[Geoserver-users] Displa remote data source
Hi
Can we display in GeoServer remote data source (from another server) ?
I think it is possible, because when I create a new ressource, if I set an
entire URL, when I save I can see contents of the remote directory.
But as soon as I want publish one of theses remote layers, GS says no !
What am I doing wrong ?
Thanks !
On Mon, Jun 1, 2015 at 2:41 PM, Georges H <georges.hinot@anonymised.com> wrote:
Hi
What kind of remote data source, what GeoServer version?
When subscribing to the GeoServer mailing list the users are requested to
read the "posting guidelines",
which should have this kind of generic mails. Please read it now and try
again :wink:
http://geoserver.org/comm/userlist-guidelines.html
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi
I talk about a remote shapes directory.
Yes, I have search in the doc, but without success (http://docs.geoserver.org/stable/en/user/data/vector/directory.html).
Whenever I create the remote warehouse, GS change the URL, adding “file:xxxx”.
Is it possible to ask GS to use only absolute path, like “http://www.xxx.com/directory” ?
2015-06-01 14:53 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com>:
Hi
When subscribing to the GeoServer mailing list the users are requested to read the “posting guidelines”,
which should have this kind of generic mails. Please read it now and try again :wink:
Ing. Andrea Aime
@geowolf
Technical Lead
Georges Hinot
CNRS - DRIIHM - UMS BBEES (3468)
Musée d’Histoire Naturelle de Paris, Maison Buffon
Géomaticien - Administrateur BDD - Intégrateur
georges.hinot@…7078…
Tél : 01 40 79 80 44
Tél : 06 47 61 84 92
Le nouveau site DRIIHM-ROHM !
On Mon, Jun 1, 2015 at 3:25 PM, Georges H <georges.hinot@anonymised.com> wrote:
Hi
"file:xxxx".
Is it possible to ask GS to use only absolute path, like "
http://www.xxx.com/directory&quot; ?
No, there is no support for reading a shapefile over HTTP, it has to be on
a local drive.
I was about to add "or look like it's on a local drive", but as far as I
can see, at least on
Linux, one cannot mount a remote http server as part of the file system, it
has to be
at least a Webdav server to do that using FUSE:
Not sure about Windows, I could not find anything of the sort.
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Jun 1, 2015 at 3:30 PM, Andrea Aime <andrea.aime@anonymised.com>
it has to be
http://unix.stackexchange.com/questions/67568/mount-http-server-as-file-system
Ing. Andrea Aime
@geowolf
Technical Lead
Ok thanks.
it is sad, because before to change the path, GS recognize the remote file…
But, OK, noticed.
2015-06-01 15:30 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com07…>:
On Mon, Jun 1, 2015 at 3:30 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
I was about to add “or look like it’s on a local drive”, but as far as I can see, at least on
Linux, one cannot mount a remote http server as part of the file system, it has to be
Georges Hinot
