[Geoserver-users] Disable WMS on Specific workspace?
Editing the global services WMS capabilities document?
Sorry, but i can’t understand what you mean. Could you elaborate more on this?
Also, there is a checkbox in “Edit workspace” page for WMS service which i can’t understand what it does. Checking or unchecking this checkbox has no difference.
Regards
On Wednesday, March 9, 2016 4:15 PM, “Passmore, James H.” jpass@anonymised.com wrote:
Could you edit the global services WMS capabilities document created by the GUI, removing the links to the workspaces that you don’t want to provide as WMS?
-----Original Message-----
From: Saka Royban [mailto:sakaroyban@anonymised.com]
Sent: Wednesday, March 09, 2016 12:21 PM
To: geoserver <geoserver-users@lists.sourceforge.net>
Subject: Re: [Geoserver-users] Disable WMS on Specific workspace?
Hi Jonathan
I’d already read that document and now i read it once more. It doesn’t feet
my needs.
Suppose this scenario: A client connects to my server. He doesn’t know
anything about workspaces and layers loaded in GeoServer. So, he makes a
GetCapabilities request (to global service) to ask about offered layers.
Leaving global services enabled, he sees all workspaces and layers as enabled
and offerable by GeoServer WMS service.
I can’t disable global services, because i wanna tell client which workspaces
and layers are available on the server.
Regards
On Wednesday, March 9, 2016 2:21 PM, Jonathan Moules <jonathan-
lists@anonymised.com221…> wrote:
Hi Saka,
Virtual services should do most (all?) of what you want:
http://docs.geoserver.org/2.1.0/user/services/virtual-services.html
Jonathan
---- On Wed, 09 Mar 2016 06:16:20 +0000 Saka Royban
<sakaroyban@anonymised.com> wrote ----
Hi all
How can i disable WMS on some workspaces while remain it enabled
on others?
I also want those disabled workspaces not to appear on WMS
GetCapabilites.
Regards
This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
