Hi Gabriel,
the attribute is nillable, and I don't need to put anything in it. It's just
that ArcSDE tells me not to remove this column otherwise I would have done
that
I would be willing to try a jar out ofcourse. TIA.
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Gabriel Roldán <groldan@anonymised.com>
Naar: geoserver-users@lists.sourceforge.net
<geoserver-users@lists.sourceforge.net>
Cc: Andrea Aime <aaime@anonymised.com>, Bart van den Eijnden OSGIS
<bartvde@anonymised.com>, Saul Farber <Saul.Farber@anonymised.com>
Onderwerp: Re: [Geoserver-users] DescribeFeatureType problem
Datum: 23/01/08 08:53
Hi Bart, sorry for the late response
the best I can think of to enable you using the table is to try a
workaround
like ignoring this kind of columns in the geotools arcsde plugin as long
as
they're nillable.
I could try that and send you a jar to try out. You don't need to set a
value
for that column through WFS-T, right? if so would ignoring that column
would
be enough for your needs?
Otherwise we should need to actually support blobs at arcsde (which is
there
but never actually tried it), and which could be more complicated, on the
WFS
side of the fence. That won't happen in the very near future though except
through some funded work or code donation, due to other higher priority
concerns.Would you be willing to try out an arcsde jar with that workaround so?
Gabriel
On Wednesday 23 January 2008 10:19:51 am Andrea Aime wrote:
> Bart van den Eijnden (OSGIS) ha scritto:
> > Hi Andrea,
> > the table is still empty, we are trying to use WFS-T to fill it
but
> > without success right now. So I can't do a GetFeature as yet
> > For reference:
http://support.esri.com/index.cfm?fa=knowledgebase.techArticles.articleSh
> >ow&d=21938
> Hum, not sure we could do anything good with this kind of
> column... maybe it would be wiser to hide it at the datastore
> level? Doing WFS-T on it may be problematic thought, is ArcSDE
> able to fill in a default value if we don't provide one?
> ArcSDE gurus needed here.
> Cheers
> Andrea
> This SF.net email is sponsored by: Microsoft
> Defy all challenges. Microsoft(R) Visual Studio 2008.
> http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
> Geoserver-users mailing list
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
> !DSPAM:4045,479706d0282871804284693!
