[Geoserver-users] Enabling no-cache headers for Geoserver tiles
Hey, folks:
I am using Geoserver 1.6.5 + Tomcat 4 to generate map tiles for a Google
mashup. I need to _enable_ no-cache headers for the tiles being sent by
Geoserver. We are currently doing this on the browser side (adding a random
number to the tile requests), and this seems to have resulted in a pretty
bad memory leak in IE. We need to test and see if IE's behavior is better
when the server is instructing it not to cache.
I've been searching, and everything I find talks only about disabling
no-cache or enabling various types of caching, and doesn't seem applicable
to a situation where the problem is that these headers aren't being sent.
(Or, to Tomcat 4.) If someone could tell me how to do this, or point me
toward the proper documentation, I'd be grateful.
Dhall
View this message in context: http://www.nabble.com/Enabling-no-cache-headers-for-Geoserver-tiles-tp20944928p20944928.html
I assume you've tried setting it to Cache and then time to 0 ?
If that doesn't help, it's just a cheap shot, you can proxy through Apache. If you have mod_expire installed and set the default to be no-cache then that will apply even to proxied responses.
http://geoserver.org/display/GEOSDOC/How+to+proxy+Jetty+through+Apache+on+port+80
-Arne
DHall wrote:
Hey, folks:
Dhall
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
Unfortunately, my packet sniffing reveals that this doesn't seem to result
in the behavior I want for either IE7 or FF2. :frowning: I see the cache-control
headers on the tile response, but the tiles aren't actually being reloaded
from the WMS by either browser when the overlay.refresh() function
provided by the Google API is called.
Proxying through Apache may not be an option, either. We're pretty much
stuck with what's currently installed, and that does not include Apache.
We've been lucky in that despite being stuck using jdk1.4 and tomcat 4
here, we're seeing excellent behavior from geoserver.
Deirdre
-----Original Message-----
Sent: Wednesday, December 10, 2008 4:34 PM
To: DHall
Subject: Re: [Geoserver-users] Enabling no-cache headers for Geoserver
tiles
port+80
-Arne
DHall wrote:
Hey, folks:
random
pretty
better
applicable
sent.
Dhall
Arne Kepp
Please open an improvement request in jira.codehaus.org.
We'll process it as time permits, if you want a quick solution
you'll either have to change the code yourself or look
for a commercial support provider to code it up for you
(pointers here: http://geoserver.org/display/GEOS/Commercial+Support)
Andrea Aime
