Mark,
I’ve had similar problems in the past with the quota store, see this thread.
tl;dr So I’ve just removed the “diskquota.index.db” file and restarted Geoserver, seems to be ok now.
Rob
From: Ismail, Mark [mailto:mark.ismail@anonymised.com]
Sent: 30 April 2014 14:59
To: ‘Jonathan Moules’
Cc: geoserver mailing list (geoserver-users@lists.sourceforge.net)
Subject: Re: [Geoserver-users] Disk quota showing incorrect values
Hi
I didn’t manually delete I used geowebcache tools to do it
I have tried turning quota on and off and it didn’t clear the error
I am using the built in database
Mark Ismail
Principal IT Officer
Tel: 0151 443 3021
Knowsley Council ê Westmorland Road ê Huyton ê L36 9GL
Save time – use the IT Service Desk Self Serve Application
From: Jonathan Moules [mailto:jonathanmoules@anonymised.com]
Sent: 30 April 2014 14:47
To: Ismail, Mark
Hi Mark,
This is a known issue with manually deleting files. You should use the interface to “truncate” the files that way the quota software doesn’t lose track.
To resolve the issue now, I believe disabling the quota cache and re-enabling it should suffice. Alternately just set the value to “0” in the database if you’re using an external one like Oracle.
Jonathan
On 30 April 2014 13:14, Ismail, Mark <mark.ismail@anonymised.com440…> wrote:
I started to generate a lot of tiles and stopped it when I realised it was going to fill the server hard drive
I then truncated the data using the tile layers link in the tile caching section
It quite happily deleted the tiles
My problem is my cache now says :-
Using -902,033,408.0 B of a maximum 10.0 GB
When I am using about 50mb
Any idea how I can reset / fix this ?
Mark Ismail
Tel: 0151 443 3021
This e-mail and any attachments are confidential. It may contain privileged information and is intended for the named recipient(s) only. It must not be distributed without consent. If you are not one of the intended recipients, please notify the sender immediately and do not disclose, distribute, or retain this email or any part of it and do not take any action based on it.
Unless expressly stated, opinions in this email are those of the individual sender, and not of Knowsley MBC. Legally binding obligations can only be created for, or be entered into on behalf of, Knowsley MBC by duly authorised officers or representatives.
Knowsley MBC excludes any liability whatsoever for any offence caused, any direct or consequential loss arising from the use, or reliance on, this e-mail or its contents. We believe but do not warrant that this e-mail and any attachments are virus free. You must therefore take full responsibility for virus checking and no responsibility is accepted for loss or damage arising from viruses or changes made to this message after it was sent. Knowsley MBC reserves the right to monitor and/or record all e-mail communications through its network in accordance with relevant legislation.
“Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos. Get
unparalleled scalability from the best Selenium testing platform available.
Simple to use. Nothing to install. Get started now for free.”
http://p.sf.net/sfu/SauceLabs
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
<br>DISCLAIMER: The information contained in this communication/message from Robert.Langford@anonymised.com..5490... sent on Wed Apr 30 15:09:26 2014 is confidential. It is intended solely for the addressee(s) mark.ismail@anonymised.com;geoserver-users@anonymised.comurceforge.net<br><br>Access to this message by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful.<br>As a public body, Salford City Council may be required to disclose this email [or any response to it] under the Freedom of Information Act 2000, unless the information in it is covered by one of the exemptions in the Act.<br>Please immediately contact the sender, Robert.Langford@anonymised.com if you have received this message in error.<br><br>For the full disclaimer please access http://www.salford.gov.uk/e-mail. Thank you.<br>
