[Geoserver-users] Displaying SVG external graphic issue
I’m using Geoserver 2.6.2. I need to use a SVG file as an external graphic to style a points layer. When I open the WMS layer in QGIS, the points are not displayed. This is not happening if I use a PNG file.
Here is an extract of my SLD code:
](http://myserver/img/mySymbol.svg%22/%3E) image/svg+xml 40
I’m wondering why the image format has to be svg+xml.
Is an additional XML file needed?
Thomas,
Can you access the file http://myserver/img/mySymbol.svg simply from a web browser? If it is indeed on your server, you can put it next to the SLDs in the same directory and make a relative path to the SVG file.
The tag is the mime-type. SVG is an XML sibling, so no need for an additional XML file.
Kind regards,
Edward
Date: Mon, 11 Jan 2016 13:00:07 +0100
Subject: [Geoserver-users] Displaying SVG external graphic issue
](http://myserver/img/mySymbol.svg%22/%3e) image/svg+xml 40
------------------------------------------------------------------------------ Site24x7 APM Insight: Get Deep Visibility into Application Performance APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month Monitor end-to-end web transactions and take corrective actions now Troubleshoot faster and improve end-user experience. Signup Now! http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
_______________________________________________ Geoserver-users mailing list Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
Edward,
Thanks for help!
Yes, I can indeed display the SVG symbol in my browser with the URL.
The question remains: *why do PNG files display correctly and SVG files
don't* (both being placed in the same directory)? I would prefer solving
this issue rather than having two different directories for PNG files and
SVG files...
I tested storing the SVG file in the same directory as SLDs and using a
relative path to call the file. This works but the symbol displayed is not
good. It seems to be distorted...
SVG file :
<http://osgeo-org.1560.x6.nabble.com/file/n5244885/svg_file.png&gt;
SVG file as displayed in QGIS :
<http://osgeo-org.1560.x6.nabble.com/file/n5244885/svg_file_qgis.png&gt;
Thanks again in advance for help!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Displaying-SVG-external-graphic-issue-tp5244529p5244885.html
We had a problem two years ago with SVG symbols not displaying. We solved it by don't setting the workspace for the style.
/Per
-----Ursprungligt meddelande-----
Från: wiltomap [mailto:wiltoma@anonymised.com]
Skickat: den 13 januari 2016 09:01
Till: geoserver-users@lists.sourceforge.net
Ämne: Re: [Geoserver-users] Displaying SVG external graphic issue
Edward,
Thanks for help!
don't* (both being placed in the same directory)? I would prefer solving this issue rather than having two different directories for PNG files and SVG files...
I tested storing the SVG file in the same directory as SLDs and using a relative path to call the file. This works but the symbol displayed is not good. It seems to be distorted...
SVG file :
Hi Per,
interesting, did you report it? It would be useful to have a reproducible
issue in the ticket tracker
On Wed, Jan 13, 2016 at 9:39 AM, Per Söderström <per.soderstrom@anonymised.com> wrote:
We had a problem two years ago with SVG symbols not displaying. We solved it by don’t setting the workspace for the style.
/Per
Från: wiltomap [mailto:wiltoma@anonymised.com84…]
Edward,
Thanks for help!
The question remains: why do PNG files display correctly and SVG files
don’t
(both being placed in the same directory)? I would prefer solving this issue rather than having two different directories for PNG files and SVG files…
I tested storing the SVG file in the same directory as SLDs and using a relative path to call the file. This works but the symbol displayed is not good. It seems to be distorted…
SVG file :
<http://osgeo-org.1560.x6.nabble.com/file/n5244885/svg_file.png>
<http://osgeo-org.1560.x6.nabble.com/file/n5244885/svg_file_qgis.png>
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Just for completeness can you open that svg from the machine GeoServer is running on as the user that is running GeoServer?
I’ve had issues in the past with proxies and tomcat not having permission to see the internet.
Ian
On 13 January 2016 at 08:01, wiltomap <wiltoma@anonymised.com> wrote:
Edward,
Thanks for help!
don’t
SVG files…
SVG file :
Ian Turton
Hie !
I modified the SLD by retrieving workspace name (no workspace affected): the
display bug is still present...
And yes, I can open the SVG file from the machine GeoServer is running on.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Displaying-SVG-external-graphic-issue-tp5244529p5244972.html
Same “distortion” happens to me sometimes too. If I try to export my SVG from InkScape using Optimized SVG, sometimes the shapes don’t come out right and have to save the file as InkScape SVG or Plain SVG instead. Never fully investigated what went on there. Also, I find that setting the actual size of the image in the tag using the width and height attributes is necessary for GeoServer to properly render the SVG.
Edward
Date: Wed, 13 Jan 2016 00:01:19 -0800
Subject: Re: [Geoserver-users] Displaying SVG external graphic issue
Edward,
Thanks for help!
don’t
SVG files…
SVG file :
Geoserver-users@anonymised.comrge.net
On Wed, Jan 13, 2016 at 1:39 PM, Edward Mac Gillavry <
emacgillavry@anonymised.com> wrote:
Same "distortion" happens to me sometimes too. If I try to export my SVG
from InkScape using Optimized SVG, sometimes the shapes don't come out
size of the image in the <svg> tag using the width and height attributes is
GeoServer parses and handles SVG using Batik... I was writing that no new
releases showed up in a long
while, but it seems that in 2015 Batik 1.8 got released (we are using 1.7),
if someone is interested in
checking compatibility with the old version and proper functionality we
could upgrade it in some
next release of GeoServer (for it to be part of GeoServer 2.9.x someone
would have to test it right now,
we'll enter feature freeze in a month)
Ing. Andrea Aime
@geowolf
Technical Lead
Great! I've just tried to save my SVG file into « SVG: simple » format (not «
SVG: Inkscape » which is the default SVG format). See screenshot below
(sorry for GUI being in french).
Display is now perfect!
Thanks again.
<http://osgeo-org.1560.x6.nabble.com/file/n5244982/svg_save.png&gt;
View this message in context: http://osgeo-org.1560.x6.nabble.com/Displaying-SVG-external-graphic-issue-tp5244529p5244982.html
Glad to hear it works!
Edward
Date: Wed, 13 Jan 2016 05:01:00 -0800
To: geoserver-users@anonymised.comge.net
Great! I’ve just tried to save my SVG file into « SVG: simple » format (not «
Thanks again.
