Dear all,
Can styling a WMS using a client-side SLD be disabled somehow? Been looking all over the interface and GeoServer data directory… We’re running GS 2.7.0. Many thanks for any pointers.
Kind regards,
Edward
Dear all,
Kind regards,
Edward
On Sun, Jun 14, 2015 at 9:11 PM, Edward Mac Gillavry <
emacgillavry@anonymised.com> wrote:
Dear all,
looking all over the interface and GeoServer data directory... We're
No, it is currently not possible, but we have plans to implement something
more "general", that is, the ability
for the admin to disable any style other than the ones configured for that
layer (so, also including
disallowing usage of another server side style, not associated to that
layer), likely in time for 2.8.0
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The more ‘general’ solution you describe suits our use case. Looking forward to 2.8.0!
Edward
Date: Sun, 14 Jun 2015 21:46:09 +0200
Subject: Re: [Geoserver-users] Disable client-side SLDs
To: emacgillavry@anonymised.com
CC: geoserver-users@lists.sourceforge.net
On Sun, Jun 14, 2015 at 9:11 PM, Edward Mac Gillavry <emacgillavry@anonymised.com> wrote:
Dear all,
No, it is currently not possible, but we have plans to implement something more “general”, that is, the ability
for the admin to disable any style other than the ones configured for that layer (so, also including
disallowing usage of another server side style, not associated to that layer), likely in time for 2.8.0
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Edward
AFAIK client side SLD uses a HTTP POST Request. I think it is possible to add a specific security filter chain and disable the POST request.
Christian
On Mon, Jun 15, 2015 at 8:29 AM, Edward Mac Gillavry <emacgillavry@anonymised.com> wrote:
Edward
CC: geoserver-users@lists.sourceforge.netOn Sun, Jun 14, 2015 at 9:11 PM, Edward Mac Gillavry <emacgillavry@anonymised.com> wrote:
Dear all,
disallowing usage of another server side style, not associated to that layer), likely in time for 2.8.0Cheers
Andrea–
http://goo.gl/it488V for more information.Ing. Andrea Aime
@geowolf
Technical LeadGeoSolutions S.A.S.
mob: +39 339 8844549http://www.geo-solutions.it
http://twitter.com/geosolutions_itAVVERTENZE AI SENSI DEL D.Lgs. 196/2003
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
On Mon, Jun 15, 2015 at 11:13 AM, Christian Mueller <
christian.mueller@anonymised.com> wrote:
Hi Edward
You can also pass a "&sld=http://url/to/your/sld" in a GET request, and
stand up a HTTP server that will give
GeoServer the SLD you desired.
Has been used quite a bit by people standing up a front/side application
that does statistics over data to
create dynamic thematic maps.
Ing. Andrea Aime
@geowolf
Technical Lead
Ups, forgot about the sld URL Parameter.
Mauro started a thread on the mailing list concerning url parameters and filter chains.
http://sourceforge.net/p/geoserver/mailman/message/34204840/
Maybe this could be a solution, but the proposed “general solution” sounds better.
Christian
On Mon, Jun 15, 2015 at 11:16 AM, Andrea Aime <andrea.aime@anonymised.com1107…> wrote:
On Mon, Jun 15, 2015 at 11:13 AM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi Edward
You can also pass a “&sld=http://url/to/your/sld” in a GET request, and stand up a HTTP server that will give
Has been used quite a bit by people standing up a front/side application that does statistics over data to
Ing. Andrea Aime
@geowolf
Technical Lead
Will investigate security filter chains. Thanks for pointing this out.
Edward
Date: Mon, 15 Jun 2015 11:28:25 +0200
To: andrea.aime@anonymised.com
CC: emacgillavry@anonymised.com; geoserver-users@lists.sourceforge.net
Christian
On Mon, Jun 15, 2015 at 11:16 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Edward
create dynamic thematic maps.Cheers
@geowolf
