[Geoserver-users] Eclipse 3.4 (ganymede) and the GeoServer WAR
I upgraded from Eclipse 3.3 to 3.4 (ganymede) and now the GeoServer
1.6.3 WAR is producing all sorts of XML and JSP validation errors. For
example:
cvc-complex-type.2.4.a: Invalid content was found starting with
element 'responseCrs'. One of '{"http://www.opengis.net/wcs":format\}'
is expected. WCS_getCoverage.xml geoserver/WebContent/data.old/demo line
34 XML Problem
I disabled validation in the project's properties, but the problem
persists. Is anyone else using Eclipse 3.4 and the GeoServer WAR?
Hi Mike,
Can you give a bit more info? How are you using the war inside of Eclipse? Are you running with the Tomcat plugin or something like that.
And when do the errors occur? ON startup? Or when you try to use the web admin tool?
-Justin
example:
34 XML Problem
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Justin Deoliveira
Software Engineer, OpenGeo
http://opengeo.org
