Hi Olivier,
Have a look at
http://docs.geoserver.org/stable/en/user/production/container.html
To fix the error you found you should increase PermGen space with parameter
-XX:MaxPermSize
I would set a 256mb or more
I would also increase heap space with
-Xmx2048M -Xms2048m
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
2013/3/26 Olivier Gagnon <mcnolii@anonymised.com>:
Stefano,
you are right. I found java.lang.OutOfMemoryError: PermGen space in
manager.log
I have a pretty good machine (16 g ram with i7 processor)
Where can I change these settings ? I unzip .war file and change what in
which file ?
Should I setup another tomcat in parallel ?
Thanks a lot
Date: Tue, 26 Mar 2013 20:44:04 +0100
Subject: Re: [Geoserver-users] Deploying GeoServer and Geonetwork on the
same Tomcat
To: mcnolii@anonymised.com
CC: geoserver-users@lists.sourceforge.net;
geonetwork-users@lists.sourceforge.net
I am just trying a guess, do you run tomcat with default startup parameters?
Both application are quite heavy and chances are you run out of memory with
default settings.
Did you find any error in tomcat's log?
Stefano
Il giorno 26/mar/2013 20:24, "Olivier Gagnon" <mcnolii@anonymised.com> ha
scritto:
Hi Group,
I'm trying to install geonetwork and geoserver on the same tomcat using
respective .war file.
If I install Geoserver first, it works like a charm but geonmetwork doesn't
work.
If I install Geonetwork first, it works like a charm but Geoserver doesn't
work ...
Thanks for any help on this
Own the Future-Intel® Level Up Game Demo Contest 2013
Rise to greatness in Intel's independent game demo contest.
Compete for recognition, cash, and the chance to get your game
on Steam. $5K grand prize plus 10 genre and skill prizes.
Submit your demo by 6/6/13. http://p.sf.net/sfu/intel_levelupd2d
Geoserver-users mailing list
