[Geoserver-users] DescribeLayer response: version attribute
Hi list,
why is a DescribeLayer response by Geoserver using value 1.0.0 for the
version attribute, and not 1.1.1?
Example request:
http://145.50.148.45:8082/geoserver/wms?LAYERS=rwsagi:BKN_TESTDATA.VWATER&FORMAT=image/gif&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer&STYLES=&EXCEPTIONS=application/vnd.ogc.se_inimage&SRS=EPSG:28992
Example response (part of it):
<WMS_DescribeLayerResponse version="1.0.0">
Ofcourse 1.0.0 is the SLD version, but IIRC according to the spec the
version should be the WMS version number.
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
http://www.osgis.nl
Bart van den Eijnden (OSGIS) ha scritto:
Hi list,
Example request:
Hum, I could not find any statement regarding about what the version number should be in the WMS_DescribeLayerVersion number, yet the only
sample response in the SLD spec is:
<!DOCTYPE WMS_DescribeLayerResponse
SYSTEM "http://some.site.com/sld/DSR.dtd&quot; >
<WMS_DescribeLayerResponse version="1.1.0" >
<!-- 'Layer_A' comes from the wfs specified by
the prefix "http://www.mywfs.com/WFS?&quot; and has features
of types 'Road_FT' and 'Route_FT' -->
<LayerDescription name="Layer_A"
wfs="http://www.mywfs.com/WFS?&quot;&gt;
<Query typeName="Road_FT" />
<Query typeName="Route_FT" />
</LayerDescription>
<!-- 'Layer_B' cannot be described in terms of
a WFS and so has no wfs attribute and no contents -->
<LayerDescription name="Layer_B">
</LayerDescription>
</WMS_DescribeLayerResponse>
so it's quite likely you're correct, the version should be related
to the wms spec (when the SLD 1.0 spec was written wms 1.1.1 still
wasn't around afaik.
Can you open a jira issue about it?
Out of curiosity, is the current behaviour causing any trouble to you?
