...yes its the issue that happens because of tiling.
Have you maybe tried with TILED and TILESORIGIN ? That should
activate metatiler, that will take bigger-3x3 tile. But i guess that
same issue would happen at the edge of 3x3 tile, no ?
Maybe also to put little bit bigger BUFFER? Hmmm...
What do the other suggest?
On Thu, Feb 26, 2009 at 3:32 PM, Lehtonen, Mika <mika@anonymised.com> wrote:
Hi Ivan,
I tried to add buffer:10 into Openlayer's WMS layer options, but it didn't
seem to make any difference..
Odd thing is that I can't any reproduce the problem in Geoserver's map
preview. But in my application it exists right after I remove
singleTile:true from OL-code. I have placed my symbols on top of Google
maps, so I hope it has nothing to do with the problem.
- mika -
P.S. I can send you a little screenshot, if you'd like to see what's
happening. Just inform me about..
Ivan Grcic kirjoitti:
...well BUFFER should help only if they are at the edge of tiles anyway...
Ivan
On Thu, Feb 26, 2009 at 2:52 PM, Ivan Grcic <igrcic@anonymised.com> wrote:
I have same issues but only with Labels, not objects (points) I
thought that adding BUFFER would help, but didnt..thats why for labels
I put untiled layer.
Have you tried using buffer?
geoserver.org/display/GEOSDOC/WMS+vendor+parameters
Cheers!
BTW whats wrong with geoserver.org for some time now? Usually i cant
read anything from the site so always finish using google cache pages
:s
http://209.85.129.132/search?q=cache:SaPJBQi2NcQJ:geoserver.org/display/GEOSDOC/WMS%2Bvendor%2Bparameters+geoserver+venodr&hl=en&client=firefox-a&strip=1
On Thu, Feb 26, 2009 at 10:45 AM, Lehtonen, Mika <mika@anonymised.com>
wrote:
I'm not sure if this is a Geoserver issue and has it got anything to do
with the dynamic symbolizer.
Anyway in 1.7.1 when I am doing dynamic symbolizing with external
references, some of the symbols get cut when using OpenLayers and tiled
mode. This goes as well in my application as in GS MapPreview. Switching
to SingleTile corrects the problem.
Unfortunately I am not allowed to provide you a live example, not in
publicly anyway.
Known issue?
- mika -
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
Geoserver-users mailing list
Ivan Grcic
Ivan Grcic
