[Geoserver-users] Display total number of GetFeatureInfo results using FreeMarker Tempate?
Hi Geoserver Users,
I'm converting a simple web mapping application from Mapserver to Geoserver. It's mostly been a big improvement. However, I cannot figure out how to achieve this one thing that was simple in Mapserver.
When I click on the map image (openlayers), to trigger a GetFeatureInfo request, I don't want the default HTML table returned, but a simple HTML list preceded by the number of results to display text such as:
  3 Results
    • Baker Street
    • Pillar Box 365
    • Holmes Residence
In the Mapserver "header" template, this was trivially simple to implement using the "[nr]" (number of results) macro, like this:
  <div><b>[nr] Results</b></div>
However, I cannot figure out how to do this using Geoserver and FreeMarker templates.
Can anybody enlighten me?
Nik.
On Sun, Mar 22, 2015 at 11:05 AM, Nik Sands <nixanz@anonymised.com> wrote:
Hi Geoserver Users,
        3 Results
                • Baker Street
                • Pillar Box 365
                • Holmes Residence
templates.
I think that you can use features?size on each of the feature collections
(one per queried layer) you're getting back, sum the
results, and thus get a total
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for your reply.
I am already using "features?size” to get a result count for each layer. However, I’m not sure how I can sum these together, as each time I get a “features?size” number it is in a completely independent invocation of calling the template.
So I guess my two follow-up questions would be:
  1. Is there some way to pass the result from one invocation of the template to the next?
  2. Is there some way to have the combined result number displayed at the TOP of the HTML returned to the client? (ideally, I’d like this in the header.ftl)
Nik.
Hi Geoserver Users,
I’m converting a simple web mapping application from Mapserver to Geoserver. It’s mostly been a big improvement. However, I cannot figure out how to achieve this one thing that was simple in Mapserver.
When I click on the map image (openlayers), to trigger a GetFeatureInfo request, I don’t want the default HTML table returned, but a simple HTML list preceded by the number of results to display text such as:
3 Results
• Baker Street
• Pillar Box 365
• Holmes Residence
In the Mapserver “header” template, this was trivially simple to implement using the “[nr]” (number of results) macro, like this:
[nr] Results
I think that you can use features?size on each of the feature collections (one per queried layer) you’re getting back, sum the
Ing. Andrea Aime
@geowolf
Technical Lead
header.ftl)
Yes, the only place would be header.ftl... unfortunately it's receiving no
information whatsoever, someone would have
to change the code to make it receive the full set of feature collections,
as a list, instead.
For reference, the change would have to be done here:
https://github.com/geoserver/geoserver/blob/master/src/wms/src/main/java/org/geoserver/wms/featureinfo/HTMLFeatureInfoOutputFormat.java#L120
with a new test covering it, here:
https://github.com/geoserver/geoserver/blob/master/src/wms/src/test/java/org/geoserver/wms/featureinfo/HTMLFeatureInfoOutputFormatTest.java
If you can do java development the most expedient way to get the change in
is for you to submit a pull request (see also
https://github.com/geoserver/geoserver/blob/master/CONTRIBUTING.md),
otherwise you can open a improvement/feature request ticket at:
http://jira.codehaus.org/browse/GEOS
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks Andrea,
Unfortunately, I don’t have the skills for Java development and don’t have access to JIRA (and it’s not obvious how to request an account from the admins).
If somebody could post this as a feature request, I’d be grateful.
Nik.
Yes, the only place would be header.ftl… unfortunately it’s receiving no information whatsoever, someone would have
to change the code to make it receive the full set of feature collections, as a list, instead.
If you can do java development the most expedient way to get the change in is for you to submit a pull request (see also
https://github.com/geoserver/geoserver/blob/master/CONTRIBUTING.md), otherwise you can open a improvement/feature request ticket at:
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Mar 25, 2015 at 10:26 PM, Nik Sands <nixanz@anonymised.com> wrote:
Thanks Andrea,
admins).
http://jira.codehaus.org/browse/GEOS, read on the top left side of the page
(sorry, it's the only part that codehaus let us customize to
add instructions :-p )
Ing. Andrea Aime
@geowolf
Technical Lead
