[Geoserver-users] Dynamic GetLegendGraphic
Hello list!
Altough the GetLegendGraphic functionality works great for simple
cases/layers/layergroups there are some shortcomings when dealing with
more complex layer(groups).
I'm in a phase where I consider wether GetLegendGraphic as implemented
by Geoserver meets my needs, and the possibility of improving it.
My main wish for the GetLegendGraphic is to make it "dynamic", i.e.
supply it a bbox (and map with/height?) as in GetMap, and get back a
legend consisting of just the features available on the given are (so
that the legend matches the part of the map the user currently sees).
I haven't found any previous discussions on this, sorry if I have
overlooked any. In my mind this seems like a rather simple task:
- Geoserver has code for getting features at a given area (used in
GetMap)
- Geoserver supports rendering of legend entries
I guess the main issue is combining these in a simple and (rather) fast
manner, so that GetLegendGraphic is performant.
When it comes to implementation my java skills are severly lacking and I
am not familiar with the Geoserver codebase, but given some pointers and
guidance I guess I could try. Another option I'm considering is
sponsoring the development of this, but in order to justify this I need
some (guess/est)imates on time/complexity of the task, and of course I
need someone (with knowledge of WMS in Geoserver) to take on the task.
Please not that I am just asking for some ballpark figures, and if this
is something that (if funded) would be considered added to Geoserver.
So, any comments, pointers, and esitmates welcome!
Best Regards
Atle F. Sveen
  Atle Frenvik Sveen
  atle@anonymised.com
  45278689
  atlefren.net
On Tue, Sep 20, 2016 at 1:00 PM, Atle Frenvik Sveen <atle@anonymised.com>
The simplest approach is probably to:
   - Add the bbox, srs to the GetLegendGraphic request object as a
   https://github.com/geoserver/geoserver/blob/master/src/wms/src/main/java/org/geoserver/wms/GetLegendGraphicRequest.java
   (the scale denominator is already an existing parameter, and width/height
   have a different meaning by spec, so I'm not sure about adding a different
   set of width/height, some consideration should be done about pros/cons of
   each choice)
   - Modify
   https://github.com/geoserver/geoserver/blob/master/src/wms/src/main/java/org/geoserver/wms/legendgraphic/BufferedImageLegendGraphicBuilder.java
   to count how many features match a rule own filter along with the correct
   bbox one (which has to be expressed in the source CRS, and take into
   account eventual map wrapping), if the count is zero, discard the rule
The changes need to be packaged as a pull request, following these rules:
https://github.com/geoserver/geoserver/blob/master/CONTRIBUTING.md
You can also check this guide, but given the mail, you might have already
read it:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
I believe this is something that would be quite welcomed. Sponsoring wise,
we normally do
not provide quotes in public, but you can ask directly to any of these
companies:
http://geoserver.org/support/
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi and thanks for the swift response!
It seems very clear to me that if this feature is to be implemented is
has to be done in cooperation with the Geoserver community, as there are
a lot of options for implementing this.
It is anyways good to hear that this is
a) a feature that is most likely welcome
b) a feature that seems absolutely possible to implement
Regarding quotes I understand that this is not done in public, and I
will follow this up in appropriate channels if I consider this route.
-atle
  Atle Frenvik Sveen
  atle@anonymised.com
  45278689
  atlefren.net
   width/height
   different
   of
   each choice)
   - Modify
   correct
read it:
wise,
we normally do
companies:
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely
for
the attention and use of the named addressee(s) and may be confidential
or
Code).Any use not in accord with its purpose, any disclosure,
reproduction,
copying, distribution, or either dissemination, either whole or partial,
is
or
