[Geoserver-users] Dynamic Legend
Hi all
I have a postgres layer perfectly styled with the colors fetched from a property “graphic”. The layer is dislayed correctly on map.
What I would like to have is the legend as well. This legend should reflect colors and labels from the styled layer.
I saw that currently geoserver builds the legend from rules in the sld, but problem is that I have only a single rule. Colors are fetched from a property field using ogc.
is there a way to have such legend that retrieve colors and labels from properties instead of rules
Thanks a lot
  • Antonio
On Wed, Mar 11, 2015 at 6:17 PM, Antonio Parrotta <antonioparrotta@anonymised.com
wrote:
Hi all
property "graphic". The layer is dislayed correctly on map.
Not at the moment, to do that we would need to figure out all possible
values and all possible values
combinations (in case of multiple properties used in the SLD) which in the
worst case would require
a visit of the entire source data set (which again, in general, is not
feasible because that data set
might be huge).
I believe we have a pull request incoming that will make it possible to
give GeoSErver a pre-built
legend to be used in GetLegendGraphics, which should fit well your case.
Or... well I guess we could implement some way to do the actual data full
scan (with distinct value
extraction when there is a single attribute involved), but we'd need to
find a way to make sure
it does not turn into a performance killer... like caching, or making it
something only the admin
can run and save the results as a pre-cooked legend, or save somewhere the
data distribution
summary and have the legend be built on the fly from that summary, avoiding
to read the whole
dataset (issue, this summary can get out of synch with the data).
Would be interesting work, if we can find funding to sponsor it.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
