[Geoserver-users] Enlightment needed : Adding Shapefile
Dear All ...
I'm trying to install / config GeoServer 1.6.5
My installation is based on the "war" file.
After deployment from tomcat interface .. it looks good.
Preview Map of "demo" work fine.
Next I try to add my frirst shapefile.
I made a subdirectory called "navnet" .. put my files under that new sub-dir.
Take a steps from tutorial ... to point my DataStorage to one of that shp file.
I put 4326 as srs , click "generate" , click "submit"
Click "apply" and "save"
And I see my data storage at http://192.168.4.2:8080/geoserver/mapPreview.do.
Click on "openlayer" ... and it only show a Blank Box with a Zoom bar at the left.
I have no prj file on that directory .... is that the problem ??
Kindly please give me your enlightment
Sincerely
-bino-
Bino Oetomo ha scritto:
Dear All ...
First thing that comes to mind looking at the above steps is that
you did not configure the proper style for your data?
The basic ones are point/line/polygon, choose the right one from
the top drop down list labelled style, submit/apply and see if
now you get anything.
Andrea Aime
OpenGeo - http://opengeo.org
Dear Andre ...
Thankyou for your enlightment
I did give it "style" .... i put "line" as it's style.
After some try .. I found that some time the map did not displayed promptly ...After a click on my browser's "refresh", it showed up.
That's with Firefox.
I try using Konqueror ... and the problem disapear, just the loading speed is a litle too slow.
My development box is :
- CPU : P4 2Ghz
- RAM : 1.5 GB
- HDD : 40 GB
- ShapeFile :
-rw-r--r-- 1 root root 41M 2008-11-17 18:14 navnet_line.shp
-rw-r--r-- 1 root root 100 2008-11-17 18:14 navnet_marine_line.shp
-rw-r--r-- 1 root root 100 2008-11-17 18:14 navnet_marine_point.shp
-rw-r--r-- 1 root root 100 2008-11-17 18:14 navnet_marine_polygon.shp
-rw-r--r-- 1 root root 100 2008-11-17 18:14 navnet_point.shp
-rw-r--r-- 1 root root 2.9M 2008-11-17 18:14 navnet_poi.shp
-rw-r--r-- 1 root root 66M 2008-11-17 18:14 navnet_polygon.shp
Is it a problem between Engine vs ShapeFile size ?
Sincerely
-bino-
Dear Andre ...
- CPU : P4 2Ghz
- RAM : 1.5 GB
- HDD : 40 GB
- ShapeFile :
Well, the machine is not recent and the shapefile are relatively big,
you definitely won't get instant display trying to put 100MB of
shapefile data on screen.
There are a number of things that can be done to speed up things:
- use the most recent JDK you can find
- on that hardware there's no change the VM will switch to server
   mode by itself, you'll have to tweak the JVM settings manually,
   see: http://geoserver.org/display/GEOSDOC/2.6+GeoServer+in+Production+Environment
- download and install the native portions of JAI and JAI Image I/O
   from jai.dev.java.net and jai-imageio.dev.java.net
- try not to display all that data in a single shot but use
   SLD scale dependency rules to display only parts of your data at
   a time
- if your map is tiled, use a tile cache (e.g. GeoWebCache) to
   cache the tiles and forget about speed issues altogether.
   Of course this assumes your data is not changing fast
Andrea Aime
Dear Andrea
My Installed JDK is : jdk1.6.0_10
Woooppss .... so many variables to set on JVM section ... I don't know how to do it, since I just Install XAMPP, JDK, and Tomcat
Done
I Think I "feel" some small performance raise
  a time
Hmm .. I need to know more about SLD first
Onfortunately .. the shapefiles is gathered from converting single *.mp file.
I read about MySQL data store.
Will it help ?
My wishes about this MySQL dataStore solution is :
- The amount of loaded data is "on demand"
- The map will show label of each object. With Shapefile, looks like the label disapear
I use ogr2ogr to inject my Shapefile to MySql.
Looks like generated database/table structure is diferent per http://geoserver.org/display/GEOSDOC/MySQL+DataStore
my Table structure (export from PhPMyAdmin) :
CREATE TABLE IF NOT EXISTS `navnet_line` (
  `OGR_FID` int(11) NOT NULL auto_increment,
  `SHAPE` geometry NOT NULL,
  `type` decimal(5,0) default NULL,
  `label` varchar(80) default NULL,
  `descr` varchar(80) default NULL,
  `label3` varchar(80) default NULL,
  `city` varchar(80) default NULL,
  `region` varchar(80) default NULL,
  `country` varchar(80) default NULL,
  `zip` varchar(80) default NULL,
  `oneway` decimal(1,0) default NULL,
  `toll` decimal(1,0) default NULL,
  `speed` decimal(2,0) default NULL,
  `roadclass` decimal(2,0) default NULL,
  `roadid` decimal(9,0) default NULL,
  `level` decimal(5,0) default NULL,
  `endlevel` decimal(5,0) default NULL,
  UNIQUE KEY `OGR_FID` (`OGR_FID`),
  SPATIAL KEY `SHAPE` (`SHAPE`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1 AUTO_INCREMENT=241979 ;
Sincerely
-bino-
Dear Andrea
Go into your Tomcat bin directory, look in catalina.sh, you can add
the parameters to JAVA_OPTS variable (double check, I'm not sure
about the name). The params above will make GeoServer startup and first
image serve slower, but then it should become quite a bit faster.
Done
  a time
There is some sample here:
http://geoserver.org/display/GEOSDOC/SLD+Intro+Tutorial
The full specification is here:
http://portal.opengeospatial.org/files/?artifact_id=1188
No no, I mean the output. Are you using OpenLayers in tiled mode?
Andrea Aime
Dear Andrea
Done ... I Add all of it to JAVA_OPTS variable.
Just one option that can not (not yet) succeed .... the one about GarbageCollector
I went to the first url ... learn a litle about it ... and try some experiment
Currently I work on displaying "label"
Not yest succeed .... the "Label" is there in PgSQL table .. but it didn't displayed.
Note : I move the data from shp to pgsql.
This label problem occurs at poi table ... but at Polygon table it work.
I really appreciate your enlightment
-bino-
