Hello All,
Is it possible to disable the WFS / WCS service on a geoserver instance programatically somehow? Is there something that can be put in the XML config files or a curl command to send?
Thanks
Ramo
Hello All,
Thanks
Ramo
On Thu, Feb 12, 2015 at 5:06 PM, Tobias Reinicke <ramotswa@anonymised.com> wrote:
Hello All,
See here: http://docs.geoserver.org/stable/en/user/rest/api/services.html
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I would try grabbing the settings from
http://default-geoserver.vagrantup.com:8080/geoserver/rest/services/wfs/settings.xml
and changing the enabled value to false and PUTTing it back
I’ve not tried (as I need my WFS running) but that should work
Ian
On Thu Feb 12 2015 at 4:08:21 PM Tobias Reinicke <ramotswa@anonymised.com> wrote:
Hello All,
Thanks
Ramo
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/_______________________________________________
Geoserver-users mailing list
Geoserver-users@anonymised.comsourceforge.net
