[Geoserver-users] Dynamic object creation and layer bounds
I use a layer presenting dynamic objects (that is, objects that are created
after the layer is defined). Two such layers are combined in a layer group.
What happens is that geoserver somehow sets his own values (different from
the one I typed in) to the bounds for this layer group. Of course, when
new objects are added, they are (sometimes) off bounds and not shown on the
layer.
Is there a way to stick these bounds independently of the objects
localization and prevent Geoserver from tempering with them ?
And when / how does Geoserver update these bounds ?
My Geoserver version is 1.6.5.
(Embedded image moved to file: pic02368.jpg)
CONFIDENTIALITE : Ce message et les éventuelles pièces attachées sont
confidentiels. Si vous n'êtes pas dans la liste des destinataires, veuillez
informer l'expéditeur immédiatement et ne pas divulguer le contenu à une
tierce personne, ne pas l'utiliser pour quelque raison que ce soit, ne pas
stocker ou copier l'information qu'il contient sur un quelconque support.
CONFIDENTIALITY : This e-mail and any attachments are confidential and may
be privileged. If you are not a named recipient, please notify the sender
immediately and do not disclose the contents to another person, use it for
any purpose or store or copy the information in any medium.
