Dear John,
a few things:
-1- I would go from JPEG + world file to GeoTiff JPEG compressed with
overviews (see
https://geoserver.geo-solutions.it/edu/en/raster_data/advanced_gdal/example4.html#example-n-4-serving-a-large-number-of-satellite-aerial-rgb-geotiff-with-compression)
-2- You shall use ImageMosaic with either a custom dimension or a
cql_filter support which is dynamic (you can add it to WMS queries)
and act on the underlying index attributes. You can easily collect
attributes from the filenames and turn them into attributes into the
underlying index ( see
https://geoserver.geo-solutions.it/edu/en/multidim/imagemosaic/mosaic_indexer.html#imagemosaic-file-indexing-options).
As an instance you could use the file name and put that in an
attribute in the index which can be queried directly or turned into a
custom dimension.
-3- I would put the index in DBMS rather than using a shapefile (this
is an optional step though, see
https://geoserver.geo-solutions.it/edu/en/multidim/imagemosaic/mosaic_datastore.html)
This should be enough to get you started I believe.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
Con riferimento alla normativa sul trattamento dei dati personali
(Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
“GDPR”), si precisa che ogni circostanza inerente alla presente email
(il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
conoscenza è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato
se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential
or otherwise protected from disclosure. We remind that - as provided
by European Regulation 2016/679 “GDPR” - copying, dissemination or use
of this e-mail or the information herein by anyone other than the
intended recipient is prohibited. If you have received this email by
mistake, please notify us immediately by telephone or e-mail.
On Mon, Jun 25, 2018 at 12:22 AM johnnyotoole <johnnyotoole@anonymised.com> wrote:
Use case: I've got a directory which contains thousands of JPG images and
accompanying JGW world files (they are scanned images where users have
red-lined areas of interest). Further images will be added to the directory
over time. In my OpenLayers 4.x web application, the user will be presented
with a list of relevant images. The user will choose which image to display
on the map. The JPG should show on the map, only ever showing one JPG at a
time.
In GeoServer 2.13.1 I can display JPG+JGW files by creating a WorldImage
datasource. This works fine for individual images, but I have to create a
data source for each.
I would like to configure GeoServer to have a single datasource which points
to the directory containing the JPG images. Then from OpenLayers, I'd like
to be able to request the display of any single JPG image in that directory
- showing just one JPG at a time.
Is this possible? Should I use Image Mosaic for this? I have read Image
Mosaic and I don't see a way of requesting the display of just one
image/granule from the mosaic.
John
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
Check out the vibrant tech community on one of the world's most
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
