[Geoserver-users] Deploying Geoserver 2.3.x on Websphere 8
All,
As I have not seen much activity on this particular topic. I am wondering whether we were able to successfully deploy Geoserver on this particular platform. Is there any documentation available?
On Jun 22, 2013, at 10:29 AM, geoserver-users-request@lists.sourceforge.net wrote:
Send Geoserver-users mailing list submissions to
   geoserver-users@lists.sourceforge.net
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
   geoserver-users-owner@lists.sourceforge.net
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Geoserver-users digest..."
Today's Topics:
  1. Re: Cannot map LDAP groups to GeoServer roles (Mauro Bartolomeoli)
  2. Re: Cannot map LDAP groups to GeoServer roles (Andrea Aime)
  3. Re: Cannot map LDAP groups to GeoServer roles (Justin Deoliveira)
Message: 1
Date: Sat, 22 Jun 2013 14:57:21 +0200
From: Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com>
Subject: Re: [Geoserver-users] Cannot map LDAP groups to GeoServer
   roles
To: Andrea Aime <andrea.aime@anonymised.com>
Cc: Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com>,
   GeoServer Mailing List List <geoserver-users@lists.sourceforge.net>
Message-ID:
   <CADQU8v1bOhbne8cVcW-moEwS90SM_pmCwycEfAejQesq9zQRzg@anonymised.com>
Content-Type: text/plain; charset="iso-8859-1"
2013/6/22 Andrea Aime <andrea.aime@anonymised.com>
On Thu, Jun 20, 2013 at 8:50 AM, Mauro Bartolomeoli <
mauro.bartolomeoli@anonymised.com> wrote:
Yes, but what I exactly mean is that the Geoserver LDAP module,
internally, does two things:
1) login to the LDAP server with the user credentials to authenticate it
(and this seems to be working for you) and then logs out from the LDAP
server (it only logins to check the user is authenticated)
2) retrieve user groups with an anonymous search, without making a new
login to the LDAP server with user credentials. Many LDAP servers deny the
search to anonymous users and so no groups are retrieved, also if the user
is correctly authenticated
Ah, really? This seems a bit dumb... would it be hard to make it
authenticate also on the second request?
If we have a user, why not use it, is there some particular setup where
that would cause issues?
Yes, sure, and this is already done with GEOS-5805 on master (using the new
option bindBeforeGroupSearch), but that enhancement has not been backported
to 2.3.x yet (by the way, I was thinking to backport it, after 2.3.3 is
out, what do you think about that?).
Mauro
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
Message: 2
Date: Sat, 22 Jun 2013 15:06:01 +0200
   roles
To: Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com>, Justin
   Deoliveira <jdeolive@anonymised.com>
Cc: GeoServer Mailing List List
Message-ID:
   <CA+nxMTubXh=fT4zqKO9u0xd+SAjrgG3XjQexnGAazmSmQqUh0A@anonymised.com>
On Sat, Jun 22, 2013 at 2:57 PM, Mauro Bartolomeoli <
it (and this seems to be working for you) and then logs out from the LDAP
new option bindBeforeGroupSearch), but that enhancement has not been
backported to 2.3.x yet (by the way, I was thinking to backport it, after
2.3.3 is out, what do you think about that?).
Sounds reasonable to me, but I'm not too familiar with the LDAP code, we
should hear from Justin
too, and ask on the geoserver-devel list just to make sure.
Afaik you have been using the GEOS-5805 results on the stable series
already (in a pre-production
environment? or was it production?) and it's working fine, right?
information.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Message: 3
Date: Sat, 22 Jun 2013 08:29:17 -0600
   roles
Message-ID:
   <CAEwWEk0=GgRohQOQWX7pC=Nz0k5y9zZm351hyMcQH8zNow52Tg@anonymised.com>
On Sat, Jun 22, 2013 at 7:06 AM, Andrea Aime
All for the backport. The ldap code pre the changes was mauro wasn't
exactly rock solid :slight_smile: I think these changes make it much more useful. +1
and great work Mauro.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
OpenGeo - http://opengeo.org
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
End of Geoserver-users Digest, Vol 85, Issue 90
Some time ago, I used Websphere 7 for GeoServer deployment. It worked for me.
The risk is that Websphere uses an IBM SDK. Now I use an IBM SDK & Tomcat 6 combination, works well.
Christian
2013/6/22 Sudheer Chadalavada <csudheer@anonymised.com>
All,
or, via email, send a message with subject or body ‘help’ to
than “Re: Contents of Geoserver-users digest…”
Today’s Topics:
Message: 1
roles
Message-ID:
<CADQU8v1bOhbne8cVcW-moEwS90SM_pmCwycEfAejQesq9zQRzg@anonymised.com.85…>
Content-Type: text/plain; charset=“iso-8859-1”
  1. login to the LDAP server with the user credentials to authenticate it
  2. retrieve user groups with an anonymous search, without making a new
Ah, really? This seems a bit dumb… would it be hard to make it
Mauro
information.
@mauro_bart
An HTML attachment was scrubbed…
Message: 2
roles
Deoliveira <jdeolive@…1671…>
Message-ID:
Sounds reasonable to me, but I’m not too familiar with the LDAP code, we
environment? or was it production?) and it’s working fine, right?
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Message: 3
roles
Message-ID:
All for the backport. The ldap code pre the changes was mauro wasn’t
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Thanks Christian. Though we were able to deploy application on Websphere8 noticed there are some issues with spring framework which resulted in not loading stores. Trying to troubleshoot and identify the issue. Will keep posted.
On Sat, Jun 22, 2013 at 11:33 AM, Sudheer Chadalavada <csudheer@anonymised.com> wrote:
All,
Today’s Topics:
Message: 1
roles
Message-ID:
Mauro
information.
@mauro_bart
Message: 2
roles
Message-ID:
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Message: 3
roles
Message-ID:
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
