Justin
2.2 and
(not
Thanks!
Mike
deployed
same issue?
-Justin
instead
of
6?
Hi again-
how
Thanks again-
Seth
Hi Justin -
WEB-
Thanks-
Seth
activation-1.1.jar
antlr-2.7.2.jar
aopalliance-1.0.jar
batik-css-1.6.jar
batik-dom-1.6.jar
batik-ext-1.6.jar
batik-gvt-1.6.jar
batik-util-1.6.jar
batik-xml-1.6.jar
common-2.2.1.jar
data-1.7.0.jar
easymock-2.3.jar
ecore-2.2.2.jar
ezmorph-1.0.3.jar
gt-api-2.5.1.jar
gt-cql-2.5.1.jar
gt-data-2.5.1.jar
gt-graph-2.5.1.jar
gt-image-2.5.1.jar
gt-jdbc-2.5.1.jar
gt-main-2.5.1.jar
gt-render-2.5.1.jar
gt-wfs-2.5.1.jar
gt-wms-2.5.1.jar
gt-xml-2.5.1.jar
hsqldb-1.8.0.7.jar
itext-2.0.6.jar
jai_codec-1.1.3.jar
jai_core-1.1.3.jar
jai_imageio-1.1.jar
jdom-1.0.jar
jstl-1.0.6.jar
jts-1.9.jar
log4j-1.2.14.jar
lucene-1.4.3.jar
mail-1.4.jar
main-1.7.0.jar
oro-2.0.8.jar
ows-1.7.0-tests.jar
ows-1.7.0.jar
platform-1.7.0.jar
spring-tx-2.5.5.jar
standard-1.0.6.jar
struts-1.2.9.jar
vecmath-1.3.1.jar
velocity-1.4.jar
wcs-1.7.0.jar
wcs1_1-1.7.0.jar
wfs-1.7.0.jar
wfs11-1.7.0.jar
wms-1.7.0.jar
xalan-2.7.0.jar
xml-apis-1.0.b2.jar
xpp3-1.1.3.4.O.jar
xpp3_min-1.1.4c.jar
xsd-2.2.2.jar
xstream-1.3.jar
Hi Seth,
-Justin
Hi Justin -
-Data
-editArea
-gmaps
-images
-index.jsp
-meta-inf
-openlayers
-popup_map
-rss
-schemas
-style.css
-WEB-INF
-Seth
Hi Seth,
you
issue
is.
is
localhost/geoserver
-Justin
Thanks-
Seth
Hi Seth,
Hi-
tomcat
Thanks-
Seth
win great prizes
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
challenge
the world
challenge
great
prizes
the
world
Justin Deoliveira
Justin Deoliveira
Here are the Tomcat logs,
the url should just be http://localhost/geoserver (i want to run it
through the same port as the apache webserver)
When I do http://localhost:8080/geoserver (tomcat's port)I get the
geoserver loading please wait 0% completed page but it stays at 0%
completed.
Sent: Friday, January 16, 2009 1:52 PM
To: Michael Tafel; geoserver-users
(Mac OSX 10.5)
Hi Michael,
Mike
To: Michael Tafel
(Mac OSX 10.5)
Hi Mike,
flat...
simply
-Justin
2.2 and
(not
Thanks!
Mike
deployed
the
same issue?
your
-Justin
instead
of
6?
Hi again-
6
how
Thanks again-
Seth
Hi Justin -
WEB-
Thanks-
Seth
activation-1.1.jar
antlr-2.7.2.jar
aopalliance-1.0.jar
batik-css-1.6.jar
batik-dom-1.6.jar
batik-ext-1.6.jar
batik-gvt-1.6.jar
batik-util-1.6.jar
batik-xml-1.6.jar
common-2.2.1.jar
data-1.7.0.jar
easymock-2.3.jar
ecore-2.2.2.jar
ezmorph-1.0.3.jar
gt-api-2.5.1.jar
gt-cql-2.5.1.jar
gt-data-2.5.1.jar
gt-graph-2.5.1.jar
gt-image-2.5.1.jar
gt-jdbc-2.5.1.jar
gt-main-2.5.1.jar
gt-render-2.5.1.jar
gt-wfs-2.5.1.jar
gt-wms-2.5.1.jar
gt-xml-2.5.1.jar
hsqldb-1.8.0.7.jar
itext-2.0.6.jar
jai_codec-1.1.3.jar
jai_core-1.1.3.jar
jai_imageio-1.1.jar
jdom-1.0.jar
jstl-1.0.6.jar
jts-1.9.jar
log4j-1.2.14.jar
lucene-1.4.3.jar
mail-1.4.jar
main-1.7.0.jar
oro-2.0.8.jar
ows-1.7.0-tests.jar
ows-1.7.0.jar
platform-1.7.0.jar
spring-tx-2.5.5.jar
standard-1.0.6.jar
struts-1.2.9.jar
vecmath-1.3.1.jar
velocity-1.4.jar
wcs-1.7.0.jar
wcs1_1-1.7.0.jar
wfs-1.7.0.jar
wfs11-1.7.0.jar
wms-1.7.0.jar
xalan-2.7.0.jar
xml-apis-1.0.b2.jar
xpp3-1.1.3.4.O.jar
xpp3_min-1.1.4c.jar
xsd-2.2.2.jar
xstream-1.3.jar
Hi Seth,
-Justin
Hi Justin -
-Data
-editArea
-gmaps
-images
-index.jsp
-meta-inf
-openlayers
-popup_map
-rss
-schemas
-style.css
-WEB-INF
-Seth
Hi Seth,
you
issue
is.
is
localhost/geoserver
-Justin
Thanks-
Seth
Hi Seth,
web-1.7.0.jar.
Hi-
tomcat
Thanks-
Seth
win great prizes
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
Developer's
challenge
great prizes
the world
challenge
great
prizes
the
world
Justin Deoliveira
Justin Deoliveira
stdout_20090116.log (16.5 KB)
jakarta_service_20090115.log (3.86 KB)
jakarta_service_20090116.log (209 Bytes)
localhost.2009-01-16.log (3.24 KB)
(Attachment manager.2009-01-16.log is missing)
(Attachment stderr_20090116.log is missing)
stdout_20090115.log (53.6 KB)
Got it up and running! The problem wasn't tomcat or geoserver but my
apache configuration with tomcat. Anyways I have geoserver 1.7.1 running
on tomcat 6 via apache 2.2 on Windows Server 2008 (vista)
Thanks for the help!
Mike
(Mac OSX 10.5)
Hi Michael,
Mike
To: Michael Tafel
(Mac OSX 10.5)
Hi Mike,
flat...
simply
-Justin
2.2 and
(not
Thanks!
Mike
deployed
the
same issue?
your
-Justin
instead
of
6?
Hi again-
6
how
Thanks again-
Seth
Hi Justin -
WEB-
Thanks-
Seth
activation-1.1.jar
antlr-2.7.2.jar
aopalliance-1.0.jar
batik-css-1.6.jar
batik-dom-1.6.jar
batik-ext-1.6.jar
batik-gvt-1.6.jar
batik-util-1.6.jar
batik-xml-1.6.jar
common-2.2.1.jar
data-1.7.0.jar
easymock-2.3.jar
ecore-2.2.2.jar
ezmorph-1.0.3.jar
gt-api-2.5.1.jar
gt-cql-2.5.1.jar
gt-data-2.5.1.jar
gt-graph-2.5.1.jar
gt-image-2.5.1.jar
gt-jdbc-2.5.1.jar
gt-main-2.5.1.jar
gt-render-2.5.1.jar
gt-wfs-2.5.1.jar
gt-wms-2.5.1.jar
gt-xml-2.5.1.jar
hsqldb-1.8.0.7.jar
itext-2.0.6.jar
jai_codec-1.1.3.jar
jai_core-1.1.3.jar
jai_imageio-1.1.jar
jdom-1.0.jar
jstl-1.0.6.jar
jts-1.9.jar
log4j-1.2.14.jar
lucene-1.4.3.jar
mail-1.4.jar
main-1.7.0.jar
oro-2.0.8.jar
ows-1.7.0-tests.jar
ows-1.7.0.jar
platform-1.7.0.jar
spring-tx-2.5.5.jar
standard-1.0.6.jar
struts-1.2.9.jar
vecmath-1.3.1.jar
velocity-1.4.jar
wcs-1.7.0.jar
wcs1_1-1.7.0.jar
wfs-1.7.0.jar
wfs11-1.7.0.jar
wms-1.7.0.jar
xalan-2.7.0.jar
xml-apis-1.0.b2.jar
xpp3-1.1.3.4.O.jar
xpp3_min-1.1.4c.jar
xsd-2.2.2.jar
xstream-1.3.jar
Hi Seth,
-Justin
Hi Justin -
-Data
-editArea
-gmaps
-images
-index.jsp
-meta-inf
-openlayers
-popup_map
-rss
-schemas
-style.css
-WEB-INF
-Seth
Hi Seth,
you
issue
is.
is
localhost/geoserver
-Justin
Thanks-
Seth
Hi Seth,
web-1.7.0.jar.
Hi-
tomcat
Thanks-
Seth
win great prizes
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
Developer's
challenge
great prizes
the world
challenge
great
prizes
the
world
Justin Deoliveira
Justin Deoliveira
running
Hi Mike,
Could u leave here some apache2.2/tomcat6 configuration details?
Pedro Mendes
Also, can you mention the advantages of using this on WS2008 vs the standard Jetty install? I'm new to running Java services like this.
Roger
Sent: Thursday, January 22, 2009 11:05 AM
To: "'Michael Tafel'" <MTafel@anonymised.com>; "'geoserver-users'" <geoserver-users@lists.sourceforge.net>
Subject: Re: [Geoserver-users] Deploying geoserver 1.7 war in Tomcat(Mac OSX 10.5)
running
Hi Mike,
Pedro Mendes
