[Geoserver-users] Different map from geoserver/wms and gwc/service/wms
With the default settings on Geoserver 2.5 on Windows 7, jre7-64bit(Oracle) these two requests are returning a different map
http://localhost:8080/geoserver/gwc/service/wms?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&TRANSPARENT=TRUE&WIDTH=256&HEIGHT=256&FORMAT=image/png8&LAYERS=topp:states&SRS=EPSG:4326&bbox=-73.828125,41.50857729743935,-73.125,42.032974332441405
http://localhost:8080/geoserver/wms?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&TRANSPARENT=TRUE&WIDTH=256&HEIGHT=256&FORMAT=image/jpeg&LAYERS=topp:states&SRS=EPSG:4326&bbox=-73.828125,41.50857729743935,-73.125,42.032974332441405
See attached images geoserver-dispatch.image.png from the GWC-WMS and geoserver-wms.jpg from basic Geoserver-WMS.
Adding &TILED=TRUE does not change anything for me.
-Jukka Rahkonen-
Hi Jukka,
have a look at the http headers of the gwc image, it might tell you whether the returned bounds do match the requested 100%.
Is the request hitting a cached resolution exactly?
Best,
Marc
On 30. Mai 2014 13:30:40 MESZ, “Rahkonen Jukka (Tike)” jukka.rahkonen@anonymised.com wrote:
-Jukka Rahkonen-
Time is money. Stop wasting it! Get your web API in 5 minutes.
[www.restlet.com/download](http://www.restlet.com/download)
[http://p.sf.net/sfu/restlet](http://p.sf.net/sfu/restlet)
Geoserver-users mailing list
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Marc Jansen, terrestris GmbH & Co. KG
http://www.terrestris.de/
