On Mon, Feb 29, 2016 at 2:21 PM, TRD <mreichardt@anonymised.com> wrote:
I figured out that there is a wfs.xml in the root data dir of geoserver.
This file contains a versions-section from which I removed the part for
version 1.0.0. But that did not the trick (even after restarting
geoserver).
The capabilities document and any other wfs requests were still allowed for
version 1.0.0.
There is no way to disable a specific service version.
It would be nice to have such ability though, if you are interested in
putting resources towards making it happen
have a look at this guide:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
