[Geoserver-users] Dip and Strike SLD symbol Style for Geological Map
Hi All,
I’m making an interactive geological map in geoserver.
I can do the Color styling for Lithology and Normal Fault layer.
But how can I make symbols for Dip and Strike to show on the map?
I have a point layer with Dip angle and Strike direction in the attribute table.
ID | Dip | Strike
Have a nice day!
Mr. Khun San Aung
Hello, Khun.
You should be able to do this either in CSS or SLD styling.
Create a .png file with the dip symbol (|) in it (define the remainder of the .png as transparent)
If using CSS, use mark:symbol() to specify the .png as the marker shape.
Use mark-rotation to rotate the dip shape.
You would then define the label as the dip value and use label-rotate and label-offset, etc. to put the label in the right place and orientation.
Check these links out …
http://docs.geoserver.org/latest/en/user/extensions/css/cookbook/point.html#point-with-rotated-label
http://docs.geoserver.org/stable/en/user/styling/sld-extensions/pointsymbols.html
http://docs.geoserver.org/latest/en/user/extensions/css/index.html
http://docs.geoserver.org/latest/en/user/styling/index.html
​Regards,
David Collins
Geological Survey of New South Wales​
On Mon, May 18, 2015 at 3:35 PM, KhunSanAung <khunsanaung.gis@anonymised.com> wrote:
Hi All,
ID | Dip | Strike
1 | 60 | 240
I’d like to have symbols for Thrust Fault too.
Thank you very much in advanced.
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Geoserver-users mailing list
Have a nice day!
Mr. Khun San Aung
