[Geoserver-users] Direct GWC integration and CQL FILTER.... [SEC=UNOFFICIAL]
Hi!
I’m using GeoServer 2.4.4 (GeoWebCache v1.5.0).
I’m currently serving a layer of point (latitude/longitude) data from a PostGIS table and have enabled direct integration GWC caching. This all works a treat when no CQL filter is supplied…
My (generated) GWC layer configuration file is…
LayerInfoImpl-43ac45ed:143e39ae9ed:-7ffa
true
sentinel:hotspot_current
image/jpeg
image/png
EPSG:900913
EPSG:4326
4
4
STYLES
sentinel-legacy
0
Requesting a tile and looking at the result in FireBug gives me…
http://host:port/geoserver/blah/wms?LAYERS=blah_layer&TILED=true&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&FORMAT=image%2Fpng&SRS=EPSG%3A3857&BBOX=15028131.255,-5009377.085,17532819.7975,-2504688.5425&WIDTH=256&HEIGHT=256
Response Headers
Cache-Control
max-age=600
Content-Disposition
Content-Type
image/png
Date
Mon, 10 Feb 2014 02:53:22 GMT
Etag
8528c0ee4f3307e0a303a2949d671801
Last-Modified
Mon, 10 Feb 2014 02:52:53 GMT
Server
Apache-Coyote/1.1
Transfer-Encoding
chunked
geowebcache-cache-result
HIT
geowebcache-crs
EPSG:900913
geowebcache-gridset
EPSG:900913
geowebcache-layer
blah:blah_layer
geowebcache-tile-bounds
15028131.254999999,-5009377.085000001,17532819.797500003,-2504688.5425000004
geowebcache-tile-index
[14, 6, 4]
Beautiful.
If I then add a CQL FILTER to my request it, as expected, misses the cache due to the CQL FILTER…
http://host:port/geoserver/blah/wms?LAYERS=blah_layer&TILED=true&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&FORMAT=image%2Fpng&SRS=EPSG%3A3857&CQL_FILTER=a=‘a’&BBOX=15028131.255,-5009377.085,17532819.7975,-2504688.5425&WIDTH=256&HEIGHT=256
Response Headers
Cache-Control
max-age=600, must-revalidate
Content-Disposition
Content-Type
image/png
Date
Mon, 10 Feb 2014 02:57:59 GMT
Expires
Mon, 10 Feb 2014 03:07:59 GMT
Server
Apache-Coyote/1.1
Transfer-Encoding
chunked
MISS
geowebcache-miss-reason
no parameter filter exists for CQL_FILTER
So, I added a CQL FILTER parameter which added the following to my GWC layer configuration…
STYLES
sentinel-legacy
CQL_FILTER
But when I try my request again it now misses the cache complaining about the FILTER parameter…
Response Headers
Cache-Control
Content-Disposition
Content-Type
image/png
Date
Mon, 10 Feb 2014 03:08:53 GMT
Expires
Mon, 10 Feb 2014 03:18:53 GMT
Server
Apache-Coyote/1.1
Transfer-Encoding
chunked
MISS
no parameter filter exists for FILTER
If I similarly add a parameter for FILTER (even though I’m not explicitly sending it?) then my config file now gets…
STYLES
sentinel-legacy
FILTER
CQL_FILTER
But when I try my request again then I get an exception…
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
java.lang.NullPointerException
null
And in my geoserver log file….
2014-02-10 14:13:07,280 ERROR [geoserver.ows] -
at java.util.regex.Matcher.getTextLength(Matcher.java:1234)
at java.util.regex.Matcher.reset(Matcher.java:308)
at java.util.regex.Matcher.(Matcher.java:228)
at java.util.regex.Pattern.matcher(Pattern.java:1088)
at org.geowebcache.filter.parameters.RegexParameterFilter.getMatcher(RegexParameterFilter.java:49)
at org.geowebcache.filter.parameters.RegexParameterFilter.applies(RegexParameterFilter.java:87)
at org.geoserver.gwc.GWC.filterApplies(GWC.java:884)
at org.geoserver.gwc.GWC.isCachingPossible(GWC.java:823)
at org.geoserver.gwc.GWC.prepareRequest(GWC.java:647)
at org.geoserver.gwc.GWC.dispatch(GWC.java:631)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:83)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:54)
Any clues on what I am doing wrong?
Thanks heaps!
Simon Oldfield
National Earth Observation Group | Environmental Geoscience Division | GEOSCIENCE AUSTRALIA
__________________________________________________****__________
Phone: +61 2 6249 9589 Fax: +61 2 6249 9999
Email: Simon.Oldfield@anonymised.com Web: www.ga.gov.au
Cnr Jerrabomberra Avenue and Hindmarsh Drive Symonston ACT
GPO Box 378 Canberra ACT 2601 Australia
Applying geoscience to Australia’s most important challenges
Geoscience Australia Disclaimer: This e-mail (and files transmitted with it) is intended only for the person or entity to which it is addressed. If you are not the intended recipient, then you have received this e-mail by mistake and any use, dissemination, forwarding, printing or copying of this e-mail and its file attachments is prohibited. The security of emails transmitted cannot be guaranteed; by forwarding or replying to this email, you acknowledge and accept these risks.
