Ciao David,
the version is correct, this should work.
Do you see anything in the log related to this error?
If you use a plain colormap things render correctly?
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Fri, Jul 31, 2015 at 6:51 PM, David Haynes II <dahaynes@anonymised.com> wrote:
Geoserver 2.7.1
Git Revision 381d86c5a8678a07eeee34f4c509e75dd03a4421
Build Date 20-May-2015 23:39
GeoTools Version 13.1 (rev 9236ae1374c05c3e52f8aaf74f7272e082669e5d)
GeoWebCache Version 1.7.1 (rev
1.7.x/15d85578685351d50081f45a99b626ffcc26a5fe)
On Fri, Jul 31, 2015 at 11:42 AM, Andrea Aime <andrea.aime@anonymised.com>
wrote:
On Fri, Jul 31, 2015 at 6:38 PM, David Haynes II <dahaynes@anonymised.com> wrote:
Hello,
Thanks for the reply, but it doesn't seem to be working
Which version of GeoServer are you using?
Mauro, do you remember if this feature has already landed in any stable
series,and if so, which one?
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
David Haynes, Ph.D.
Research Associate Terra Populus
Minnesota Population Center
www.terrapop.org
Geoserver-users mailing list
