[Geoserver-users] ECW JPEG2000
Hello
I have been trying to convert some tif files in ecw format using Gdal solutions.
I have used this line:
gdal_translate -of ECW -co TARGET=0 -a_srs EPSG:*** input.tif output.ecw
Once I send the command I receive the following message:
Output driver ‘ECW’ not recognised.
Anyone can give any useful tips?
Hi Marco,
I think you are sending your question to the wrong mailing list.
I suggest to send it to the GDAL one instead: http://lists.osgeo.org/mailman/listinfo/gdal-dev
That being said, as far as I know, you should have your GDAL lib being built with support for ECW library (which is a third party, external dependency).
Run a “gdalinfo --format ECW” to check if it’s enabled on your installation.
Moreover, depending on the size of the data you want to convert, I think that you should need a specific ECW license without encoding limitations. (Not sure if the things are changed during these years… )
Hope this helps.
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
On Thu, Jun 26, 2014 at 2:40 PM, marco casella <mcasella03@anonymised.com> wrote:
Hello
Open source business process management suite built on Java and Eclipse
Turn processes into business applications with Bonita BPM Community Edition
Quickly connect people, data, and systems into organized workflows
Winner of BOSSIE, CODIE, OW2 and Gartner awards
http://p.sf.net/sfu/Bonitasoft
Geoserver-users mailing list
