[Geoserver-users] DNS, URLs and /geoserver necessary?
Hi
I am trying to setup an installation of geoserver on tomcat with apache in front of it.
I am trying to mount the web app such that the geoserver url is
http://geoserver.gbif.org
like we deploy all our java applications.
However it doesn’t seem too happy… I have either got a typo or I am wondering – does ’geoserver need the “/geoserver” in the URL – e.g.
http://geoserver.gbif.org/geoserver
Tim
Tim Robertson ha scritto:
Hi
http://geoserver.gbif.org/>
Hmmm... I don't think so, but you have to set the "Proxy base URL"
parameter in the Config/Server configuration panel.
It was indeed a typo... it can be mounted as a virtual host no problem in
tomcat with mod_jk
-----Original Message-----
Sent: Monday, August 13, 2007 10:35 AM
To: Tim Robertson
Subject: Re: [Geoserver-users] DNS, URLs and /geoserver necessary?
Hi
in front of it.
However it doesn't seem too happy. I have either got a typo or I am
wondering - does 'geoserver need the "/geoserver" in the URL - e.g.
My recent experience (5 min ago :-)) with tomcat and geoserver is that geoserver behaves correctly in asking the container for its mounting point. This lets you use a server.conf similar to this:
<Service name="Catalina">
       <Connector port="9095" proxyName="my.domain.se" proxyPort="80" />
    <Connector port="19095"/>
    <Engine name="Catalina" defaultHost="localhost">
      <Realm className="org.apache.catalina.realm.UserDatabaseRealm"
             resourceName="UserDatabase" />
      <Host name="localhost" appBase="webapps" />
    </Engine>
     </Service>
This lets you run geoserver proxed *and* access it unproxed, depending on which port you access it on.
Note: All this is without actually modifying PROXY_BASE_URL i geoserver's web.xml
Still, I haven't put this config through all its pases yet. I`ll report back if this doesn't work as well as it appears right now :slight_smile:
Maybe somehow this info could be of interest in some sort of installation wiki page?
Per-Olof
tomcat with mod_jk
From: Andrea Aime [mailto:aaime@anonymised.com] Sent: Monday, August 13, 2007 10:35 AM
To: Tim Robertson
Hi
http://geoserver.gbif.org/&gt;
However it doesn't seem too happy. I have either got a typo or I am wondering - does 'geoserver need the "/geoserver" in the URL - e.g.
Geoserver-users mailing list
Per-Olof Norén ha scritto:
   </Engine>
   </Service>
Indeed it would. The proxy base url thing was designed for reverse
proxies like Squid, and I was unsure about Apache integration in fact.
If you could write up something and send it by mail, we could definitely
add it as a guide in the wiki (the wiki is read only due to spam, only
developers can write on it). Anyways, if you feel like writing lots of
documentation, we can certainly give you write access :slight_smile:
