I was discussing with someone recently in the jvn mobile gis group and the person told me that the wms specs includes a describe feature request. This request returns an XML encoding of the attribute data of a feature. Does Geoserver support this feature ? if it does how can i use it ?
Roman
This is not completely true/right.
SLD WMS contains a request called DescribeLayer. Using DescribeLayer, you
can get the necessary info to create a WFS DescribeFeatureType request,
which will give back which attributes the feature has.
So (intranet urls, so just for reference):
http://145.50.148.45:8082/geoserver/wms?service=WMS&request=DescribeLayer&layers=rwsagi:DIENSTEN_DROOG&version=1.1.1
and then:
http://145.50.148.45:8082/geoserver/wms?service=WFS&request=DescribeFeatureType&typename=rwsagi:DIENSTEN_DROOG&version=1.0.0
Best regards,
Bart
On Thu, 15 May 2008 01:45:03 -0700 (PDT), Roman Isitua
<romanisitua@anonymised.com> wrote:
request.
Roman
Roman Isitua ha scritto:
It's not part of the base WMS standard, but part of the WMS + SLD standard and called DescribeLayer, but in the end it will just give you
just a redirect to the WFS DescribeFeatureType call, that you can just
make that one directly. Of course, for this to work, WFS should be enabled as well.
For more details about DescribeLayer download the SLD 1.0 standard (not the 1.1) from www.opengeospatial.org, it should fill in the details.
For more information about the DescribeFeatureType WFS call, download
the WFS 1.0 standard from www.opengeospatial.org.
Btw, there are sample calls of both of them in the demo requests
section of GeoServer.
