[Geoserver-users] Dynamic generated image url in SLD not working in 2.23.2
Hello
After upgrading to Geoserver 2.23.2 (from version 2.22.3) some of your dynamic image url’s (In SLD’s) stopped working, and we are getting som errors:
URI.normalize() not available for location:
Path.normalize() not available for location:
Error occurred evaluating external graphic org.geotools.data.ows.URLCheckerException: Unable to normalize location:
The url is as follows:
https:///ImageHandler.ashx?parameters=&imageurl=https:///Images/NorthArrows/northmicro.png&wkt=POLYGON|((588873.93564633|6137127.0831221,|588873.93564633|6137249.5831221,|588996.43564633|6137249.5831221,|588996.43564633|6137127.0831221,|588873.93564633|6137127.0831221))&plotscale=3500&wms_scale_denominator=3306.045340050377&wms_height=1123&wms_width=794&wms_bbox=588313.93564633|589048.93564633,6136262.5831221|6137302.0831221
The url works as expected from the service we are calling and it is returning the correct image, and have been working perfectly on older versions of geoserver.
Do any of you have an idea of what has changed in 2.23.2?
Med venlig hilsen / Best regards
Karsten Darré
GIS-udvikler
As described on the blog announcement (https://geoserver.org/announcements/2023/07/21/geoserver-2-23-2-released.html) this release includes a URL Checking function to prevent OGC processes from calling arbitrary URLs as a security enhancement.
You will need to white list the __https://**********/ImageHandler.ashx__ url (but be careful escaping those *)
Ian
Ian Turton
New security check, described in the GeoServer 2.23.2 release announcement:
and documented in detail here:
https://docs.geoserver.org/maintain/en/user/security/urlchecks.html
You’ll have to whitelist the host that generates the dynamic images
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
I looked at the example URL and it is getting blocked because of a “java.net.URISyntaxException: Illegal character in query”. The URL checking feature was modified to reject URLs that contain invalid characters to prevent them from bypassing the URL normalization and allowing access to arbitrary URL paths. A feature enhancement would be to modify the URL normalization to properly normalize the URL path even with invalid characters in the query and fragment.
If it is feasible to modify your image URLs, changing all of the “|” characters to the string “%7c” should allow it to pass the URL check although your image service will have to know to decode it.
Steve Ikeoka
Sent: Friday, September 1, 2023 3:00 AM
To: Karsten Darré <KDA@…10084…>
Cc: geoserver-users@lists.sourceforge.net geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Dynamic generated image url in SLD not working in 2.23.2
[External: Use caution with links & attachments]
On Fri, Sep 1, 2023 at 11:34 AM Karsten Darré via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Hello Steve
Thank you for the information, we will try this out, it is possible to change all the pipes out :blush:
Again thank you very much for the help!
Med venlig hilsen
Karsten Darré
GIS-udvikler
Fra: Ikeoka, Steve <Steve.Ikeoka@…4839…>
Sendt: 1. september 2023 17:40
Til: Andrea Aime <andrea.aime@…10949…>; Karsten Darré <KDA@…10083…>
Emne: Re: [Geoserver-users] Dynamic generated image url in SLD not working in 2.23.2
You don’t often get email from steve.ikeoka@…1196…. Learn why this is important
Steve Ikeoka
Cc: geoserver-users@lists.sourceforge.net <geoserver-users@lists.sourceforge.net>
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
