Actually I wanted to fix some minor issue in the wiki, but I only seem
to be able to edit labels.
Anyway, I reckon instead of
[/dev/geoserver/web]mvn run -DGEOSERVER_DATA_DIR=/Users/cholmes/gs-dir
you meant
[/dev/geoserver/web]mvn jetty:run -DGEOSERVER_DATA_DIR=/Users/cholmes/gs-dir
http://geoserver.org/display/GEOSDOC/2+Maven+Quickstart
Martin
Despite the possibility that I might just get blind - I am logged in
(I can see my real name, my username is mgiljohann).
I can see that I am in the confluence-users group, but maybe I need to
be in a geoserver group to edit?
This is more of a minor problem, but since I wanted to dig a bit into
the sources I could take the opportunity and update some docs.
Thanks
Martin
2008/5/1 Arne Kepp <ak@anonymised.com>:
Sorry about that, what is your username?
Are you sure that Confluence is aware that you're logged in? (does it say
your username on the top)
-Arne
The edit button is a bit hidden, perhaps we can change it's location?
On the left hand sidebar hit 'Page Operations' and it'll do a javascript drop down of another four rows (if you're logged in, if not less), the second should be 'edit'.
Chris
Thanks
Martin
-Arne
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference Don't miss this year's exciting event. There's still time to save $100. Use priority code J8TL2D2. http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Geoserver-users mailing list
!DSPAM:4005,4819b48d163522458217002!
+1 on changing the location of the Page Operations. It's not very intuitive, and tripped me up when I first started. Does someone know how to do it? If no one knows, I could dig around...
Mike
Chris
Thanks
Martin
-Arne
!DSPAM:4051,4819dd86231081012714783!
