[Geoserver-users] Download page link broken?
There are many other broken links still, for example http://geoserver.org/display/GEOS/Versioning+WFS
-Jukka Rahkonen-
Stefano Iacovella wrote:
it seems GeoServer download link, as referenced in docs page, page is not working
http://geoserver.org/display/GEOS/Download
returns 404
While the link from the main page works properly:
http://geoserver.org/download/
It was probably updated when switching to github but docs still have a reference to the old one.
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
Hi Juka,
thanks for your answer.
In case of download start page it seems simply a matter of removing the GEOS/ part of the URL, but in the case you noted this seems do nothing as also http://docs.geoserver.org/display/Versioning+WFS does not work.
41.95581N 12.52854E
2014-06-16 15:17 GMT+02:00 Rahkonen Jukka (Tike) <jukka.rahkonen@anonymised.com>:
-Jukka Rahkonen-
returns 404
Stefano
41.95581N 12.52854E
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Geoserver-users mailing list
I thought versioning WFS (i.e. the functionality) was removed … we kind of recommend people use geogit now?
I expect this page needs to be removed from the user manual.
Jody Garnett
On Mon, Jun 16, 2014 at 11:17 PM, Rahkonen Jukka (Tike) <jukka.rahkonen@anonymised.com> wrote:
-Jukka Rahkonen-
returns 404
Stefano
41.95581N 12.52854E
On Mon, Jun 16, 2014 at 4:23 PM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
I thought versioning WFS (i.e. the functionality) was removed ... we kind
For a list of potential issues, find and grep come to the rescue. Running
against the docs on master:
find . -name "*.rst" | xargs grep '/display'
./source/extensions/csw/features.rst:.. _ResourceInfo:
http://rancor.boundlessgeo.com:8080/display/GEOS/Catalog+Design#CatalogDesign-resources
./source/extensions/jp2k.rst:See
http://docs.codehaus.org/display/GEOTDOC/JP2K+plugin for further
information.
./source/data/app-schema/mapping-file.rst: *
http://udig.refractions.net/confluence/display/EN/Constraint+Query+Language
./source/data/app-schema/cql-functions.rst: *
./source/security/index.rst:masters thesis entitled `Flexible
Authentication for Stateless Web Services <
http://rancor.boundlessgeo.com:8080/display/GEOS/Flexible+Authentication+for+Stateless+Web+Services&gt;\`\_\.
It is good reading to help understanding many of the new concepts
introduced.
./source/filter/ecql_reference.rst:The full language grammar is documented
in the the GeoTools `ECQL BNF definition <
http://docs.codehaus.org/display/GEOTOOLS/ECQL+Parser+Design&gt;\`\_
./source/filter/syntax.rst:- `ECQL Grammar <
http://docs.codehaus.org/display/GEOTOOLS/ECQL+Parser+Design&gt;\`\_ is the
grammar defining the GeoTools ECQL implementation
./source/services/wms/get_legend_graphic/legendgraphic.rst:Do not worry if
it seems like something written in ancient dead language, I am going to
explain the various params here below. Nevertheless it is important to
point out that basic info on how to create and set params can be found in
this `page <
http://rancor.boundlessgeo.com:8080/display/GEOSDOC/GetLegendGraphic+Improvements
`_.
./source/services/wms/get_legend_graphic/legendgraphic.rst:I am now going
to briefly explain the various parameters tht we can use to control the
layout and content of the legend (refer also to this `page <
http://rancor.boundlessgeo.com:8080/display/GEOSDOC/GetLegendGraphic+Improvements&gt;\`\_\).
Here below I have put a request that puts all the various options at tow::
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Comments inline, website issue https://github.com/geoserver/geoserver.github.io/issues/12
Short term: replace with http://old.geoserver.org/Catalog%20Design.html
Long term: print this as a PDF at attach it to the wiki page in question, or port to wiki
Replace with http://docs.geotools.org/latest/userguide/library/coverage/jp2k.html
Replace with http://udig.github.io/docs/user/concepts/Constraint%20Query%20Language.html
Short term: http://old.geoserver.org/Flexible%20Authentication%20for%20Stateless%20Web%20Services.html
Long term: print PDF and attach to wiki page? or port to wiki
Short term: No action CodeHaus is keeping confluence up to date.
Long term: Consider making a design page for the geotools guide similar to http://docs.geotools.org/latest/userguide/library/cql/internal.html
No replacement found! Should of been ported to the GeoServer user manual.
Thanks Andrea,
Jody
For a list of potential issues, find and grep come to the rescue. Running against the docs on master:
find . -name “*.rst” | xargs grep ‘/display’
./source/extensions/csw/features.rst:… _ResourceInfo: http://rancor.boundlessgeo.com:8080/display/GEOS/Catalog+Design#CatalogDesign-resources
./source/extensions/jp2k.rst:See http://docs.codehaus.org/display/GEOTDOC/JP2K+plugin for further information.
./source/data/app-schema/mapping-file.rst: * http://udig.refractions.net/confluence/display/EN/Constraint+Query+Language
./source/data/app-schema/cql-functions.rst: * http://udig.refractions.net/confluence/display/EN/Constraint+Query+Language
./source/security/index.rst:masters thesis entitled Flexible Authentication for Stateless Web Services <[http://rancor.boundlessgeo.com:8080/display/GEOS/Flexible+Authentication+for+Stateless+Web+Services](http://rancor.boundlessgeo.com:8080/display/GEOS/Flexible+Authentication+for+Stateless+Web+Services)>_. It is good reading to help understanding many of the new concepts introduced.
./source/filter/ecql_reference.rst:The full language grammar is documented in the the GeoTools ECQL BNF definition <[http://docs.codehaus.org/display/GEOTOOLS/ECQL+Parser+Design](http://docs.codehaus.org/display/GEOTOOLS/ECQL+Parser+Design)>_
./source/filter/syntax.rst:- ECQL Grammar <[http://docs.codehaus.org/display/GEOTOOLS/ECQL+Parser+Design](http://docs.codehaus.org/display/GEOTOOLS/ECQL+Parser+Design)>_ is the grammar defining the GeoTools ECQL implementation
./source/services/wms/get_legend_graphic/legendgraphic.rst:Do not worry if it seems like something written in ancient dead language, I am going to explain the various params here below. Nevertheless it is important to point out that basic info on how to create and set params can be found in this page <[http://rancor.boundlessgeo.com:8080/display/GEOSDOC/GetLegendGraphic+Improvements](http://rancor.boundlessgeo.com:8080/display/GEOSDOC/GetLegendGraphic+Improvements)>_.
./source/services/wms/get_legend_graphic/legendgraphic.rst:I am now going to briefly explain the various parameters tht we can use to control the layout and content of the legend (refer also to this page <[http://rancor.boundlessgeo.com:8080/display/GEOSDOC/GetLegendGraphic+Improvements](http://rancor.boundlessgeo.com:8080/display/GEOSDOC/GetLegendGraphic+Improvements)>_). Here below I have put a request that puts all the various options at tow::
