Hello Community,
I want to use GeoServer 2.4.1 as OWS provider for OpenLayers in Drupal. I try to install Drupal7 with XAMPP, PostgreSQL/PostGIS, GeoServer inclusive the respective Drupal modules.
Almost everything went fine (GeoServer configuration, no errors in GeoServer, PostgreSQL filling) but Drupal can’t transfer the User credentials (Log in, pw) to GeoServer.
Drupal Error: ‘GeoServer login failed: Wrong user credentials. Please check the GeoServer URL and your site maintenance account.’ Site maintenance account and GeoServer URL are correct. During Installation process GeoServer has to accept any user credentials and GeoServer has to use them in his authentication processes.
Enquiries for days on end in the drupal.org community issue posts yield no evidence.
Please take a small foretaste of the GeoServer Log file:
// In Drupal SITE MAINTANANCE ACCOUNT I want to log in as admin with pw: ‘test’ and in GeoServer I was logged in as root, pw: ‘geoserver’
Installation attempts 30.10.2013 09:35, 09:36 & 9:38 :
2013-10-30 09:35:06,220 INFO [geoserver.security] - Drupal user tries to log in: pw:
2013-10-30 09:35:06,242 DEBUG [filter.GeoServerUserNamePasswordAuthenticationFilter$1] - Authentication request failed: org.springframework.security.authentication.ProviderNotFoundException: No AuthenticationProvider found for org.springframework.security.authentication.UsernamePasswordAuthenticationToken
2013-10-30 09:35:06,243 DEBUG [filter.GeoServerUserNamePasswordAuthenticationFilter$1] - Updated SecurityContextHolder to contain null Authentication
2013-10-30 09:35:06,243 DEBUG [filter.GeoServerUserNamePasswordAuthenticationFilter$1] - Delegating to authentication failure handlerorg.springframework.security.web.authentication.SimpleUrlAuthenticationFailureHandler@anonymised.com
2013-10-30 09:35:06,243 DEBUG [rememberme.GeoServerTokenBasedRememberMeServices] - Interactive login attempt was unsuccessful.
2013-10-30 09:35:06,243 DEBUG [rememberme.GeoServerTokenBasedRememberMeServices] - Cancelling cookie
GeoServer Security/Authentication: The added Authentication Provider ‘inak’ (workspacename) was pushed to ‘Selected’ and ‘default’ was moved to ‘Available’ in the ‘Provider Chain’.
In the attachment you can find more log files.
Kind regards and thanks for your time.
Toni
Installation environment and configurations:
XAMPP: Apache/2.4.4 (Win32) OpenSSL/1.0.1e PHP/5.5.3
Drupal Config: ‘Installation shares GeoServer with other Drupal instances’ in the CARTARO SETTINGS
GeoServer 2.4.1.: proper installation of the GeoServer extension geoserver-sec-drupal-7.x-1.0 + configuration Using Drupal users and roles for authentication in GeoServer
PostgreSQL 9.3 x64/PostGIS 2.1: userdb ist superuser ‘postgres’; template_postgis_21_sample used
System Win7 x64:
debug_Drupal_install_20131030.rar (137 KB)
