One alternative is to publish the raster index with footprint polygons and attribute data as a WFS feature type and use WFS requests with suitable filters (location, time, other attributes) for queries.
-Jukka Rahkonen-
Uwe Rosebrock wrote:
Thanks Simone,
Considering that number of raster will eventually become rather large I will move to postgis eventually - at this point i needed something to work.
However that doesn’t really help me with figuring out how much data there is i.e. what is the last or first date (as the index is based on the date).
Is there a way by query to find out ? - Obviously as you can see by now - I am not normally working much in the GIS world.
as to your question - yes and yes.
Uwe
Uwe Rosebrock
Software Engineer
CSIRO Marine & Atmospheric Research
T +61 (0)3 6232 5181
E uwe.rosebrock@anonymised.com
M +61 (0)422 513453
Castray Esplanade,
Hobart, TAS 7000
On 28/11/2012, at 12:13 AM, Simone Giannecchini wrote:
Ciao Uwe,
my suggestion is as follows:
-1- use postgis instead of shapefile for indexing your files
-2- add the incoming file directly to the postigs table used for
indexing. GeoServer will pick it up from there
That said, I can provide some more help on how to do this, but I
believe it would be good also to have some additional info on which
type of raster data you are using, as follows:
- subsequent raster covers the same area at different time?
- all rasters have the same spatial resolution and CRS?
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Mon, Nov 26, 2012 at 10:14 PM, Uwe Rosebrock <uwe.rosebrock@anonymised.com> wrote:
Hi Simone,
thanks for the reply -
Index rebuild: at the moment i run a cron job to pick up new images and
rebuild the index with a little java program which ditches the old one and
builds a new one using CatalogBuilder (pls tell me if that is the wrong way
to go about it) - 8 lines of code.
return code: could it be an option to configure that - even in the mosaic
properties file (that way you don’t need to drag in into the ui in the first
instance)?
as this is a show stopper at the moment, is there a way to query the store
to get the available start and end time ?
Many thanks
Uwe
On 27/11/2012, at 3:25 AM, Simone Giannecchini wrote:
Ciao Uwe,
a preliminary thing, if you are adding new granules to an existing
mosaic I would rather use postgis as an index and simply ad a new row
when new data is added.
That said, right now the default behavior is as you see, that is if
you make a request in the right area but with improper TIME values you
get a void image back.
I believe your request sound reasonable but it might break existing
existing clients. Anyway, if you file an enhancement request this
might spawn some discussion
with the other devs to see what we can do to achieve the requested behavior.
Simone Giannecchini
more information.
@simogeo
Founder/Director
On Sat, Nov 24, 2012 at 7:29 AM, <Uwe.Rosebrock@anonymised.com> wrote:
Hi list,
I am using the imagemosaic plugin to serve geotiff’s produced daily (the
store index gets rebuild after a new image gets added - that works fine).
If i query for a particular date which doesn’t exist in the index, an empty
image gets returned - to my mind it should return a 404.
Could somebody please clarify the response process - and - is there a way to
change that response to i.e. 404?
Uwe
Monitor your physical, virtual and cloud infrastructure from a single
web console. Get in-depth insight into apps, servers, databases, vmware,
SAP, cloud infrastructure, etc. Download 30-day Free Trial.
Pricing starts from $795 for 25 servers or applications!
Geoserver-users mailing list
