Manual page for cascading WFS gives advice about how to set outgoing http(s) traffic to go through a proxy server http://docs.geoserver.org/stable/en/user/data/cascaded/wfs.html but this information is missing from cascaded WMS http://docs.geoserver.org/stable/en/user/data/cascaded/wms.html.
It would be good to copy or link the advice for setting the proxy to the WMS page as well. An example about how to edit startup.bat would not harm either
I could make it work by editing this line
if "%JAVA_OPTS%" == "" (set JAVA_OPTS=-XX:MaxPermSize=128m)
into
if "%JAVA_OPTS%" == "" (set JAVA_OPTS="-XX:MaxPermSize=128m -Dhttp.proxyHost=proxy.com -Dhttp.proxyPort=80 -Dhttps.proxyHost=proxy.com -Dhttps.proxyPort=80")
On the WFS page the http.proxySet=true parameter is said to be required. Perhaps it is in the wrapper file but I did not need to set that in the startup.bat file.
-Jukka Rahkonen-
Agreed. Please open a ticket for this.
A pull request to go with it would be appreciated, but not required
On Wed, Sep 17, 2014 at 11:52 AM, Rahkonen Jukka (Tike) <jukka.rahkonen@anonymised.com> wrote:
if “%JAVA_OPTS%” == “” (set JAVA_OPTS=-XX:MaxPermSize=128m)
into
if “%JAVA_OPTS%” == “” (set JAVA_OPTS=“-XX:MaxPermSize=128m -Dhttp.proxyHost=proxy.com -Dhttp.proxyPort=80 -Dhttps.proxyHost=proxy.com -Dhttps.proxyPort=80”)
-Jukka Rahkonen-
Want excitement?
Manually upgrade your production database.
When you want reliability, choose Perforce
Perforce version control. Predictably reliable.
http://pubads.g.doubleclick.net/gampad/clk?id=157508191&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
