What file do i edit to ENABLE_JSONP.
I’m using GeoServer 2.3 with tomcat.
Michael,
You need to set/create an Environment (System) Variable.
Variable name: ENABLE_JSONP
Variable value: true
Rob
From: Michael Savarese [mailto:geomajor56@anonymised.com]
Sent: 09 April 2013 01:09
To: geoserver-users
Subject: [Geoserver-users] ENABLE_JSONP
<br>DISCLAIMER: The information contained in this communication/message from Robert.Langford@anonymised.com..5490... sent on Tue Apr 9 12:08:08 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) geomajor56@anonymised.com..;geoserver-users@lists.sourceforge.net<br><br>Access to this message by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful.<br>As a public body, Salford City Council may be required to disclose this email [or any response to it] under the Freedom of Information Act 2000, unless the information in it is covered by one of the exemptions in the Act.<br>Please immediately contact the sender, Robert.Langford@anonymised.com if you have received this message in error.<br><br>For the full disclaimer please access http://www.salford.gov.uk/e-mail. Thank you.<br> |
