[Geoserver-users] Different Labels using filter SLD
Hello everyone
I have a question! I have a rule for different classes of roads, and I need
labeling that classes with differents label rules. The routes under number
10 with a background shield , and routes above number 11 another shield.
I have this code:
<sld:TextSymbolizer>
            <sld:Label>
              <ogc:PropertyName>NumRuta</ogc:PropertyName>* ## I need filter
here?#*#
            </sld:Label>
            <sld:Font>
              <sld:CssParameter name="font-family">News Gothic
Bold</sld:CssParameter>
              <sld:CssParameter name="font-size">11</sld:CssParameter>
              <sld:CssParameter name="font-style">bold</sld:CssParameter>
              <sld:CssParameter name="font-weight">normal</sld:CssParameter>
            </sld:Font>
            <sld:LabelPlacement>
              <sld:PointPlacement>
               <Rotation>0</Rotation>
              </sld:PointPlacement>
            </sld:LabelPlacement>
            <sld:Fill>
              <sld:CssParameter name="fill">#323232</sld:CssParameter>
            </sld:Fill>
                  <sld:Graphic>
                    <sld:ExternalGraphic> <sld:OnlineResource
xlink:type="simple" xlink:href="background_security2.svg"
/><Format>image/svg+xml</Format>
                    </sld:ExternalGraphic>
                    <sld:Size>20</sld:Size>
                  </sld:Graphic>
            <VendorOption name="followLine">false</VendorOption>
            <VendorOption name="graphic-resize">proportional</VendorOption>
            <VendorOption name="graphic-margin">3</VendorOption>
            <VendorOption name="repeat">100</VendorOption>
            <VendorOption name="labelAllGroup">true</VendorOption>
          </sld:TextSymbolizer>
How use the filter option with labels
Thanks!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Different-Labels-using-filter-SLD-tp5332816.html
Hi Hanesa,
Yes, you need filter:
<ogc:Filter>
         <ogc:PropertyIsEqualTo>
           <ogc:PropertyName>..</ogc:PropertyName>
           <ogc:Literal></ogc:Literal>
         </ogc:PropertyIsEqualTo>
       </ogc:Filter>
You can find some examples here:
http://docs.geoserver.org/stable/en/user/styling/sld/cookbook/lines.html#attribute-based-line
View this message in context: http://osgeo-org.1560.x6.nabble.com/Different-Labels-using-filter-SLD-tp5332816p5332859.html
Hi
2017-08-29 3:07 GMT+03:00 Hahesa <harold.herreras@anonymised.com>:
Hello everyone
ogc:Filter usually goes straight into a Rule. If you have diferent
rules for different road classes, then you can add your label
symbolizers to the respective rules instead of creating a genereal
label-rule.
All the best,
Tõnis
@tkardi
skype: tonis.kardi
Thank you!
I try using filter in the Label Tag but the geoserver send me this
Imágenes integradas 1
Thanks for your help!
2017-08-29 1:03 GMT-06:00 imse [via OSGeo.org] <[hidden email]>:
Hi Hanesa,
ogc:Filter
ogc:PropertyName…</ogc:PropertyName>
ogc:Literal</ogc:Literal>
</ogc:Filter>
If you reply to this email, your message will be added to the discussion below:
To unsubscribe from Different Labels using filter SLD, click here.
NAML
Harold Herrera Sánchez
Teléfono: 2259-4242
Celular: 8831-3082
An ogc:Filter goes into the Rule tag (as is partly visible on your screenshot aswell), but you can try this as your label tag:
NumRuta 10 NumRuta This get's rendered as a lable if NumRuta >= 10
docs for filter functions: http://docs.geoserver.org/stable/en/user/filter/function_reference.html
btw a superhandy SLD cheat-sheet ftp://download.osgeo.org/osgeo/foss4g/2009/SPREP/1Wed/Parkside%20GO3/1300/SLDReferenceSheet.pdf
All the best,
Tõnis
2017-08-29 18:22 GMT+03:00 Hahesa <harold.herreras@anonymised.com>:
Thank you!
View this message in context: Re: Different Labels using filter SLD
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
Geoserver-users@anonymised.com.382…sourceforge.net
Hi Hanesa,
ogc:Filter
</ogc:Filter>
NAML
Teléfono: 2259-4242
Celular: 8831-3082
@tkardi
skype: tonis.kardi
I have the same issue, is it possible to use filters under Label tag??
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
No, as Tõnis says you need to use the filter in the rule not the label.
Ian
On 11 December 2017 at 07:06, ohadm <ohadm@anonymised.com> wrote:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ian Turton
