Hello, I have some doubts about Rendering Transformations.
1 - I have a few points on the map, set up the SLD for the heatmap type. I noticed strange behavior. Depending on where I stand the map, the heat spot changes radically, even when there is no change points.
2 - Using the configuration in SLD to pointstacker, I realized that there is a distance comes the point position and where the grouping is indicated
Configuring SLD as follows,it was possible to have the cluster more closest to point, however, the distance to the points to be grouped also became smaller and in some cases, not clustered anymore.
<ogc: Function name = “parameter”>
<ogc: Literal> cellsize </ ogc: Literal>
<ogc: Literal> 1 </ ogc: Literal>
</ ogc: Function>
I am sending a link so that you can see the situation.
In the video, the red dot is the point with the default style for geoserver point.
https://docs.google.com/file/d/0B1rFep5a4kpVWmlxcWQ3ZnFHanlCXzZTWTJYa2NFTU5jU09V/edit?usp=docslist_api
Someone has an explanation to this behavior or i made a wrong configuration in the SLD?
Thanks for the support
Romulo Silva
Programador
SIC - NDS - Núcleo de Desenvolvimento de Software
DÍGITRO TECNOLOGIA
E-mail: romulo.silva@anonymised.com913…
Fone: +55 48 3281-7000 Ramal: 8146
Fax: +55 48 3281-7299
Site: www.digitro.com
“Antes de imprimir, pense na sua responsabilidade e no seu compromisso com o meio ambiente”
Esta mensagem, incluindo seus anexos, é reservada somente à Dígitro e ao destinatário da mensagem. Caso você tenha recebido esta mensagem por engano, queira por favor, retorná-la ao remetente e apagá-la de seus arquivos.
