Hi again,
No I've got a minor problem with the GWC componenent of GeoServer 2.3.0 : the "Disk Used" field also shows a 0.0B value. I can used the tiles of my old GeoServer 2.2.2, or seed new ones, I never have any value for this. Do you know what can cause that ?
In my configuration, "Disk Quota" option is disabled, and all provided services concerning Cache are enabled.
Thanks !
Gabriel Vatin
On Thu, Mar 21, 2013 at 3:46 PM, Gabriel Vatin
<gabriel.vatin@anonymised.com> wrote:
Hi again,
Disk quota is the only thing that tracks space used by tiles, so if you have
it disabled, there is no way to know how much space each layer is using.
See also:
http://jira.codehaus.org/browse/GEOS-5673
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Ok, so that's my fault !
Indeed, I just changed it and Size is displayed. In GS 2.2, I had Quota disabled, but the Disk Used was displayed yet.
Thanks Aime.
Gabriel
Hi again,
See also:
On Thu, Mar 21, 2013 at 4:00 PM, Gabriel Vatin
Yeah, that was a bug in 2.2. Basically the disk quota subsystem was
working even if you
disabled it...
Ing. Andrea Aime
@geowolf
Technical Lead
Does this mean that the Disk Quota system is broken in 2.2.4? I am currently clustering 4 Geoserver nodes to a single data directory and need the Disk Quota turned off for this to work correctly.
Thank
-robert
-----Original Message-----
From: Andrea Aime [mailto:andrea.aime@anonymised.com]
Sent: Thursday, March 21, 2013 8:04 AM
To: Gabriel Vatin
Cc: GeoServer Users
Subject: Re: [Geoserver-users] Disk used of tiled layers - GS 2.3.0
On Thu, Mar 21, 2013 at 4:00 PM, Gabriel Vatin <gabriel.vatin@anonymised.com> wrote:
Yeah, that was a bug in 2.2. Basically the disk quota subsystem was working even if you disabled it...
Ing. Andrea Aime
@geowolf
Technical Lead
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_mar
Geoserver-users mailing list
On Thu, Mar 21, 2013 at 6:46 PM, Brister, Robert L
If you did that, you disabled it with the system variable as opposed via the UI.
In that case it's really off
Ing. Andrea Aime
@geowolf
Technical Lead
