Hi Simone,
thanks for the reply -
Index rebuild: at the moment i run a cron job to pick up new images and rebuild the index with a little java program which ditches the old one and builds a new one using CatalogBuilder (pls tell me if that is the wrong way to go about it) - 8 lines of code.
return code: could it be an option to configure that - even in the mosaic properties file (that way you don’t need to drag in into the ui in the first instance)?
as this is a show stopper at the moment, is there a way to query the store to get the available start and end time ?
Many thanks
Uwe
On 27/11/2012, at 3:25 AM, Simone Giannecchini wrote:
Ciao Uwe,
a preliminary thing, if you are adding new granules to an existing
mosaic I would rather use postgis as an index and simply ad a new row
when new data is added.That said, right now the default behavior is as you see, that is if
you make a request in the right area but with improper TIME values you
get a void image back.
I believe your request sound reasonable but it might break existing
existing clients. Anyway, if you file an enhancement request this
might spawn some discussion
with the other devs to see what we can do to achieve the requested behavior.Regards,
Simone GiannecchiniOur support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.Ing. Simone Giannecchini
@simogeo
Founder/DirectorGeoSolutions S.A.S.
Via Poggio alle Viti 1187
mob: +39 333 8128928http://www.geo-solutions.it
On Sat, Nov 24, 2012 at 7:29 AM, Uwe.Rosebrock@anonymised.com wrote:
Hi list,
I am using the imagemosaic plugin to serve geotiff’s produced daily (the store index gets rebuild after a new image gets added - that works fine).
If i query for a particular date which doesn’t exist in the index, an empty image gets returned - to my mind it should return a 404.
Could somebody please clarify the response process - and - is there a way to change that response to i.e. 404?
Uwe
Monitor your physical, virtual and cloud infrastructure from a single
web console. Get in-depth insight into apps, servers, databases, vmware,
SAP, cloud infrastructure, etc. Download 30-day Free Trial.
Pricing starts from $795 for 25 servers or applications!
Geoserver-users mailing list
