On Tue, Feb 2, 2016 at 10:09 PM, adanecito <adanecito@anonymised.com> wrote:
Hi,iuses
I am seeing conflicting views regarding usage of the Bil extension. Some
say
it only uses big endian and others little endian.
Who says that? Do you have links?
If only Big Endian why
does the settings for it have both Big Endian and Little Endian??
Because the code is using it to set the byte order:
https://github.com/geoserver/geoserver/blob/master/src/community/dds/src/main/java/org/geoserver/wms/worldwind/BilMapResponse.java#L224
Also, has anyone gotten that extension to work with a client (like WWJ)?
And
if so what settings did they use and why? If you have say a 16 bit geotiff
why would you use 32 bit bil?
I know we have used it to serve elevation to Cesium with success.
The format was chosen because Cesium can barse BIL, but not GeoTiff (BIL is
way simpler to parse, especially in a browser).
Never tried WWJ myself
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
