Hi Alexander Petkov,
Thanks again. I got everything working ! (SLD, Search)
I have doubts on converting dwg format ?
What is the projection/coordinate mapping i should set
? (SRS 4326) - Does anyone have a good document on how
to do this ?
What tools should i use ? (GPL - if possible) ?
Muthu Veerappan
Thanks for your answers...I have few more doubts
1) I have 2 layers, can i show them in different
colors ? Is this related to SLD ?
Yes, you can show them in different colors. Yes, you
need to configure
an SLD to accomplish that.
3) Where does the geoserver store the configurations
for stores, styles, featuretypes ? Any xml file or ?
FeatureStore and style configuration is in the
catalog.xml file. This
catalog can have a few places, depending on how you
configured
Geoserver. If you haven't changed the default
directory where
Geoserver stores configuration, that would be the
WEB-INF/catalog.xml
file.
FeatureType configuration is stored in an info.xml
file in a
subdirectory in "data/featureTypes" . Hope this is
clear.
2) I have problem displaying my 3rd layer. I have
all
the information in postgis. 2 layers are always
visible but not the 3rd.. What could be the problem
There could be a number of problems:
1. The postgis layer doesn't have a valid geometry
column.
2. The layer is missing a corresponding entry in the
geometry_columns table.
3. The layer has a different projection than the other
two, despite
the fact that you are configuring it as an EPSG:4326.
4. The FeatureType is not configured properly in
Geoserver.
Overall, it could be a problem on the postgis end or
the geoserver end.
Alex
PR.Muthu Veerappan (முத்து வீரப்பன்
Mobile +971 50 4206576 (Dubai)
e-Mail - muthu@anonymised.com
Check http://www.periyakaruppan.com
Join http://www.buddhibase.org
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
