[Geoserver-users] double geoserver deploy
Hello,
I have a simple question:
Does it possible to deploy 2 geoserver (with different name) in the same application server?
Does it produce errors, crashes or malfunctioning??
Thanks a lot in advance.
Eugenio
I have deployed GeoServer 2.3.1, 2.4.4, 2.4.8, 2.5.2 into the same tomcat server. We named them:
/geoserver (2.5.2 as a default)
/geoserver.2.3.1 (for existing deployed server testing)
/geoserver.2.4.4 (for existing deployed server testing)
/geoserver.2.4.8 (for existing deployed server testing)
An issue with this is using an environment variable for the geoserver data dir will force all configured endpoints to use the same directory which can cause problems with the configuration files. Since the format of the configuration can change between versions, you have to allow the default data dir recognition, or setup the web.xml to define the geoserver data dir.
Otherwise, it has worked well for us to test the various deployed GeoServer instances we support.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Description: Description: Description: cid:image001.png@anonymised.com
From: Eugenio Trumpy [mailto:frippe12573@anonymised.com]
Sent: Monday, September 22, 2014 7:24 AM
Subject: [Geoserver-users] double geoserver deploy
Hello,
Eugenio
Ciao Eugenio,
although it should work I would not recommend this approach for
production purposes.
If you are looking for HA you'd better have multiple java processes
running GeoServer which means multiple tomcat instances.
That said can you tell us a bit mroe about what youa re trying to achieve?
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Mon, Sep 22, 2014 at 3:23 PM, Eugenio Trumpy <frippe12573@anonymised.com> wrote:
Hello,
application server?
Eugenio
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ciao Simone,
thank you for your answer, I’m going to plan the setup of 2 tomcat instances for deploying 2 geoserver.
Actually I’m testing your (geosolution) mapstore/geostore to store and serve maps.
Following the documentation I had some troubles configuring the authorization for geostore/geoserver binding,
for instances I was not able to administer my running geoserver (that I was configuring for such binding) since
the active role service had to be setup geostore user.
So that’s way I would setup a geoserver for mapstore/geostore purpose and leave the mine to serve the already existing
layers.
What about? What do you suggest on this regards?
Regards
Eugenio
Date: Mon, 22 Sep 2014 23:15:46 +0200
Subject: Re: [Geoserver-users] double geoserver deploy
To: frippe12573@anonymised.com
CC: geoserver-users@lists.sourceforge.net
Ciao Eugenio,
If you are looking for HA you’d better have multiple java processes
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
On Mon, Sep 22, 2014 at 3:23 PM, Eugenio Trumpy <frippe12573@anonymised.com…> wrote:
Hello,
application server?
Eugenio
Geoserver-users@anonymised.comt
Eugenio,
in my experience, multiple geoserver servlets work fine in a single tomcat. Using JNDI it is even possible to share database connection pools between them.
Kind regards,
Ben.
On 22/09/14 21:23, Eugenio Trumpy wrote:
Hello,
application server?
Eugenio
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Mineral Resources Flagship
Australian Resources Research Centre
