Dear Friends,
I have geoserver deployed in tomcat Web container and i like to move the geoserver into JBOSS is it possible to deploy ‘geoserver folder’ directly to JBOSS??
I tried to deploy geoserver 2.5 war file under JBOSS 7.1.1 in windows XP, But when i try to enable it in JBoss management / deployment section following is the response am getting
and I also getting the following error in error console
Unknown error
Unexpected HTTP response: 500
Request
"address" => [("deployment" => "geoserver.war")],
"operation" => "deploy"
Response
Internal Server Error
"outcome" => "failed",
"failure-description" => {"JBAS014671: Failed services" => "jboss.deployment.unit.\"geoserver.war\".STRUCTURE" => "org.jboss.msc.service.StartException in service jboss.deployment.unit.\"geoserver.war\".STRUCTURE: Failed to process phase STRUCTURE of deployment \"geoserver.war\""}},
"rolled-back" => true
Looks like your deploy has failed, check the JBoss logs for more details. What you provided tends to indicate that it did not like the contents of our geoserver.war file, you may need to search for others that have had similar problems with jboss.
Dear Friends,
Unknown error
Request
Response
please help me
Anas A,
Palakkad | +917736368236
Is your legacy SCM system holding you back? Join Perforce May 7 to find out:
� 3 signs your SCM is hindering your productivity
� Requirements for releasing software faster
� Expert tips and advice for migrating your SCM now http://p.sf.net/sfu/perforce
