[Geoserver-users] DXF OutputFormat for WFS
Dear list,
In the documentation I found info about a community module: DXF OutputFormat for WFS
http://docs.geoserver.org/stable/en/user/community/dxf/index.html
On http://docs.geoserver.org/stable/en/user/community/index.html it is stated that this module can be found in the nightly builds (http://gridlock.opengeo.org/geoserver/), but it is not there.
Can someone point me to a working .jar? I found one (2.3), but it crashes geoserver.
Thanks
Bart
AGIV e-mail disclaimer: http://www.agiv.be/gis/organisatie/?artid=355
I did a quick check, and although it compiles, there were some changes on the 2.4.x WFS output format interfaces, so it doesn’t work anymore. I’m going to try to make it work again and keep you informed.
Mauro
2013/11/29 Bart Verbeeck <Bart.Verbeeck@anonymised.com3…>
Thanks a lot
But to save you work, you can also send a working version and tell me what version it works with
Bart
From: maurobartolomeoli@anonymised.com [mailto:maurobartolomeoli@anonymised.com] On Behalf Of Mauro Bartolomeoli
Sent: vrijdag 29 november 2013 11:09
To: Bart Verbeeck
Cc: Mauro Bartolomeoli
Subject: Re: [Geoserver-users] DXF OutputFormat for WFS
Hi Bart,
I suppose some work is needed to make the module work again on 2.4, compiling is not enough. I’ll take a look and if it’s a simple fix I’ll be back with a new jar.
2013/11/29 Bart Verbeeck <Bart.Verbeeck@anonymised.com>
Hi Mauro
Sorry, but geoserver craches again after the install of the jar
· I did a clean install of geoserver2.4.2 under tomcat, and I checked it. It worked
· I copied the dxf jar you sent yesterday to \Tomcat 6.0\webapps\geoserver\WEB-INF\lib
· I restarted tomcat, geoserver can’t be started anymore (see logs)
Thanks if you can find the time to give me advise.
I am so happy someone from Italy is willing to help. I just returned from Italy after working two years in the Varese area. Sorry that I didn’t find the time to learn more than some basic Italian.
Happy to know you liked Italy. Currently I am the original author of the DXF module, so I would be very happy if I can make it work again and if it can be useful to someone :-).
Mauro Bartolomeoli
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
@mauro_bart
That’s what eventually happens to modules staying long term in community area. Maybe consider pushing it to extension?
Thanks a lot
Bart
To: Bart Verbeeck
Hi Bart,
Hi Mauro
Mauro Bartolomeoli
@mauro_bart
@mauro_bart
2013/12/2 Andrea Aime <andrea.aime@anonymised.com>
That's what eventually happens to modules staying long term in community
Yes, we are considering that and we are going to make it happen soon, if
possible.
I got it to work again (Bart I'm sending you a jar to test in a separate
email).
Currently the module has a dependency on the wps extension, so I think we
should split it into two modules, the outputformat itself and the wps PPIO.
Mauro
information.
@mauro_bart
The last discussion on this:
http://sourceforge.net/p/geoserver/mailman/message/31089820/
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 2 December 2013 10:39, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Rapidly troubleshoot problems before they affect your business. Most IT
organizations don’t have a clear picture of how application performance
affects their revenue. With AppDynamics, you get 100% visibility into your
Java,.NET, & PHP application. Start your 15-day FREE TRIAL of AppDynamics Pro!
http://pubads.g.doubleclick.net/gampad/clk?id=84349351&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Yes, we are considering that and we are going to make it happen soon, if possible.
I got it to work again (Bart I’m sending you a jar to test in a separate email).
Currently the module has a dependency on the wps extension, so I think we should split it into two modules, the outputformat itself and the wps PPIO.
Mauro
@mauro_bart
2013/12/2 Jonathan Moules <jonathanmoules@anonymised.com>
Hi Jonathan,
thanks for the reminder.
Mauro
information.
@mauro_bart
Hi, if anyone is interested, the dxf community module has been added to the
nightly builds on master and spllited in two jars, one for the wfs support
and one for wps.
I will do the same on the 2.4.x branch soon.
Mauro
information.
@mauro_bart
