Hi!
As sad in previous mails, i am drawing PostGIS features trought Geoserver WFS-T and OpenLayers using GOOGLE_HYBRID_MAP as background.
I am not using spherical mercator ad my PostGIS features are in EPSG:4326.
In order to query my features with GetFeatureInfo request I must display them as WMS layers, too.
The problem is that when I refresh my map after drawing I have a shift between WMS and WFS Layers (that are the same feature). I think it is due to NOT spherical mercator projection. Is it right?
So, I have thought to change my map proj using EPSG:900913. Two questions:
* If i draw features in 4326 on GOOGLE layer without changing my
EPSG in spherical mercator, when I serve them trought WMS
GeoServer are they shifted respect actual position? Can I consider
my features position reliable?
* If I must use spherical mercator to draw, have I define
EPSG:900913 in spatial_reference table of PostGIS in order to
create FeatureTypes correctly in GeoServer?
Thanks a lot!
Ing. Fabio D'Ovidio
INOVA Open Solutions s.r.l.
Web : http://www.inovaos.it
Tel.: 081 197 57 600
mail: fabiodovidio@anonymised.com
Hi. Yes you need to use spherical mercator and 900913. Then either
configure the WFS service to serve the data in 900913 or rely on
OpenLayers to do the 4326 to 900913 reprojection. To have OL do the
reprojection just pass option "projection: new
OpenLayers.Projection('EPSG:4326')" to the WFS constructor. Hope this
helps. Cheers. Eric
2008/7/1, Fabio D'Ovidio <fabiodovidio@anonymised.com>:
Hi!
Thanks a lot!
Ing. Fabio D'Ovidio
Users mailing list
Users@anonymised.com
http://openlayers.org/mailman/listinfo/users
