[Geoserver-users] Does Geoserver support the ellipsoidal Equidistant Cylindrical projection?
A clean Geoserver installation advertises EPSG:4087 in its OGC WMS
capabilities, which corresponds to an equidistant cylindrical projection
with ellipsoidal calculations.
It seems however that Geoserver treats this reference the same as
EPSG:32662, which is the equidistant cylindrical projection with spherical
calculations.
This can be verified using the Transformation console available in the Demos
section on the Geoserver portal page.
For instance, the point (10, 5) in EPSG:4326 results in the point
(1113194.9079327357 556597.4539663679) when transformed to EPSG:4087 - which
is the same as for EPSG:32662 - while I would expect (1113194.9079327357,
552885.4510584074) for EPSG:4087.
Could this be a bug or am I overlooking something?
Kind regards,
Robin
View this message in context: http://osgeo-org.1560.x6.nabble.com/Does-Geoserver-support-the-ellipsoidal-Equidistant-Cylindrical-projection-tp5217819.html
Hi Robin,
        As you don't seem to have any responses, I'd suggest reporting it as a bug with all the details you have.
Jonathan
-----Original Message-----
From: robkhe [mailto:robinhoutmeyers@anonymised.com]
Sent: Thursday, July 30, 2015 4:38 PM
Subject: [Geoserver-users] Does Geoserver support the ellipsoidal Equidistant Cylindrical projection?
A clean Geoserver installation advertises EPSG:4087 in its OGC WMS capabilities, which corresponds to an equidistant cylindrical projection with ellipsoidal calculations.
It seems however that Geoserver treats this reference the same as EPSG:32662, which is the equidistant cylindrical projection with spherical calculations.
This can be verified using the Transformation console available in the Demos section on the Geoserver portal page.
(1113194.9079327357 556597.4539663679) when transformed to EPSG:4087 - which is the same as for EPSG:32662 - while I would expect (1113194.9079327357,
Kind regards,
Robin
Geoserver-users mailing list
This message has been scanned for viruses by MailControl - www.mailcontrol.com
Click https://www.mailcontrol.com/sr/A3Fy2cJmdgTGX2PQPOmvUrikelaf+VTnw+AX4tuo8GGVpp4hFmdwvpm1t5MUD6ihSOpEbUBhyl3sVggzUgwWUw== to report this email as spam.
HR Wallingford and its subsidiaries uses faxes and emails for confidential and legally privileged business communications. They do not of themselves create legal commitments. Disclosure to parties other than addressees requires our specific consent. We are not liable for unauthorised disclosures nor reliance upon them.
If you have received this message in error please advise us immediately and destroy all copies of it.
HR Wallingford Limited
Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
Registered in England No. 02562099
Jonathan Moules <J.Moules <at> hrwallingford.com> writes:
Hi Robin,
Jonathan
Thanks Jonathan. I've logged this as GEOS-7149.
Robin
From: robkhe [mailto:robinhoutmeyers <at> gmail.com]
To: geoserver-users <at> lists.sourceforge.net
portal page.
Kind regards,
Robin
Geoserver-users <at> lists.sourceforge.net
www.mailcontrol.com
Click
reliance upon them.
