[Geoserver-users] Dynamic SLD using rasters
Hello,
I successfully created a SLD for a categorical raster that will allow me to turn each pixel value on an off. The initial style has opacity set to ‘0’ and it works fine when previewing in open layers. However, our app which is using leaflet has trouble rendering the image. The image shows a large outlined ‘black’ box in the middle. When you zoom in the image keeps updating.
It seems like I need to change a setting somewhere? Is this a leaflet or a geoserver issue? The rasters being processes are using postgis.
David Haynes, Ph.D.
Research Associate Terra Populus
Minnesota Population Center
www.terrapop.org
On Mon, Aug 3, 2015 at 6:26 PM, David Haynes II <dahaynes@anonymised.com> wrote:
Hello,
'0' and it works fine when previewing in open layers. However, our app
large outlined 'black' box in the middle. When you zoom in the image keeps
updating.
Is the image showing up fine in the GeoServer layer preview?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Mon, Aug 3, 2015 at 6:55 PM, David Haynes II <dahaynes@anonymised.com> wrote:
yes works fine and the parameters work properly as well.
Then it seems you're having troubles with Leaflet
Ing. Andrea Aime
@geowolf
Technical Lead
